Author Topic: What did you do to your bike today ?  (Read 3711549 times)
0 Members and 31 Guests are viewing this topic.
Offline Tews19
  • I am no
« Reply #19850 on: May 26, 2015, 07:25:05 AM »
I need a little helper like that.
+1  My daughter was just never that good at being a "son"!
That's funny. My oldest daughter is the girly type and my youngest is the tom boy..
1970 Honda CB750 survivor.
Offline lajos
« Reply #19851 on: May 26, 2015, 04:27:38 PM »
Thanks for the suggestion, I will post in the project build section.
'73 CB500 frame with '76 CB550 engine build in progress http://forums.sohc4.net/index.php/topic,148166.0.html
'09 Ducati M696
« Reply #19852 on: May 27, 2015, 02:15:47 PM »
Synched the carbs, Mikuni TMR32. Strange that a users guide how to adjust and do service are not supplied with expensive carbs. I get a guide when buying a toaster for $20US!
I managed to synch anyway after I have seen the construction and made a small test on carb 4. These carbs have nuts to be turned a little to adjust carb 1-3-4 to get same vacuum as fixed carb 2.
Offline Old Scrambler
« Reply #19853 on: May 30, 2015, 04:48:13 PM »
My original K3 got its HM341 pipes cleaned by hand so they are presentable next weekend at the ROCKER-BOX Moto-Fest.  I changed the jets from 120s to 115s because a friend said he could smell the fuel when following me. I knew the bike was a little rich but I wanted it that way for some sea-level riding. Now thinking the 115s will be good for moderate elevations. I also cleaned and oiled the K & N air-filter..........first time since it was installed in '75 ;D
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline CycleRanger
  • No comment about being an
« Reply #19854 on: May 30, 2015, 10:58:26 PM »
After walking away from my 95% rebuilt CJ360T two years ago I finally installed the Pamco ignition I bought a year ago and got it fired up and timed yesterday.
Been busy doing non-bike related things for a while but it's time to finish up some projects.
Like getting the XS650 going!
« Reply #19855 on: May 31, 2015, 12:43:08 AM »
Decided to upgrade the look of my bike with a better looking tank. I have used a black scratched set when tuning carbs, change cams etc when I do not want to scratch my latest tank setup in Candy Sapphie Blue from Yamiya750. I have an Ok setup in Freedom Green that I can use until I have done the final change on the bike.
The old repainted tank have some rust inside that I should have removed earlier. Now only 5L  vinegar, 12% concentration the weakest we have here unless the salad versions with half conc that cost much more. I might have bought 24% version for a quicker derust.
I'll buy additional 10-12L 12% vinegar today to speed up the derust. Let tank be positioned in different angles take longer time. I can hopefully reuse the vinegar in my avatar K6 tank that I plan to fix to OEM look.
12% solution work rather quick.
Offline MoMo
  • Ride like you're invisible
« Reply #19856 on: May 31, 2015, 01:23:35 AM »
cj360 was the stripped down cafe version back in 76 or so?  Always liked that little twin...Larry
Offline mcswny
« Reply #19857 on: May 31, 2015, 05:09:49 AM »
Started the fun process of switching out all the old bullets on my wiring harness to new vintage connections. man does it feel good!!!
1972 CB750 K2
1997 XR600r (street legal)
1975 XL250
198 XR80
« Reply #19858 on: May 31, 2015, 05:38:46 AM »
To the supemarket again for additional 13L vinegar, 12% version. Plundered the shelf with 12% vinegar ;D
Filled the tank completely. When done I'll store the vinegar in a 20L petrol can to be reused in another tank I have.
I guess it will be OK tomorrow afternoon 48 hours after first 5L went in.
    • http://forums.sohc4.net/index.php?PHPSESSID=te59d5nd6s0rrf3kcfdvu9ngu2&/topic,60973.0.html
« Reply #19859 on: May 31, 2015, 05:49:43 AM »
good you not have to get it at the  "monopolet"..vas there not a limit oif 2 bottels pr person number....
« Reply #19860 on: May 31, 2015, 07:16:26 AM »
  Your a vinegar HOARDER   ;D ;D   What the heck do people really do with that stuff  besides cleaning coffee pots ?
« Last Edit: May 31, 2015, 07:18:52 AM by ekpent »
« Reply #19861 on: May 31, 2015, 08:20:36 AM »
Pickling cucumbers, herring, salmon.... mmm
The gardening shops also sell vinegar for weed kill. 12 or 24% too.
« Reply #19862 on: May 31, 2015, 08:24:50 AM »
Monopolet...Systembolaget... no limits at all, amount as well as the price! No vinegar here, only alcohol.
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #19863 on: May 31, 2015, 01:31:53 PM »
Cleaned out garage to park the friends.
Gus, Austin, MN.
