Author Topic: What did you do to your bike today ?  (Read 3217420 times)
« Reply #19800 on: May 11, 2015, 05:26:03 AM »
Wife and I did a ride this weekend      ;)
Did you get new, matching jackets, Eric?
Offline InAquaVeritas
« Reply #19801 on: May 11, 2015, 05:44:30 AM »
Heels make the man!
Verzonden vanaf mijn iPhone met behulp van Tapatalk
Surf bum trying his hand at wrenching!
Past "bikes" ;)
1981 Honda MT 50cc - Torn apart, put back together and got run down on..
1994 Derby Senda R 50cc - Fell apart
2001 Derby Senda R 50cc - 13/45 changed to 15/70, hit 90 kph in under 150 meters! Undriveable fun!
1987 Suzuki GN250 - Sold
1977 Honda CB750 F1 - F2 engine, '05 ZX6R front end and wheels, '04 ZX6R shortened swing arm converted to twin shock. http://forums.sohc4.net/index.php?topic=133411.0
1987 Honda XR600 Supermoto conversion. CR250 forks and triple. SM wheels, discs front and back. Rebuilt engine. Loudest exhaust in the world: Leovinci X3
Offline socal1200r
« Reply #19802 on: May 11, 2015, 01:37:50 PM »
Yeah, I wanna see the S&M Club patch on the back, lol...
« Reply #19803 on: May 12, 2015, 03:37:07 AM »
Holy sihte  ;D ;D
« Reply #19804 on: May 13, 2015, 05:42:09 AM »
   Sooo I recently finished a K2 project and all is good. Next up on the poop deck are a couple of F models. I bought 2- F model part outs last fall so it will be a good time to sort the piles and use what I need. The orange 75 was bought from the original owner and shows 21,000 on the clock. Had a fairing etc as seen in the pics. Plan is to put it back to stock and replace the rear 16" Lester with an 18" stock rear. Think I have everything needed to do it like signals, headlight blah blah.
  The yellow F is one owner removed from the original and has 8700 miles on it. Needs a side cover and somebody put an aftermarket exhaust and rear master on it both of which I have stock replacements for. Hopefully find a nice seat cover.
  Both bikes have electronic ignitions and I already went through the carbs, oil and plug changes, tappets and all the tune-up stuff etc. and both ran well off the bottle before putting away for later.  Need to get some more stuff officially done in the shop before I get tempted to start buying again.  More later if you like pictures.  Eric
« Last Edit: May 13, 2015, 05:46:10 AM by ekpent »
Offline Tews19
  • I am no
« Reply #19805 on: May 13, 2015, 05:45:32 AM »
The orange 750 looks nice! It would match it's Lil brother in my garage.
1970 Honda CB750 survivor.
Offline goldarrow
  • one day, i'll be an
« Reply #19806 on: May 13, 2015, 05:53:27 AM »
The rear mag wheel on the Orange F is Morris.
CB550 K0
« Reply #19807 on: May 13, 2015, 06:01:51 AM »
Hmmm-I will have to take a closer look, sure looked like, or I just assumed a Lester. Here is a closer pic I took last night. Guess maybe the ribbing is different  ?, your the expert on these Goldie !!
« Last Edit: May 13, 2015, 06:04:16 AM by ekpent »
Offline goldarrow
« Reply #19808 on: May 13, 2015, 06:06:42 AM »
Definitely Morris, here's mine.
CB550 K0
« Reply #19809 on: May 13, 2015, 06:36:44 AM »
Were almost twins !!
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
« Reply #19810 on: May 13, 2015, 06:41:39 AM »
Man, those orange F's are good looking bikes!
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
Offline goldarrow
« Reply #19811 on: May 13, 2015, 06:44:30 AM »
Frank 754 has the front to mate with yours then we be twin :)
CB550 K0
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #19812 on: May 13, 2015, 07:52:30 AM »
New battery arrived today!
Glug glug glug
--Evan
1975 CB750K "Rhonda"
« Reply #19813 on: May 13, 2015, 08:16:30 AM »
Was building up my rebuilt engine and after closing the cases I found a hidden, broken bolt. So had to take it apart again and lost two days on the build. Deadline is getting tight, so not ideal. Hoping to pick it up today and build again tomorrow!
Past "bikes" ;)
Offline DaveBarbier
« Reply #19814 on: May 13, 2015, 01:15:40 PM »
Painted my kick stand. It's always been super rusty so now it's nice and clean. Didn't want to destroy the paint when putting on the spring so I used the coin method. Haven't done it before and haven't actually seen a picture on here of someone doing it. Used quarters and a dime. Worked like a charm!
1978 Honda CB550K
« Reply #19815 on: May 15, 2015, 01:10:41 PM »
Assembled my engine yesterday, but kept running into problems. Fitment issues with a few cases and the bolts that hold the cam towers down have all pulled all the threads out....one by one...spent a full day and all night (until 5:30 am) and the next day trying to get it done. Spent €1400,- on rebuilding, €700,- in parts and now it comes down to #$%*ty threads. They pulled with no effort and came out clean, top to bottom. Super gutted!!
PO has taken it apart too many times I guess. It is very worn and old according to the machine shop.
Past "bikes" ;)
Offline Tews19
  • I am no
« Reply #19816 on: May 15, 2015, 09:00:53 PM »
Stopped at the Temple.
« Reply #19817 on: May 16, 2015, 03:12:58 AM »
  That is a weak area around the cam towers especially if its been redone multiple times. You will be happy once those holes are reinforced and done correctly.
Offline Bailgang
  • Scott
  • Indiana
« Reply #19818 on: May 16, 2015, 03:24:33 AM »
I've been chasing down annoying oil leaks on my F2 and yesterday I pulled the cam and cam towers to replace the rubber pucks/discs underneath. Instead of using cheap aftermarket ones like those that were in it already I opted for genuine Honda rubber discs. I also checked out BrandEns leak free top end thread and used permatex hylomar sealant around those discs. It's too early to say if it's a long term fix but once i got it all together I took it out for a ride and so far so good.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
« Reply #19819 on: May 16, 2015, 10:25:21 AM »
You're on the right track!
Offline Sgt.Pinback
« Reply #19820 on: May 18, 2015, 01:52:19 PM »
Mounted old Giuliari seat
Doc, I love a motorcycle!
« Reply #19821 on: May 18, 2015, 01:56:44 PM »
looks perfect!  8)
Offline evanphi
  • Apparently I'm an
« Reply #19822 on: May 19, 2015, 11:20:36 AM »
Gorgeous!
--Evan
« Reply #19823 on: May 19, 2015, 11:56:33 AM »
Finally closed up my engine!
It was an ordeal with pulled threads and having to move it out of the shop before it was finished.
Put helicoils in all the holes for the cam towers after I pulled three and one already had a new one. Works like a charm!
I need to torque down the clutch basket, but need a tool for it. Probably sort that tomorrow.
Going in the frame tomorrow for wheel alignment and other small things. After that it's time to put it all together!
Past "bikes" ;)
« Reply #19824 on: May 19, 2015, 11:59:23 AM »
Love the color!
