Author Topic: What did you do to your bike today ?  (Read 3587349 times)
« Reply #19725 on: May 03, 2015, 06:49:57 AM »
I was kidding about happening while working on the bike. She was doing some gymnastics in the backyard  ;) I've a bit of a sardonic sense of humor
  I thought maybe she scratched your gas tank and you went Steven Seagal on her and snapped that arm like a chicken bone !!
Wobbly
« Reply #19726 on: May 03, 2015, 07:03:12 AM »
Stick with the "while working on the bike" story--it's a lot more dramatic.
Seeing the kids get seriously hurt is the worst for me. When my daughter broke her wrist in the gym, and then was pushed off into surgery, I felt terrible and helpless. I wish your daughter a speedy recovery.
Offline DaveBarbier
« Reply #19727 on: May 03, 2015, 07:05:58 AM »
Haha, nice one. Although I bet a 9 year old's radius and ulna is the perfect size to raise the front when changing a front tire. And now that it's braced with a cast you might want to look into that.
1978 Honda CB550K
Offline DaveBarbier
« Reply #19728 on: May 03, 2015, 07:59:13 AM »
Louis CK has a great bit where his daughter fell and got a black eye so he took her to get ice cream. People in the shop were looking at her and then at him and giving him dirty looks. "They thought I hit her!" He says. "And now I'm giving her ice cream because I feel guilty! I can't believe that they think I did that to her eye. If I hit her, her face would be DEMOLISHED! See these fists!? I could OBLITERATE her tiny face. Not just give her a black eye!"
Something to that extent, haha.
Edit: Clip.
1978 Honda CB550K
Offline fire113
« Reply #19729 on: May 03, 2015, 11:11:53 AM »
...started the K1 for the first time this Year,didn't moved it for a half Year, two kicks an it was running...
Online PeWe
« Reply #19730 on: May 03, 2015, 02:16:53 PM »
Adjusted needles on carbs and test drive on the roads. Much more boring with a cooler cam.. (less hot). But bike runs OK.
Offline koendd
« Reply #19731 on: May 03, 2015, 02:19:32 PM »
repaired some rust on my K2 frame, guess letting it sit for 10+ years on the side stand is a bit to much...
and found another crack as well...
1972 cb750K2 brat
1976 cb360
1984 GPZ900R
Offline Stoli
« Reply #19732 on: May 03, 2015, 04:34:19 PM »
Spring finally arrived in NH today. Pulled the bikes out of the dungeon for another year of fun. Leaky front caliper on build #1 and fork seal leak on #3. The carbs didn't leak on either this year though, so I guess that's progress. These bikes aren't made to be put away for 6 months every year.
« Last Edit: May 03, 2015, 06:09:15 PM by Stoli »
My Project Threads:
Project #1 - http://forums.sohc4.net/index.php?topic=117106.0  First bike
Project #2 - http://forums.sohc4.net/index.php?topic=127364.0  Something different
Project #3 - http://forums.sohc4.net/index.php?topic=123831.0  Long and Low
Offline DaveBarbier
« Reply #19733 on: May 03, 2015, 05:10:05 PM »
Beautiful work space. Mine work space is about the size of one of those blue plastic bin drawers you have on the right.
1978 Honda CB550K
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #19734 on: May 04, 2015, 05:53:28 AM »
Changed a tire using my father in law's tire changing rig. We pinched a new tube. %!%@#&^%#@%&^@#%@# (expletives).
Brought it home, popped the bead off with a couple BFSs, put the old tube in, put the tire all together with the same two BFSs. Not a single leak. Sometimes the simple way works best.
Pictured: All you need for changing a tire... New tire, old tire, bicycle inner tube (aka rim protector), soapy water in a spray bottle, and two Big Fcuking Screwdrivers (aka tire spoons).
--Evan
1975 CB750K "Rhonda"
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
« Reply #19735 on: May 04, 2015, 06:26:32 AM »
Removed my points plate, took off the advancer and snipped a coil from each spring. Reinstalled everything, set gaps, got 1-4 perfect at idle and advance, but still can't get 2-3 lined up at idle... no adjustment left and the timing is slightly advanced. I forgot to check 2-3 advance marks at 2500 rpm. But what are thoughts about this? If my advance marks are on at 2500, should I just forget about idle? Or is there another way? Thanks... in.... "advance?" Doh!
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
Offline evanphi
  • Apparently I'm an
« Reply #19736 on: May 04, 2015, 06:36:21 AM »
Try live-setting your points gap. Closing the gap will retard the timing. Just make sure everything is within spec for your points gap afterwards. \
Condensers good?
--Evan
Offline joeyvans
  • Definitely not a
« Reply #19737 on: May 04, 2015, 07:09:11 AM »
Condensers good?
Live setting gaps? Go on....
I set gaps at .014 thinking it would be better to have leeway, but maybe I should try .012 instead?
