Author Topic: What did you do to your bike today ?  (Read 3271005 times)
Offline eigenvector
« Reply #19475 on: March 21, 2015, 12:52:49 PM »
Replaced the air filter with a custom built one.  Much tighter fit for the box.
Tightened the #2 exhaust valve, gap was probably double what it should have been.
Reset the idle air mixture screw on the #4 carb, was probably 1/4 turn too far out - I can't remember if that's too lean or rich.
Cleaned the control switch interior.  A lot of my electrical gremlins went away after I wiped off all the grease and dirt that had accumulated in there.
Haven't gone for a ride, need my brake line before I can do that.  Brakes are just too mushy to trust.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
    • http://forums.sohc4.net/index.php?PHPSESSID=7geevug7mict5k06ujjca9iql6&/topic,60973.0.html
« Reply #19476 on: March 21, 2015, 01:01:30 PM »
faund my old hveel adjusting rig...
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #19477 on: March 21, 2015, 04:30:38 PM »
Nice haul from Canadian Tire...
Mothers Back to Black
STP High Mileage oil treatment (for the ZDDP)
Permatex Ultra Grey (AKA Hondabond)
Permatex thread sealant
Permatex dielectric grease
Mothers Back to Black really works! Holy smokes! My airbox is all scratched, but at least it's shiny now!
Also did the second round of torques on the head.. loosened 1/2 turn in sequence, tightened to 8ft/lbs then 15ft/lbs.
Installed a new gasket for the cam chain tensioner, which is held back until I get the cam/sprocket on.
Drained all my oil. I'm letting everything drain overnight, and then I'll be dropping the pan tomorrow, too. Just to see what might be lurking inside... we shall see! Probably will give the oil pump screen a scrub, too.
--Evan
1975 CB750K "Rhonda"
« Reply #19478 on: March 21, 2015, 08:15:35 PM »
Engine in the frame.
Oil pump in.  Pan on.
Shifter bits installed.
Alt and shifter covers on.
Cold beverage time!
Offline Raef
« Reply #19479 on: March 21, 2015, 08:45:26 PM »
 I bought a battery and started it, it has been sitting disassembled in a damp block storage building  since november 2011. I got a battery gave it a shot of WD-40 and a shot of starting fluid, it would not turn over with the starter but it started and ran on 4 year old gasoline, one the second kick, I guess I'll put it back together and take it for a ride.
« Reply #19480 on: March 22, 2015, 04:50:33 AM »
No road tests this weekend >:( Difficult to understand that I rode my bike 2-3 days ago
« Reply #19481 on: March 22, 2015, 05:41:24 AM »
That STP additive may possibly just be some snake oil if you want good zinc. Here is one test somebody did on the stuff. Is it for cars that have high mileage already ? http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2701357#Post2701357
« Reply #19482 on: March 22, 2015, 07:21:03 AM »
I have seen adverts for a zddp product from Eastwoods recently.  I'll still stick with the original zddp brand.
Offline Raef
« Reply #19483 on: March 22, 2015, 07:24:56 AM »
Ever use any of the Lucas products?
Offline evanphi
  • Apparently I'm an
« Reply #19484 on: March 22, 2015, 10:12:28 AM »
This is all that I could find locally. I'll try it, and probably get the good stuff for next oil change.
--Evan
Offline Jerry E.
« Reply #19485 on: March 22, 2015, 06:47:37 PM »
Replaced the oil stopper seal and spring in my K3 oil pump, to stop the oil draining into engine from oil tank. A lot of work, without a bike lift, and the oil still drains into the motor. No idea's what to do now. Can't ride it like this.
"Why jump from perfectly good airplanes? Because the door opens."
Offline WhyNot2
  • I'm finally an
« Reply #19486 on: March 23, 2015, 02:23:07 AM »
I used lucas gas treatment in my 750 a while back and hasn't run since.
_________________________________________________________________________________________________
I should clarify: Hasn't run right since.
I get backfiring and no power, dropped the bowls, pulled jets, cleaned, reinstalled no change.
Have the carbs off setting float levels, (correctly I hope) and blowing all passages, hope this will work.
Will put some electrical tape around clamped area of the manifolds, due to clamps feeling loose when removed.
« Last Edit: March 23, 2015, 07:59:25 AM by budlite282 »
Offline evanphi
  • Apparently I'm an
« Reply #19487 on: March 23, 2015, 05:51:51 AM »
Yowch... just read that thread... I might just throw it away!
« Last Edit: March 23, 2015, 05:55:08 AM by evanphi »
--Evan
Offline edwardmorris
  • Youngish
« Reply #19488 on: March 23, 2015, 03:03:25 PM »
Finished rebuilding carbs. Few highlights (details in build thread)
Ultrasonically cleaned (I know they look a bit dirty, was handling them after lubing during assembly, will clean it up on installation)
All NOS brass and rubbers
Polished all Aluminum (backplate didn't get the chrome finish, because even I don't have the patience for it)
Zinced every last bit on them (except the cotters, thanks to harisuluv!)
« Reply #19489 on: March 23, 2015, 03:15:19 PM »
  If it has less zinc than the oil you are using that is not good and if you use 20/50 you don't want it getting thicker. May be good for a very tired old smoking engine on its last leg, kind of like Motor Honey.
   Here is a 'zinky' thread to keep you busy for awhile started by our own builder/guru named Mike R.  http://forums.sohc4.net/index.php/topic,49740.msg525949.html#msg525949
« Last Edit: March 23, 2015, 03:25:12 PM by ekpent »
Offline evanphi
  • Apparently I'm an
« Reply #19490 on: March 23, 2015, 06:02:38 PM »
I always like an oil related thread ;D
--Evan
« Reply #19491 on: March 23, 2015, 06:18:21 PM »
You must love popcorn
Offline Eydugstr
« Reply #19492 on: March 23, 2015, 09:02:57 PM »
Finally got mine all back together and rode it some today.  Honda NOS head gasket, new transmission forks, third and fourth gear, better set of carbs, fork brace, added dual disc & new m/c, new cables that fit the superbike bar, proper Honda rear lester wheel instead of an adapted Kaw lester, redone speedo/tach assemblies with green LED lighting, and a charging indicator.  If it wasn't for the clutch rattle I'd swear I was on a different bike.
« Last Edit: March 23, 2015, 09:32:52 PM by Eydugstr »
« Reply #19493 on: March 23, 2015, 10:41:34 PM »
...and you tease us with a night shot of the gauges.    ::) let's see a full shot! :)
Offline evanphi
  • Apparently I'm an
« Reply #19494 on: March 24, 2015, 06:18:33 AM »
Do I ever! Mmmmmmmmmmmmmmmmbutter.
--Evan
Offline Eydugstr
« Reply #19495 on: March 24, 2015, 02:04:49 PM »
It was beginning to rain that night!
« Last Edit: March 24, 2015, 02:10:46 PM by Eydugstr »
« Reply #19496 on: March 24, 2015, 02:17:04 PM »
Yes!  good stuff right there!  8)
DH
« Reply #19497 on: March 24, 2015, 03:08:56 PM »
That's a good looker. Any plans to badge it? (just wonderin')  Proof that a cafe'd, or semi cafe" bike can look good with fenders. Very nice. Do the Lesters allow you to run tubeless?
« Reply #19498 on: March 24, 2015, 07:03:52 PM »
Very Nice....will be nominating you for BOTM.....
« Reply #19499 on: March 24, 2015, 09:45:26 PM »
 I'm not telling this time. nanana.
