Author Topic: What did you do to your bike today ?  (Read 3224594 times)
Offline Davez134
« Reply #20000 on: June 14, 2015, 06:04:03 PM »
Take off the choke and turn out the idle set screw to lower the idle rpm after it warms up.
Choke wasn't on and I know how to adjust the idle with the screw. My question was why does the idle increase when the engine gets warm?
How much is it increasing? Does idle hang up after opening and closing throttle? Or is it just a gradual rise, say a couple hundred rpms as bike is fully warm?
Offline Ace
« Reply #20001 on: June 15, 2015, 05:01:10 AM »
It increases over time 3-5 minutes, 500 to 800 rpm. Always has even after rebuilds of engine and carbs. Doesn't worry me a great deal, just curious to see if anyone else knows about it or has the same issue.
1971 CB750 K1 - Sold
1978 CB750 F2 Supersport - Sold
1981 CB900 Bol d'or - Sold
2006 CBR1100 XX Super Blackbird - Sold
Offline calj737
  • I refuse...
« Reply #20002 on: June 15, 2015, 05:12:43 AM »
You should be setting your idle screw after the engine gets hot. So let it warm up, rev up, then set it and see if it behaves going forward.
Offline Powderman
« Reply #20003 on: June 15, 2015, 04:09:12 PM »
I borrowed a starter from Bill Benton and put it to the motor. While it turns it better than mine it is still quite sluggish going through the cycles. I think I may have to hook the other battery to it to make it 24 volts.
On a side note, I've seen some bikes built and displayed in some strange places before. I built my Sportster first time in the living room of my 3rd floor apartment. Stood it on it's back wheel to roll it into the elevator to take it down. I was however surprised when I went into Bills house to see this beautiful CB750 dragster displayed on the dining room table. His house is the most awesome mini CB750 drag race museum I can imagine.
So I will be doing the few things needed to see if this will fire for the first time in 38 years.
We got on the subject of actually eating at the table and the first thing that came to mind was a motorcycle related setup and I had just the start for him. I am giving him my Wrenchware Tool Kit. I recommended some sort of brake rotor for a plate, maybe a cylinder or something for a glass.
Offline Tews19
  • I am no
« Reply #20004 on: June 15, 2015, 07:27:14 PM »
resync'd the carbs on my 550 for the dyno run tomorrow.
1970 Honda CB750 survivor.
Offline Desert-SOHC
  • It's old
« Reply #20005 on: June 15, 2015, 09:41:51 PM »
Walked past it a few times.................still waiting parts
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
« Reply #20006 on: June 16, 2015, 05:02:18 AM »
Ha ha -  my wife puts up with quite a bit but I don't think a dragster on the dining table is going to fly well around here  ;D  ;D   What are the museum hours Bill and do you charge members for admission   ;)  Can wait to see the treatment on the toilet,  King and Queen seat ??
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #20007 on: June 16, 2015, 05:34:01 AM »
I'd visit that museum!
I rode my bike to work yesterday, for Ride Your Motorcycle to Work day. I live less than a KM from work (I normally walk), so I took an EXTRA long route. Showed off for some kids on a school bus.
--Evan
1975 CB750K "Rhonda"
« Reply #20008 on: June 16, 2015, 09:21:54 PM »
Bchaley40 came over and we did the 3k maintenance on his (free to him) K8.  Took it for a spin before loading it back up.  Needs some fine carb tuning, but it was running quite well.
Offline Tews19
  • I am no
« Reply #20009 on: June 17, 2015, 06:00:34 AM »
Not my CB on the Dyno but my new to me VFR. Sorry guys for the shameless video plug of the run..
Offline evanphi
  • Apparently I'm an
« Reply #20010 on: June 17, 2015, 06:06:00 AM »
New sprockets came by post! These are the sprocket part numbers for JT Sprockets if you're ever ordering stock gearing for a CB750.
