Author Topic: What did you do to your bike today ?  (Read 3271932 times)
Offline jimv50
« Reply #20650 on: October 25, 2015, 01:48:52 PM »
We get our bags checked by Customs here with X-ray machine and hand searched if necessary before we even make our way to the airport. Last summer I went home with four ceramic knives and they didn't stop me in Japan, Dubai or Ireland.
As long as it's not drugs, guns, large knives, porn or large amounts of tobacco or alcohol they let you through.
"There's no way to rule innocent men. The only power government has is the power to crack down on criminals. When there aren't enough criminals, one makes them. One declares so many things to be a crime that it becomes impossible for men to live without breaking laws." -Ayn Rand
Offline Desert-SOHC
  • It's old
« Reply #20651 on: October 25, 2015, 02:39:29 PM »
Put the "best" of my stock taillight stuff together and put it back on till I can come up with a better taillight/directional idea. Changed the gauges, scored a complete dash for cheap, and I can say that my old ones DID NOT work very well as compared to these. Went for a nice blast and filled her up with fresh gas for the week. My petcock isn't flowing like it should.....when I'm under 2/3 of a tank she wont go above 80mph, acts like she is running out of gas. I was a beautiful day
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
« Reply #20652 on: October 25, 2015, 03:36:34 PM »
Mock up with the replacement swing arm. It all started with a 78 K engine in a 75 frame. 10mm offset output shaft and a 530 conversion. Had to get the chain in alignment. First was the late model sprocket carrier. No clearance with the 75 swing arm with the 10mm offset. Looks like the 77/78 F swing arm is the ticket. Next is the 10mm offset shock mount adapter that has been fabricated and a 77/78 F chain guard. Gotta also get a 77/78 F axle that is also 10mm longer.
PROGRESS and light at the end of the tunnel.
Order some more bits and pieces. Rebuild the rear caliper. Powder coater trip. Install my new Slingshot brake hoses, ETC. Fire this 1000cc #$%* up before long.
Offline BPellerine
« Reply #20653 on: October 25, 2015, 04:37:20 PM »
1978 CB 750K ard and webers
another anfob
Offline maduncle
  • Don't confuse me with a
« Reply #20654 on: October 26, 2015, 04:11:12 AM »
Jeez - I might as well give up flying then.
CB750K2 (only slightly modified)
Offline maduncle
« Reply #20655 on: October 26, 2015, 04:12:37 AM »
This is good.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #20656 on: October 26, 2015, 06:11:02 AM »
Purchased some oil to change out before laying up for the winter. Still  a few weeks left yet!
--Evan
1975 CB750K "Rhonda"
Offline briancwynn
  • If created then it is for a purpose!
« Reply #20657 on: October 26, 2015, 02:01:29 PM »
I added oil to the beast and I am wondering if I should add Chrome or Black headers.  What say you.  Wrap is also an option.
Honda CB750 1978 K
Stock Carbs w/ Pods
125 main jets, stock slow, and 2 shims on the needle (equal to about raising it one clip)
M-unit
Bike broken down to bare bones and slowly put back together (except for the engine)
« Reply #20658 on: October 26, 2015, 02:04:27 PM »
Black  8)
A cheap header, saved from the junk pile, wrapped and VHT'd black would look good.
Just find a better looking can than a MAC  ;)
"This is my CB. There are many like it, but this one is mineā€¦"
« Reply #20659 on: October 26, 2015, 03:14:51 PM »
Black  8)
+1 a nice black header [not wrapped] with a Cone can.
I have a nice header for sale if you are looking.
Offline millla03
« Reply #20660 on: October 26, 2015, 04:25:24 PM »
Rolled it over 30,000 miles!
Luke
72 Honda CB750 K2
78 BMW R100/7
83 Honda Nighthawk 650
07 Honda Rebel 250
Offline Pat_at_APE
    • APE Race Parts
« Reply #20661 on: October 27, 2015, 04:07:35 PM »
Took this image just now.....  I'm almost there too!!!!!!
Pat at APE
Offline Oz350Four
  • Keep yer stick on the ice...!!!
« Reply #20662 on: November 01, 2015, 01:54:11 AM »
Started on the forks to get the bottom cases ready to go to the powder coater with all the other parts.
So I got the forks out of the triple tree.  Both of them had heaps of rust up under the shrouds and covers (ears).  I used some very fine wet n' dry to get it all off followed by some cutting compound.
Next were the chrome doohickies... man what a pain...!!! but slowly slowly catchy monkey tapping all around gently and done.  Decided to polish the fork ends (the bits that hold the axle on).
"Me speed officer...?? never..!!!"
