Sorted out what gaskets and and O-rings I need to dig in to my top-end. I ordered a whole engine gasket kit, so I had to measure the orings and see which ones I needed... Hondaman's book was helpful in figuring out what I needed: two on top of the cylinders, along with the stud rubbers (holes in gasket are big enough!), and four little orings for the metering jets on top of the head. I got 6 pucks in the gasket set, and I also ordered four more. So I will measure their pocket's depth when I have the towers off, and see which pucks are closest to 0.030" more than that value (according to Hondaman
here. Also going to change out the orings for the tappet covers and breather cover. Set aside the head gasket and valve cover gasket too, as well as four new exhaust gaskets.
Getting organized for this job is half the fun!
I'm going to get everything taken apart, and bring the head and valve cover to be cleaned. Going to clean the rest of the engine once everything is put back together and the weather warms up. No sense in everything getting wet when it is always below freezing!
One other thing I plan to do... remove the tach drive gear from underneath the valve cover. I am not running the stock tach on this bike (electronic tach weeee). I have a plug all made up and ready to go in, and hopefully removing the driver will reduce any tendency for that spot to leak oil. I have an Oring on the plug anyway, but just want to be sure!
