Un-screwed some PO wiring...
Here we see the wiring from the PO, with the main ground wire to the front half of the bike broken off. See previous post. Repair is below it.
PO had the frame powder coated before their rebuild. How nice. Too bad they didn't do any proper wiring... So I sanded back the PC and ran this wire up to where the others were attached. Also applied some dielectric grease to protect the bare metal.
Couple snips here... a few crimps there...
The three on the right are for the tail lights, regulator, and rectifier.
Applied a little heat for some shrinkage... (very high quality automotive heat shrink with glue)
TA DA! Factory-correct harness ground! Hooray!