1972 CB350F Four - Project Ol' Red (current)
2007 Harley Davidson Softail Deuce - Sold to start this project.
Offline CycleRanger
  • No comment about being an
« Reply #20663 on: November 02, 2015, 03:53:56 PM »
After cleaning out the glass beads I loaded the blasting cabinet with soda.
It was a little chunky so I did a little chopping...  ::)
Cleaned up a carb body for the CJ360 to replace the one that broke when I knocked the carbs off the bench!
 >:( :P
Offline millla03
« Reply #20664 on: November 05, 2015, 06:50:57 PM »
Pat at APE
Nice, Pat! I know there are bikes on here with a lot more miles but it's a cool watch all the numbers roll over.
Luke
72 Honda CB750 K2
78 BMW R100/7
07 Honda Rebel 250
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
« Reply #20665 on: November 10, 2015, 08:08:53 AM »
Replaced stock coils with Dyna 5 ohm coils (DC8-1) & Dyna copper core wires with NGK 5k ohm caps  to complete my ignition upgrade... Pamco was installed about a month ago. Hoping this corrects my weak spark on #4 so we can burn out some of the carbon buildup. If this doesn't fix my #4 issue, I'm probably looking at a top end refresh. Ugh! Hope to test run later today, then if weather cooperates..... get out for a long, spirited ride this weekend.... then park it for the winter.
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
« Reply #20666 on: November 10, 2015, 09:14:02 AM »
 >:( :P
I was in H.F. the other day and noticed they have an adapter for soda. Are you using that? Hoping for some nice after pictures! I have a set of Webers that could use a soda blasting.
Sounds like #4 is/was the wire (did you swap out #4 with #1?), the plug cap (previous comment), the plug or the carb since it is only on one cylinder.
Offline joeyvans
  • Definitely not a
« Reply #20667 on: November 10, 2015, 11:52:30 AM »
Jerry, I had intended to swap the 1 & 4 wires to see if I could get some soot on the #1 plug and confirm the wire as the problem, but the wires had been snipped too far by the PO.  They weren't long enough to swap.  Also, because I couldn't snip much more of the wires, I just wanted to start fresh anyways.  But I agree.... I would have been nice to confirm a bad wire before upgrading.
I am ditching out of work in a half hour to do a little shakedown on the new coils/wires.  Fingers crossed that I get some consistent readings now.  It's gonna work!!!!!
1976 CB550 K2
Offline CycleRanger
« Reply #20668 on: November 10, 2015, 03:14:26 PM »
 >:( :P
No I don't use any adapter, I just install a smaller orifice.  Seems to work ok.  I got the CJ360 carbs back together. I guess I could take a photo.
But in the meantime here's the carbs from the 750K5 I did a couple of years ago. :)
« Reply #20669 on: November 10, 2015, 04:53:46 PM »
I picked up a fresh box of 80 grit glass bead since mine is getting very difficult to blast assuming it's due to age and maybe 2000 grit now LOL. I looked at the orifice but wasn't sure how to remove it for replacement. Ideas??
I may try that conversion kit for soda when it comes time to clean up the Webers.
Those carbs look nice plus the soda is water soluble leaving no engine damaging grit.
« Reply #20670 on: November 10, 2015, 07:12:57 PM »
I bought another one. BMW R1100GS. Pics when I pick it up on the weekend. ;D
Offline CycleRanger
« Reply #20671 on: November 10, 2015, 08:36:12 PM »
My gun uses replaceable ceramic tips.  Yes, the soda works great on the pot metal.  Just make sure you have enough pressure. I run at ~90psi / ~15CFM
    • http://forums.sohc4.net/index.php?PHPSESSID=ujpjf0hfrbri35bcolnlbbadh5&/topic,60973.0.html
« Reply #20672 on: November 11, 2015, 03:26:18 AM »
is it a runner.?.you..goes to summer...so be ready for the road.
..ve are going for snow my insurence ends at the 15 this month...then it 4 month Winter sleep....and fixing bikes inside in the shop/cave...thinking of a vinter bike ....
« Last Edit: November 11, 2015, 07:54:43 AM by strynboen »
Offline CycleRanger
« Reply #20673 on: November 11, 2015, 04:25:41 AM »
Go for it! ;D
Offline 72 yellow
« Reply #20674 on: November 11, 2015, 06:40:13 AM »
Pulled the Kerker off and dropped the oil pan.  No strange objects lurking in the bottom.  Going to pull the pump and replace the O rings.  Neighbor and I built a wooden stand to run the bike up on.  What a relief on my old back.  No more laying on the floor.  Should have done this years ago.
