Author Topic: What did you do to your bike today ?  (Read 3209453 times)
0 Members and 18 Guests are viewing this topic.
    • http://forums.sohc4.net/index.php?PHPSESSID=5n7u3vt8vditt8ub7so69lan81&/topic,60973.0.html
« Reply #19225 on: February 08, 2015, 09:26:04 AM »
i go for set germen kvality...this  krauser"s ,can go to stalingrad and back..and not a drop of vater vill kome inside
« Reply #19226 on: February 08, 2015, 09:33:59 AM »
have vorked on some adjusters to clutch on cb 550..flatlander have broken his,,so tryed to made some in rs steel..
the first get a bit thin in the flange..,05 mm to thin...so made a ekstra..but think both vill funktion fine...
the lathe is a danish type from city odense...a VESUV..i have build digital scales on..but the orginal are presise..so use it only to komplicied parts..
« Last Edit: February 08, 2015, 09:40:36 AM by strynboen »
Offline alacrity
  • Ride, Optimize, Repeat
« Reply #19227 on: February 08, 2015, 09:51:45 AM »
I wish I had free unfettered access to a lathe nearby...
« Reply #19228 on: February 08, 2015, 10:07:14 AM »
a old lathe is not expensive...but they are often to big, and heavy...and the cutting tool are more expensive then the lathe itself..i have spend 20 years to finde mine machines,,,ans still need a lot..of parts
« Reply #19229 on: February 08, 2015, 11:09:57 AM »
Started my bike with it's new cam trying other jets.
I need custom made pilots for my mikuni carbs.
15 just too small despite air jet 0.6.
17.5 just too large despite air jet 0.9. Larger air jets than 0.9 not possible either, too lean middle and up.
I guess that 16.5 would be fine.  ::)
Offline 750cafe
« Reply #19230 on: February 08, 2015, 11:31:23 AM »
Why not try the 15's with the 0.9 air jet?
Eric
Is there anything more fun than riding? They are between your legs and are quiet when you turn them off.
Offline koendd
« Reply #19231 on: February 08, 2015, 11:39:51 AM »
replaced the fork mayonaise in my K2 for some actual oil and new seals  :o ;D
1972 cb750K2 brat
1976 cb360
1984 GPZ900R
Offline 750cafe
« Reply #19232 on: February 08, 2015, 12:02:39 PM »
Well it's another beautiful day here in the deep south of Oz. The wife forced me at gunpoint to mow the lawn and pull down the Christmas lights, (well, they were becoming spider nests, so fair enough) but as soon as I'd done that I hopped on the ol' Battle Scarred Galactica and went for a hot lap.
I'd had it on the charger overnight, and it started on the first brush of the button, and up to 70 MPH it was as smooth as silk. I took it up to my secret road and gave it the berries, and sadly it missed and farted up to around 90 MPH, but it wasn't happy.
It felt like fuel starvation, but it could have been an ignition issue, either way I didn't stop to examine it, as I was 30 miles from home with few tools, and I was not keen on pushing it, so I limped home. (when I say limped, under 70 MPH it was fine again) It's kind of typical of working on old bikes, you fix one thing, and something else becomes an issue........ ;D
Still running points? If so, try replacing the condensers. That should cure it.  ;)
Eric
« Reply #19233 on: February 08, 2015, 02:06:49 PM »
Eric
That will be even worse when air jet 0.9 gives more air into pilot circuit. Pilot 15 with smaller air jet maybe, like 0.5.
Pilot 17.5 is also correct for the throttle cut-out 1.5 according to what I have read on other forums for VM29. Air jet 0.9 works OK.
I have to compromise by opening the air screws a little. From 1/2 turn out to ~3/4 might improve. But all my road tests so far with plenty of combinations have always worked best with air screws opened 1/2 turn out.
I'll might get some good ideas how to make 16.5 pilots. All 4 must be exactly the same...
« Reply #19234 on: February 08, 2015, 02:16:50 PM »
It def is time!
« Reply #19235 on: February 08, 2015, 02:53:45 PM »
^ good time to clean/polish them fork lowers also ^
« Reply #19236 on: February 08, 2015, 04:14:43 PM »
The clutch cable on the Z1 was a tad long, so I changed it out today with the stock length replacement.