--Evan
« Reply #20011 on: June 17, 2015, 06:08:37 AM »
Got a print out to post?
« Reply #20012 on: June 17, 2015, 06:09:19 AM »
Assembled countershaft and bought gaskacinch on ebay.
Offline evanphi
  • Apparently I'm an
« Reply #20013 on: June 17, 2015, 06:10:04 AM »
What were your numbers?!
I need to find a dyno around here...
--Evan
Offline Tews19
  • I am no
« Reply #20014 on: June 17, 2015, 06:32:56 AM »
97. on all 3 pulls.
Offline evanphi
  • Apparently I'm an
« Reply #20015 on: June 17, 2015, 06:55:36 AM »
I did a group ride a few weekends ago, and rode with a guy on an '87 VFR750 in red, with the white wheels, and dual undertail exhaust. BEAUTIFUL bike.
--Evan
« Reply #20016 on: June 17, 2015, 10:01:02 AM »
Attempted to fit main bearings on the 1000 engine. 4 greens and 1 brown comparing the original letters and a micrometer. Neither worked out as planned  ::) All too loose. Ordered a full set of browns and blacks from Yamiya. In stock and about 25% less than US plus 4 day shipping. Back to the drawing board.
« Reply #20017 on: June 17, 2015, 12:35:00 PM »
Fixed my clutch lever functionality since the adjuster screw had seized, not possible to adjust or remove. Got fresh parts from a CB750 collector nearby. No need to wait for eBay shipping.
Sudden clutch problem when riding gave me the idea to let the Honda tool kit to move in where it belongs, allen tools need to be added, 4,5,6mm.
Hondaman ignition module to move out from tool compartment. Space enough on top of battery.
« Reply #20018 on: June 17, 2015, 02:21:55 PM »
97. on all 3 pulls.
Thats impressive!  Makes your hot rod 605 feel like a slug I bet.
Offline Tews19
  • I am no
« Reply #20019 on: June 17, 2015, 02:44:05 PM »
97. on all 3 pulls.
Very much
Offline jonda500
« Reply #20020 on: June 17, 2015, 09:48:49 PM »
Dragged the trusty ole kirby out to the flooding garage, vacuumed the water out from around the bikes and shuffled them around to slightly drier areas of the cement floor which currently has a natural spring flowing out of the cracks in the cement..... hope it stops raining soon!
Note- whoever built the garage broke lots of building rules including a golden rule that I have about building sheds- never allow any part of the cement slab to end up being lower than the original ground level!!
« Last Edit: June 17, 2015, 10:00:04 PM by jonda500 »
A starter clutch thread:
Offline evanphi
  • Apparently I'm an
« Reply #20021 on: June 18, 2015, 08:27:54 AM »
Got a "bearing puller" from Canadian Tire...
5/8" sleeved concrete anchor! Going to open it up on the old bearing, and tap them out from the inside. Should save having to mess around with the internal spacer.
--Evan
« Reply #20022 on: June 18, 2015, 08:54:49 AM »
Good luck.
I went that route, once. Couldnt get enough purchase on the inner race to get it to budge.
A BFH and a punch were much more effective  ;D
Offline evanphi
  • Apparently I'm an
« Reply #20023 on: June 18, 2015, 09:18:19 AM »
Good luck.
Yes that will be my alternative solution. ;D I went around to a bunch of stores to get a nice big one. Most had only 1/2" anchors. Hopefully this does the trick.
--Evan
Offline DaveBarbier
« Reply #20024 on: June 20, 2015, 09:08:10 PM »
Just tried to stop a leak at the brake splitter. We'll see if it's dry tomorrow...but in the meantime, I replaced the CV axle in my Hyundai. I only say this here because I made a vice grip slide hammer. Used a 650 motor mount bolt as the slide and alternator rotor as the hammer. Worked like a charm! I removed most of the axle first then used the slide hammer for the cup and spindle that goes into the tranny.
1978 Honda CB550K