Current Bike:  75 750F
Past bikes: 76 750K - "Iowa Blue",78 750K Craigslist find - "Black Beth;" 77 CB750K Basketcase, with a 75K engine; 1970 Cb750 K1, "Rosa Luxembourg"
74 cb750, 75 cb550, 77 kawa 650, 81 virago 750, 83 virago 920, 80 Honda Twinstar 200, 71 Honda CT70, 1971 Honda CB750 Rat Project "Black Dahlia Bitsa"
Offline socal1200r
« Reply #19864 on: May 31, 2015, 05:00:30 PM »
Took her out on a ride from Newport News to Smithfield (est 1752) and back, about 120 miles.  Bike ran great, altho I'm a little concerned about pulling 5000 rpms at 60 mph.  But since that's half the way to redline, I guess that's okay.  I might have to check the rear sprocket, and see if it's the stock one, because that seems like a lot of rpms at 60 mph to me.  But then again, my other bikes are v-twins, which pull less rpms at 60 mph, so maybe it's okay...
Offline dusterdude
« Reply #19865 on: May 31, 2015, 05:55:05 PM »
Socal,which nn and smithfield?
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
« Reply #19866 on: June 01, 2015, 12:59:27 PM »
Bike transformed to  more OEM like than it has been since over 33 years. It is a K6-76 now look like a K2/K4-74 with the Freedom Green Metallic and K2 swing arm that CB750 guys will notice.
Offline InAquaVeritas
« Reply #19867 on: June 01, 2015, 03:03:55 PM »
Why not use HG rust converter? Works like a charm! Used it on a badly rusted oil tank and it cleaned it out in half an hour. One bottle might do a tank, but it's not super expensive.
Was a chromed tank as well and it didn't damage it at all. Probably will eat your paint if you don't rinse it right away.
Verzonden vanaf mijn iPhone met behulp van Tapatalk
Surf bum trying his hand at wrenching!
Past "bikes" ;)
1981 Honda MT 50cc - Torn apart, put back together and got run down on..
1994 Derby Senda R 50cc - Fell apart
2001 Derby Senda R 50cc - 13/45 changed to 15/70, hit 90 kph in under 150 meters! Undriveable fun!
1987 Suzuki GN250 - Sold
1977 Honda CB750 F1 - F2 engine, '05 ZX6R front end and wheels, '04 ZX6R shortened swing arm converted to twin shock. http://forums.sohc4.net/index.php?topic=133411.0
1987 Honda XR600 Supermoto conversion. CR250 forks and triple. SM wheels, discs front and back. Rebuilt engine. Loudest exhaust in the world: Leovinci X3
Offline socal1200r
« Reply #19868 on: June 01, 2015, 06:32:03 PM »
That would be the great commonwealth of Virginia...
« Reply #19869 on: June 02, 2015, 03:26:18 AM »
I have read so much about vinegar as a soft way to derust tanks inside without risk of eating thru the metal or harm the paint.
I got the idea on Saturday morning, took my car to the supermarket and bought 5L vinegar. Understood that I was too cheap and went for additional 13L on Sunday and filled tank completely. I verified tank volume when I could fill it with 17.5 bottles that most likely has a little extra in each 1L bottle (+ 3-4cl)
I have a complete tank clean/derust and sealing kit (Restom Super kit) that I planned to use. But I changed my mind when reading about eventual difficulties with sealers and the tank was rather good, no holes what I have seen (yet).
Vinegar in tank 48 hours in total (28 hours completely full). Saved vinegar in a spare plastic gas tank for my red avatar tank. Flushed tank with warm water plus brushed inside with a bottle brush.
After a few times with tap water, drained almost all water, filled with 2L conc. alcohol (for car windscreen washer tank) that diluted water to more alcohol than water. Drained tank again and direct 0.7L white spirit and 2 spoons of motor oil and shaked the tank. Out with that and in with 0.5 L gasoline and shaked the tank again and drained tank for last time.
Mounted a new fuel petcock, tank on bike and filled it with Shell V-power. Started bike and let it idle for 5-10 minutes. No signs of water in fuel..
« Last Edit: June 02, 2015, 03:29:45 AM by PeWe »
Offline Tews19
  • I am no
« Reply #19870 on: June 02, 2015, 05:44:14 AM »
Vinegar is awesome! Using a pressure washer to rinse the inside out makes the tank like new. I have done it many times. Not once have I had flash rusting.
Offline mcswny
« Reply #19871 on: June 02, 2015, 05:48:40 AM »
Never thought of incorporating a power washer. Genius.
1972 CB750 K2
1975 XL250
198 XR80
« Reply #19872 on: June 02, 2015, 06:59:06 AM »
Prepped and painted my headlight bracket for a 1975 F0. Total cost $1.00   :D
« Reply #19873 on: June 02, 2015, 07:03:21 AM »
be careful to not blow out a rust-weakened area/seam  :o
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #19874 on: June 02, 2015, 07:06:41 AM »
using a wide stream should help reduce pressure somewhat. Don't use a straight jet!
--Evan
1975 CB750K "Rhonda"