I knew I forgot to do something... will test the condensers tonight. If faulty, what is recommended for replacements? I hear Sudco is out. How are K&L or Hitachi?
Thanks man! Sorry the tire changer didn't work out.
1976 CB550 K2
« Reply #19738 on: May 04, 2015, 07:47:54 AM »
Picked up a 1975 Kh400 at a yard sale this weekend. Pretty rough shape. Engine turns and has a title."Ran when parked" back in 1998  :D Seller has owned it for 30 years. 13000+ miles showing. Have two of the 400's now and a 350 triple but Mercy will my day ever come when I finally turn up a nice early 500 or 750 ?? Guess I need to keep huntin' or spend some big cash !!
Offline evanphi
  • Apparently I'm an
« Reply #19739 on: May 04, 2015, 08:29:45 AM »
Condensers good?
Loosen the adjuster screw for adjusting the gap slightly. see the two little knobbies beside the contacts, and the little notch right beside it?
use a flat head screwdriver to adjust your gap, using this notch to move it around. Closing the gap retards the timing. Have the bike running, and the timing light flashing from the appropriate (2 or 3 in your case) spark plug wire.
I just went through the same issue... 1/4 could get right on by adjusting the main plate (using shims), but 2/3 had to be live adjusted. My gaps are 0.011" now, with no ill effects.
Also TEC is the recommended condenser brand.
« Last Edit: May 04, 2015, 08:31:41 AM by evanphi »
--Evan
Offline DaveBarbier
« Reply #19740 on: May 04, 2015, 08:30:31 AM »
Try shimming the plate? I had an issue like that and shimming helped. Also, I've read a lot that below 3000 timing isn't critical since we spend about 95% of our time above 3000 anyway. But if you can, might as well make it perfect.
1978 Honda CB550K
Offline joeyvans
  • Definitely not a
« Reply #19741 on: May 04, 2015, 08:47:13 AM »
Thanks for the tips, Evan and Dave! Evan, I see your 2-3 plate is maxed clockwise like mine, so I'm really hoping the combination of these 2 things will work! I will try both of them tonight. I think my neighbors are getting pissed with me constantly doing warm up laps, then running & revving in the garage. F 'em if they can't take a joke.
1976 CB550 K2
Offline evanphi
  • Apparently I'm an
« Reply #19742 on: May 04, 2015, 09:21:23 AM »
Yeah if your 1/4 is OK I would leave it, then just adjust the 2/3 how I described.
--Evan
Offline MoMo
  • Ride like you're invisible
« Reply #19743 on: May 04, 2015, 12:05:19 PM »
cool looking old plate MI had.   I have a fairly decent tank for the S2 if you ever need one. Keep hunting, it'll show up...Larry
Offline evanphi
  • Apparently I'm an
« Reply #19744 on: May 05, 2015, 06:57:48 AM »
New tire on and re-installed. Turns are much more confident now!
--Evan
« Reply #19745 on: May 05, 2015, 07:25:10 PM »
  Rainy and 50 today so some down time for me and good time to make a fire in the shop. Been posting a little on a 72 I am working on,bought it probably 3 years ago but have yet to ride. Well in 75 degree heat inside(thanks wood) I installed the air box with new filter and my freshly cleaned tank, fuel lines etc.. Also knocked off the front brake for a total clean, wow you should have seen the 'mud' behind that piston. Looks like I may have been the first one in. While I was there drained what was probably original fork oil. Got water out of both sides so that tells me it will need new fork seals in the future if I keep it. It is now a good runner on the kick stand and look forward to a dry day to clean/lube and adjust the chain and cut it loose on the road finally. Am motivated this spring to start wrapping up projects that I have started in the past and have got in the way while I buy more  8)  Parts get lost if you do not follow through.
  Found a Dyna today in an engine I bought sometime last summer,(never know what you may find) now just need to remember where the the hell it goes or came from  ;D  Next up maybe is a GS1000 whose petcock has decided to bleed all over the place out the carbs(have rebuild kit) or tinker with a new Kh400 I just bought. Have a few tanks lined up for cleaning also for a perfect day, mostly a V65 Sabres so I can finally mount that and ride.   Later------   Eric
« Last Edit: May 05, 2015, 07:28:09 PM by ekpent »
« Reply #19746 on: May 05, 2015, 07:30:18 PM »
Hey Eric - about all that is needed on that K2 is to ship it to TX so I can slap some 341's on it!
« Reply #19747 on: May 05, 2015, 07:33:20 PM »
I got some I can put on for you but I think you should wait for an orange or gold one--- sorry and not to offend other members but this color does not do it for me . I think it is my least favorite.
Offline eigenvector
« Reply #19748 on: May 05, 2015, 07:42:09 PM »
That's a nice tire evanphi, what is it?
The D402's that are on mine don't give you much other than they are round.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
« Reply #19749 on: May 05, 2015, 07:55:26 PM »
I like that it's differant.  Seems everyone has a Goldie and my K1 has an Orange tank on it.
