Author Topic: What did you do to your bike today ?  (Read 3750175 times)
« Reply #19450 on: March 15, 2015, 05:20:03 PM »
Wow, I mean just WOW. I got my 750 all together today and took it out for a ride after having the cases apart to address a transmission issue and I'm nothing but smiles right now. It was my first serious effort at messing with a transmission so I was apprehensive on whether I could fix the issue the bike was having popping out of 4th gear when under a load but right now it shifts smoother than it ever has since I've owned and no problem with 4th gear anymore. Today has been a good day for me. ;D
Woo Hoo- Glad you experienced good success !!
    • http://forums.sohc4.net/index.php?PHPSESSID=g9fc0aj96f2912q7bv82to2bu5&/topic,60973.0.html
« Reply #19451 on: March 16, 2015, 09:45:49 AM »
.have my first long ride on the 400 four.
.nice littel bike..it dont have the power of the 550..but have the same stabile kontroll in stering ..it have not be droven for some years..so tires and brakes are hard..but it get softer after some kilometers
it dies a bit aut abaut 120 kmt..but need a tune up..have only thanged oil and filter and adjusted cam thain..
« Last Edit: March 16, 2015, 09:50:09 AM by strynboen »
« Reply #19452 on: March 17, 2015, 04:20:04 AM »
Yesterday I was getting ready to install push and pull cables on the K3F - only to find out the wire to Start button broke off.
Oh well :)
Offline DaveBarbier
« Reply #19453 on: March 17, 2015, 05:22:34 AM »
Ordered new clipons so my new MC wouldn't hit the clamp. And also painted a bracket to hold my ignition. Also ordered this stuff called Versimold, anyone hear of it? It's like play-doh and you can form it to make rubber parts then cure it in the oven or with a heat gun for a few minutes. Resists gas and oil it says. The part can be as good as you want depending on your forming abilities. Hope it works out.
1978 Honda CB550K
« Reply #19454 on: March 17, 2015, 06:44:24 AM »
1978 Honda CB550K
Which Clip-ons did you go with?
Offline DaveBarbier
« Reply #19455 on: March 17, 2015, 09:00:27 AM »
1978 Honda CB550K
These from ebay. http://pages.ebay.com/link/?nav=item.view&alt=web&id=190714880810
See how it looks like you can "choke up" on the bar close to the clamp with the MC? My current clipons, and a lot of others I see, have a really bulky clamp that make the MC hit and not let it get close. These seem like they're shaved down. They didn't have any measurements but I'm going by eye. Hope I'm right!
I could have gone with these to totally eliminate the issue: http://pages.ebay.com/link/?nav=item.view&alt=web&id=181690007779 but where the pinch part is that seems like it would hit my tank. The '78 550K has a pretty large tank. More info than you wanted but I'm at work so I felt like replying in detail, ha.
1978 Honda CB550K
« Reply #19456 on: March 18, 2015, 01:41:15 PM »
New fuel lines to my TMR32's today. The other hoses were not good when one of them got a kink or 2. Result : No fuel to 1,2.
6mm hoses from tank connected with steel braided hoses via reducer 6,3 - 8mm.
Now much better routing of the dual fuel hoses.
Offline CB500_k2
  • Wrenching makes a good retirement.
« Reply #19457 on: March 18, 2015, 02:52:02 PM »
I took a long look at my CBs and then a look at the two feet of snow on each side of the driveway.  It is still too cold to bring my babies back to life.  --sigh
Too many bikes -- too little time
1973 CB500
1974 CB350 - sold
1975 CB400F SuperSport
2000 Ducati Monster Dark
Offline przjohn
« Reply #19458 on: March 18, 2015, 03:11:33 PM »
Ditto, here in Connecticut.  :'(
« Reply #19459 on: March 18, 2015, 03:51:48 PM »
Changed out the clutch cable on my K4.  I found a Euro-spec NOS cable that fits perfect on my K4 which is fitted with super bars.
For more info on this cable with bikes with super bars, go here....
http://forums.sohc4.net/index.php/topic,144511.0.html
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #19460 on: March 19, 2015, 05:37:04 AM »
Got my head torqued down... PO didn't install the M6x35mm under the pucks, so I replaced all 6 of them: 5 M6x35 and 1 M6x90 10.9 grade socket heads with washers. Torqued those all down to 90 in-lbs. On to the head nuts... added a dab of oil on the threads and washers, then torqued in sequence to 8 ft-lbs first, then 15 ft-lbs. Checked them all again afterwards, and the M6s needed a bit of snugging. Tonight I will loosen everything and do it again!
Now I just need to wait on new cam towers to come from a generous forum member, and then I can proceed! I'll check all my torque again before sealing the pucks and putting on the towers.
Also took off the cam chain tensioner and lubed it.
