Author Topic: What did you do to your bike today ?  (Read 3752737 times)
« Reply #20175 on: July 16, 2015, 04:28:33 AM »
  Think we need to call you " The deer whisperer", you seem to have a lot of contact with them in your area.  I had to brake for one recently also while up north.
« Reply #20176 on: July 16, 2015, 05:37:08 AM »
I see a lot of deer around here on my sunset cruises, seen quite a few fawns the last two weeks.
Offline WhyNot2
  • I'm finally an
« Reply #20177 on: July 16, 2015, 09:57:20 AM »
I see deer every morning on the way in to work.......5:00 am...............been blessed not to have them run in front of me....!
« Reply #20178 on: July 16, 2015, 10:55:47 AM »
I have heard that deer is tasty!
I did another test run today between the heavy showers, now with larger pilot jets.
Raised the needles when back home again (did all 4 within 20 minutes. Tank-on-off 10 minutes + all needles in another 10). The needles in Mikuni TMR take affect from low throttle lift DIRECT after idle. I'll hopefully verify tomorrow that the carbs finally are almost perfect :)
« Reply #20179 on: July 16, 2015, 11:06:43 AM »
Nothing, YET.... chomping at the bit!!
Honda called. My oil orifice jet o-rings came in. Time to finish the engine.My Avons came in. Time to get my Lesters set up. My frame has had Gordons Kit installed and ready to pick up.
Sounds like I can start putting a bike, er my 1000 Hot Rod together.
Offline mkoski
« Reply #20180 on: July 16, 2015, 12:56:31 PM »
I enjoyed the sweet music of my engines freshly-restored top-end!
Just kidding.  :'(
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #20181 on: July 16, 2015, 06:24:21 PM »
Just kidding.  :'(
Get those tappet covers off and see what's flappin'!
--Evan
1975 CB750K "Rhonda"
Offline evanphi
  • Apparently I'm an
« Reply #20182 on: July 16, 2015, 06:26:53 PM »
Put in new stainless socket head bolts for chainguard (M6x14) and bar clamps (M8x40).
--Evan
Offline fitzmotor
« Reply #20183 on: July 16, 2015, 09:30:45 PM »
Disassembled some stock forks, cleaned and installed new fork seals, they are to replace the bent chopper forks that came on the bike.
Offline evanphi
  • Apparently I'm an
« Reply #20184 on: July 17, 2015, 10:13:13 AM »
Re-set my timing statically, synced my carbs, then took it for a 4-hour run. Beautiful day!
--Evan
« Reply #20185 on: July 18, 2015, 01:53:38 AM »
Fitted the new back wheel that Cal sent me, to my sweet ride........... ;D
The massive torque of my twin engined bike destroyed the spokes on my old one, so hopefully the thicker spokes and stiffer, wider rim will stop the new wheel squirming under it's awesome power.
Tomorrow, we ride! ;D
Offline Sgt.Pinback
« Reply #20186 on: July 18, 2015, 05:34:46 AM »
Great bike. Everything selfmade?
Got my old 750 KO doublecut-fender back from de-rusting and re-chromeing. Still some dents but thats OK to me. Dont have a living room bike.
Next, I will put some silver paint inside. Bought "hammerite".
« Last Edit: July 18, 2015, 02:06:27 PM by Sgt.Pinback »
Doc, I love a motorcycle!
« Reply #20187 on: July 18, 2015, 05:36:26 AM »
Sounds like a real "widowmaker"
Offline Jdickinson
« Reply #20188 on: July 18, 2015, 01:48:57 PM »
Switched out my bars
1973 CB500 Newbie
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
« Reply #20189 on: July 18, 2015, 01:53:21 PM »
Love the black bars! They look like superbike profile. Where did you get them and were they pre-drilled?
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
Offline Jdickinson
« Reply #20190 on: July 18, 2015, 02:01:35 PM »
Thanks!
They were rusty chrome when I got them...the guy I bought the bike from had them laying around his shop so I have no idea what they are.
I painted them and one side was pre-drilled in the right position, the other side I needed to drill through the bottom to bring the wires down for the horn and blinkers.
It went really smoothly though!
J
1973 CB500 Newbie
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #20191 on: July 18, 2015, 02:23:32 PM »
Took it around the block. When I got back there was another 100 miles on the odometer.  :o
It was a big block!  8)
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline pickingupdimes
« Reply #20192 on: July 18, 2015, 05:46:05 PM »
I stared at the pieces scattered about and wondered what to do next.
1978 CB750K8
1981 GS550L
« Reply #20193 on: July 18, 2015, 05:48:38 PM »
Break out the paint stripper!
« Reply #20194 on: July 18, 2015, 05:55:42 PM »
Thanks mate, yep, I built the layshaft assembly using a CB750 front axle as the layshaft itself, and somehow it's managed to handle the awesome power of those two stroke power-houses. ;D
Re: your fender, make sure you scrub all the chemicals from underneath before you paint it, chrome platers are usually pretty lazy about doing this, and that's half the reason why they start to rust underneath so early after plating. Cheers, Terry. ;D
Ha ha, ironically my wife asked me this morning if the brakes on it worked well, and I said, "Brakes? What Brakes?". ;D
« Reply #20195 on: July 18, 2015, 06:19:40 PM »
And some matches! ;D
Offline Ace
« Reply #20196 on: July 18, 2015, 10:52:02 PM »
Decided to sync the carbs. Picture shows what they were like before sync. Got caught up in the moment of getting better than the photo and then forgot to take the after sync photo. Was rushed for time as well with the wife on her way home. Needless to say the bike is running great.
1971 CB750 K1 - Sold
1978 CB750 F2 Supersport - Sold
1981 CB900 Bol d'or - Sold
2006 CBR1100 XX Super Blackbird - Sold
« Reply #20197 on: July 18, 2015, 11:25:16 PM »
Jesus dude, why'd you even #$%* wit it?
Offline Sgt.Pinback
« Reply #20198 on: July 18, 2015, 11:44:40 PM »
Thanks for the hint, Terry!
« Reply #20199 on: July 19, 2015, 12:07:25 AM »
Carb rather OK before sync.
Mine were worse. My ears verified the instrument.