Then, of course I had to take it for a test ride down by the River on a gorgeous winters day, all good.
Then, I thought I would go "check fences", alls good there too, these big boys arent getting out anytime soon...
Maybe throw some steaks on the barbie tonight?
« Reply #19237 on: February 08, 2015, 04:26:15 PM »
Don't be rustlin' them cattle, Steve-O...dare ya to go back later tonight and tip 'em over while they sleep ;D
Offline 750cafe
« Reply #19238 on: February 08, 2015, 06:39:58 PM »
Definite YES to those steaks.
I see that your street bikes also double as off-road bikes just like mine.  :D
What is the name of the reservoir/lake that the Kwacker is next too?
Did you replace the condensers on the 750 yet?
Eric
« Reply #19239 on: February 08, 2015, 07:22:59 PM »
Eric
The Z1 is parked by the Colorado River, called Lake Travis when levels are higher (still in a drought down here).
My K4 has had electronic ignition since I've owned it and runs fantastic, no points/condensers on this one.
Offline budman
  • 1914X
    • LeCompte Electric Bass
« Reply #19240 on: February 08, 2015, 08:20:36 PM »
Nice!
Bud
1973 CB750K3 Chopper
2021 Indian Scout
Offline AlekStooge
  • can't afford cheap stuff
« Reply #19241 on: February 08, 2015, 10:48:45 PM »
That picture makes that tank look real looooong--- Thought you might be getting artsy  :D    Whats that in the background, another ride of yours ?---   Another Eric
[/quote]
No not yet, I'm going to be getting artsy this Spring. The bike in the back is a TU 250.
Offline koendd
« Reply #19242 on: February 08, 2015, 11:17:44 PM »
to bad! allready back together :D
don't like polishing and cleaning, matches the rest of the bike  8) :o
1972 cb750K2 brat
1976 cb360
1984 GPZ900R
« Reply #19243 on: February 08, 2015, 11:48:01 PM »
Eric
No way Eric, I haven't run points in any of my bikes in 30 years or so, points went out with 8 track stereo's didn't they? Nope, I think it's either running too lean with the stock carbs (with 130 mains, from memory) or the float levels need looking at.
I'm torn between continuing to use the stock carbs (because they're easier to live with than my 31mm CR's) or have another go at setting up the twin 34mm Mikuni carbs that I probably didn't spend enough time with when I bought them a year or two ago. Cheers, Terry. ;D
Offline maduncle
  • Don't confuse me with a
« Reply #19244 on: February 09, 2015, 12:50:10 AM »
Didn't do a lot except jump up and down with glee when I went to the letterbox and found the latest copy of Cafe Racer magazine waiting for me.
The Knott CB550 is rather nice, even if he stole my scooter headlamp idea.
CB750K2 (only slightly modified)
Offline tweakin
  • tear down
« Reply #19245 on: February 09, 2015, 06:19:08 AM »
Nice pics Steve-O!
Offline mkoski
« Reply #19246 on: February 09, 2015, 11:02:24 AM »
I got my carbs back together after around 15 hours of working time! Very proud of them! Just gotta restore the rubber boots via wintergreen oil and they will be back on my bike.
For now they are my living room's center piece. =)
« Reply #19247 on: February 09, 2015, 11:29:19 AM »
 8) Nice work!
Offline 750cafe
« Reply #19248 on: February 09, 2015, 03:36:32 PM »
Got the carbs on and mounted, installed a battery, installed a set of exhaust pipes from a G (shaft drive)  model, cleaned and gapped the plugs
added some gasoline and...
(Click on tiny picture for video)
Eric
« Last Edit: February 09, 2015, 04:38:28 PM by 750cafe »
Offline Short shins
  • New Zealand
« Reply #19249 on: February 09, 2015, 04:21:15 PM »
Found out why my tyre went flat
Carnage
What have we learn't Dunno
Tube/tyre combo was less than 10k old.
Dont let the shop install a cheap generic inner tube perhaps
I love sleep. My life has the tendency to fall apart when I'm awake, you know?”
Ernest Hemingway