« Last Edit: March 19, 2015, 05:39:03 AM by evanphi »
--Evan
1975 CB750K "Rhonda"
Offline 72 yellow
« Reply #19461 on: March 19, 2015, 02:20:54 PM »
Pounded out old swing arm bushings.  Stopped at a place that sold dry ice.  Packed bushings with the ice while I prepped the swing arm.  Went in and had lunch.  Bushings went in super easy.  Used a 1/2 inch all rod and thick washers.
« Reply #19462 on: March 19, 2015, 06:19:59 PM »
Speedo cable broke on me, guess it happens.
Scavenged the one from the project and replaced it.
Offline edwardmorris
  • Youngish
« Reply #19463 on: March 19, 2015, 07:45:53 PM »
Sat down to put the oil pump back together and realized I don't have the gasket kit yet  >:( >:(. Earlier today picked up cleaned and blasted engine from the shop, time to begin the compulsive cleaning.
« Reply #19464 on: March 20, 2015, 01:02:48 PM »
Started the bike and let idle warm.
Verified that the really cheap and bad fuel line which collapsed direct at installation and tricked me to go for richer pilots due to lack of fuel. Kinked hose hidden behind air filter. I have never seen such bad fuel hose before.
With working fuel lines and fuel too all carbs I also verified that the pilot mixture screw adjust fuel, located on engine side of throttle.
Need to change pilot back to the leaner I had  from the very beginning. Do that tomorrow.
Will search for good fuel hose to be trusted, made in Europe or USA. Cotton or nylon braided would be fine.  Inner diam 8mm and 6,3 mm
« Last Edit: March 20, 2015, 01:06:34 PM by PeWe »
Offline DaveBarbier
« Reply #19465 on: March 21, 2015, 12:01:24 PM »
After another pretty decent snow yesterday I'm out with the bike. Ran wires through the handlebars and going to be installing single brake line. So much cleaner of a look. They're only clipons so it was pretty easy to do.
1978 Honda CB550K
Offline eigenvector
« Reply #19466 on: March 21, 2015, 12:52:49 PM »
Replaced the air filter with a custom built one.  Much tighter fit for the box.
Tightened the #2 exhaust valve, gap was probably double what it should have been.
Reset the idle air mixture screw on the #4 carb, was probably 1/4 turn too far out - I can't remember if that's too lean or rich.
Cleaned the control switch interior.  A lot of my electrical gremlins went away after I wiped off all the grease and dirt that had accumulated in there.
Haven't gone for a ride, need my brake line before I can do that.  Brakes are just too mushy to trust.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
« Reply #19467 on: March 21, 2015, 01:01:30 PM »
faund my old hveel adjusting rig...
Offline evanphi
  • Apparently I'm an
« Reply #19468 on: March 21, 2015, 04:30:38 PM »
Nice haul from Canadian Tire...
Mothers Back to Black
STP High Mileage oil treatment (for the ZDDP)
Permatex Ultra Grey (AKA Hondabond)
Permatex thread sealant
Permatex dielectric grease
Mothers Back to Black really works! Holy smokes! My airbox is all scratched, but at least it's shiny now!
Also did the second round of torques on the head.. loosened 1/2 turn in sequence, tightened to 8ft/lbs then 15ft/lbs.
Installed a new gasket for the cam chain tensioner, which is held back until I get the cam/sprocket on.
Drained all my oil. I'm letting everything drain overnight, and then I'll be dropping the pan tomorrow, too. Just to see what might be lurking inside... we shall see! Probably will give the oil pump screen a scrub, too.
--Evan
« Reply #19469 on: March 21, 2015, 08:15:35 PM »
Engine in the frame.
Oil pump in.  Pan on.
Shifter bits installed.
Alt and shifter covers on.
Cold beverage time!
Offline Raef
« Reply #19470 on: March 21, 2015, 08:45:26 PM »
 I bought a battery and started it, it has been sitting disassembled in a damp block storage building  since november 2011. I got a battery gave it a shot of WD-40 and a shot of starting fluid, it would not turn over with the starter but it started and ran on 4 year old gasoline, one the second kick, I guess I'll put it back together and take it for a ride.
« Reply #19471 on: March 22, 2015, 04:50:33 AM »
No road tests this weekend >:( Difficult to understand that I rode my bike 2-3 days ago
« Reply #19472 on: March 22, 2015, 05:41:24 AM »
That STP additive may possibly just be some snake oil if you want good zinc. Here is one test somebody did on the stuff. Is it for cars that have high mileage already ? http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2701357#Post2701357
« Reply #19473 on: March 22, 2015, 07:21:03 AM »
I have seen adverts for a zddp product from Eastwoods recently.  I'll still stick with the original zddp brand.
Offline Raef
« Reply #19474 on: March 22, 2015, 07:24:56 AM »
Ever use any of the Lucas products?
