Author Topic: What did you do to your bike today ?  (Read 3650603 times)
0 Members and 11 Guests are viewing this topic.
« Reply #19950 on: June 12, 2015, 05:20:15 PM »
+2 but I'm very partial to it   ;)
Offline MoMo
  • Ride like you're invisible
« Reply #19952 on: June 12, 2015, 07:58:40 PM »
what the heck.............................+4
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #19953 on: June 12, 2015, 08:24:31 PM »
Tapered steering bearings installed with the new forks today.  Rolled it out into the sunshine...realized I'm going to thank myself later if at this point I just pull a few more parts off, mask everything else, and rattle can the frame.
Offline MoMo
« Reply #19954 on: June 13, 2015, 04:31:46 AM »
I used Rustoleum oil based satin black and a quality natural bristle 1" flat brush and hand painted the frame on a Yammie DS6 I am restoring.  Worked real well -the paint levels out and in conjunction with the fine brush it looks good.  Saved an awful lot of time masking ...Larry
« Reply #19955 on: June 13, 2015, 04:39:45 AM »
Yep, I've decided that I'm only going to touch up the original paint on my Honda XR500R's black engine and red frame, the paint has worn thru where the PO's boots rubbed against it, (or where it flaked off the magnesium covers) and as it's not good painting weather here, so I'll just touch it up and maybe strip it completely come summer. (6 months away sadly..........) ;D
Offline MoMo
« Reply #19956 on: June 13, 2015, 05:09:57 AM »
How cold does it get down under?
Offline maduncle
  • Don't confuse me with a
« Reply #19957 on: June 13, 2015, 05:11:48 AM »
You have an XR500 now Terry? Cool.
CB750K2 (only slightly modified)
Offline maduncle
« Reply #19958 on: June 13, 2015, 05:13:44 AM »
Now that's a pretty personal question.
It was minus seven Celsius in Canberra last week, around Terry's and my patch it drops down to four degrees Celsius overnight, we are too low for snow where we are.
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
« Reply #19959 on: June 13, 2015, 09:11:23 PM »
Got my carbs back together after cleaning, with new o-rings and proper emulsion tubes from Harisuluv. Thanks again, James!  Installed on bike and went for a test ride with just a bench sync. Ran smoother and quieter than ever! However, #4 sounded a bit off. Will vacuum sync when weather cooperates and pop in some new plugs to see if that smoothes it out. Things are looking up!
Kyle
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
Offline Desert-SOHC
  • It's old
« Reply #19960 on: June 13, 2015, 09:34:01 PM »
Went out and picked up my new toy today and spent some $$$ ordering some parts to get her back on the road.  ;)
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
Offline Tetter
  • CB500F Café - CB750F K6
« Reply #19961 on: June 14, 2015, 01:41:19 AM »
Bought her a MotorMover, this wil save my back ! And she tucks away very close to the wall now.
Verzonden vanaf mijn iPhone met Tapatalk
« Last Edit: June 14, 2015, 01:43:04 AM by Tetter »
« Reply #19962 on: June 14, 2015, 05:56:21 AM »
Bike look great, Tetter.  Just curious, what part of the world are you in?
Offline Tetter
« Reply #19963 on: June 14, 2015, 06:30:28 AM »
I'm from The Netherlands. Tulips, Windmills, cheese and woooden shoes
« Last Edit: June 14, 2015, 09:37:36 AM by Tetter »
« Reply #19964 on: June 14, 2015, 06:31:32 AM »
Beautiful!  Do you really wear wooden shoes?!
Offline Ace
« Reply #19965 on: June 14, 2015, 07:10:00 AM »
Check the points gap, 2/3 need adjusting. Did this as per Hondaman's instructions in his book. Worked a treat. Then I hooked up the digital multimeter, put it around to Ohms to check the timing. This was done statically and when the reading on the meter when to 1 the point were open. 1/4 were good, slight adjustment for 2/3. Started the bike up, and checked timing again with timing light, spot on, checked full advance, all good there so job done. Bike sounded good. Now why is it that as the bike warms up the idle increases?
1971 CB750 K1 - Sold
1978 CB750 F2 Supersport - Sold
1981 CB900 Bol d'or - Sold
2006 CBR1100 XX Super Blackbird - Sold
« Reply #19966 on: June 14, 2015, 07:18:37 AM »
Take off the choke and turn out the idle set screw to lower the idle rpm after it warms up.
Offline Tews19
  • I am no
« Reply #19967 on: June 14, 2015, 07:42:01 AM »
Not today but yesterday. Here is my first Dyno run after the 605 build.
<iframe width="1280" height="720" src=" frameborder="0" allowfullscreen></iframe>
« Last Edit: June 14, 2015, 07:43:43 AM by Tews19 »
1970 Honda CB750 survivor.
Offline joeyvans
  • Definitely not a
« Reply #19968 on: June 14, 2015, 07:48:37 AM »
Sounds fantastic, Nick!
1976 CB550 K2
Offline 750cafe
« Reply #19969 on: June 14, 2015, 07:51:55 AM »
And???
Where is a copy of the results? (Dyno chart)
Eric
Is there anything more fun than riding? They are between your legs and are quiet when you turn them off.
Offline Tews19
  • I am no
« Reply #19970 on: June 14, 2015, 08:20:06 AM »
And???
Here you go... Chart
Eric
Offline DaveBarbier
« Reply #19971 on: June 14, 2015, 08:41:01 AM »
Awesome! I can't wait to dyno mine. A little behind compared to you, though. Starting the motor tear down today most likely. Bagging and tagging then finding the money for the 674 kit and finding a good machinist. Oh god this motivates me a lot!
1978 Honda CB550K
Offline Tews19
  • I am no
« Reply #19972 on: June 14, 2015, 08:44:47 AM »
Dave, send to Mrieck. Than there are no worries about quality of work.
Offline Tetter
« Reply #19973 on: June 14, 2015, 09:22:53 AM »
No. Not many people still own them. Those who do only use them around the house. Gardning, taking away the trash. Also more often in villages not in the main city's
« Reply #19974 on: June 14, 2015, 09:32:49 AM »
Sounds Dyno-Mite!   Makes me want a MotoGP pipe.
