Author Topic: What did you do to your bike today ?  (Read 3277185 times)
Offline nathanong87
« Reply #20650 on: November 12, 2015, 07:47:49 AM »
went for a ride
« Reply #20651 on: November 12, 2015, 08:10:02 AM »
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
« Reply #20652 on: November 13, 2015, 06:30:39 AM »
My soldered in starter button (momentary switch) hasn't been working for the last couple weeks.  The headlight would go out when the button was pushed, but the solenoid wasn't clicking. I started with the connections in the headlight bucket... cleaned them up and added some dielectric grease before reconnecting.  That didn't do the trick.  Pulled the solenoid out, checked resistance... good there.  Hooked up jumper wires from the solenoid to the battery (per the Honda service manual) and it did click.  So, I cleaned up all the connections to the solenoid and tried again.  Lo and behold it worked.  Hopefully, this issue doesn't become intermittent.
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
Offline joeyvans
  • Definitely not a
« Reply #20653 on: November 13, 2015, 06:57:08 AM »
You want your headlight to be deactivated during startup as it reduces the draw on the battery.
Correct.... That was working as it should. It was being deactivated when I hit my button, which is why I didn't start my troubleshooting in the hand controls.
1976 CB550 K2
Offline oldhatt45
« Reply #20654 on: November 13, 2015, 07:35:04 AM »
joeyvans,
Now if you want to keep it that way (Start Button working) I would like to suggest that you do the Hondaman Relay mods.  At least for the Start Button (and maybe the headlight ).
I have attached the schematics for the 750 K6 that show the wiring mods.
Charlie
Offline joeyvans
  • Definitely not a
« Reply #20655 on: November 13, 2015, 08:32:47 AM »
joeyvans,
Charlie
Thanks for the info, Charlie! I always forget to check Hondaman's online shop for goodies. My original starter button exploded when I switched handlebars last winter, so I have replaced it with a RadioShack momentary push button in the same housing. Works great, but probably isn't rated for enough amperage. I mainly use the kick start, but this relay should help. - Kyle
1976 CB550 K2
Offline oldhatt45
« Reply #20656 on: November 13, 2015, 09:14:22 AM »
Kyle,
Glad I could help!
I also made up a schematic for the CB750 K1-4 that does not use the 2 position Start button (the one that disconnects the headlight when starting).  I am attaching that one to this message, just in case anyone else needs it.  :)
Charlie
    • http://forums.sohc4.net/index.php?PHPSESSID=mbb8e75s8kf1c98ommd4mnr3d5&/topic,60973.0.html
« Reply #20657 on: November 13, 2015, 09:24:04 AM »
send..some of my bikes to Winter sleep..to get some Space to make the cbx ready for spring..its hard to home 8 bikes
Offline WhyNot2
  • I'm finally an
« Reply #20658 on: November 13, 2015, 04:33:11 PM »
« Reply #20659 on: November 13, 2015, 08:39:31 PM »
I bought another one. BMW R1100GS. Pics when I pick it up on the weekend. ;D
is it a runner.?.you..goes to summer...so be ready for the road.
..ve are going for snow my insurence ends at the 15 this month...then it 4 month Winter sleep....and fixing bikes inside in the shop/cave...thinking of a vinter bike ....
G'Day Mate, yep, it's a runner, registered until the end of January, has a full "Staintune" system, (worlds best stainless steel exhaust) the ECU's been "chipped", it's got a really cool Scott's steering damper, etc. The owner did a lot of dirt and sand riding, but has given up motorcycles, as he's getting a bit old. I hope I never get that old.
You're right, the weather is nice and warm in the cooler southern states of Oz right now, but hopefully I'll be able to ride the big BMW all year round. Cheers, Terry. ;D
Offline edwardmorris
  • Youngish
« Reply #20660 on: November 15, 2015, 03:00:43 PM »
Went past 1000 miles after the frame up rebuild!
Offline joeyvans
  • Definitely not a
« Reply #20661 on: November 16, 2015, 09:17:47 AM »
Yesterday... Put the 550 away for the year, as we probably had our final day in the upper 50's. On the ride to my father in law's heated shop, I figured I would do a quick high speed run on a less travelled highway. 99.6 mph on the GPS before I saw  a car in the distance. She'll do the ton, as I think there was a little bit left. I was pleased at the high speed stability. No wobble... just tracked perfectly. Great final ride of the year. Should be able to enjoy the bike much more next year, as my tuning is finally spot on.  - Kyle
1976 CB550 K2
« Reply #20662 on: November 16, 2015, 10:56:45 AM »
thek your spedo with gps. ???
after easy doing the ton ,,i faund it shov 10 kmt to fast..so im only drove 150 kmt..not 160....so got it pressed to 170 to be sure..no more left.
« Last Edit: November 16, 2015, 10:58:45 AM by strynboen »
Offline joeyvans
  • Definitely not a
« Reply #20663 on: November 16, 2015, 11:39:51 AM »
The 99.6 mph was taken from the Garmin GPS max speed. My speedo runs fast too. I need to check my max throttle stop screw next time the carbs are off to be sure I am getting full throttle at full twist. I neglected that last time.
1976 CB550 K2
« Reply #20664 on: November 16, 2015, 11:43:02 AM »
any ideas to korrerkt auor spedos...tires are often to big.(.i have a bicykel digtal spedo for refarense now)
Offline flatlander
« Reply #20665 on: November 16, 2015, 01:07:01 PM »
mount a GPS  ;)
« Reply #20666 on: November 17, 2015, 02:49:19 AM »
Well I finished work, then drove back to my hotel so I could get changed out of my business clothes and into jeans and a polo shirt, so I could take my new (to me) BMW R1100GS for a ride to Cooma, 80 miles away, for dinner.
The Monaro Highway is a great road with heaps of fast sweepers through the hills, and once I got out of Canberra there was very little in the way of traffic, so apart from the odd errant Kangaroo, very little danger. I had a great meal and a couple of icy cold beers at a Chinese restaurant in Cooma, then flew back to Canberra at indecent speeds, arriving around 8pm. All in all, a great evening! ;D
« Reply #20667 on: November 17, 2015, 02:50:30 AM »
Offline dhall57
« Reply #20668 on: November 17, 2015, 03:04:14 AM »
Hey Terry. The styling on that Bimmer is well, a little different and I'll just leave it at that ;D  but Im sure it drive's and rides like a dream.
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
« Reply #20669 on: November 17, 2015, 03:27:03 AM »
Ha ha, you're absolutely correct Dwight, it's no show pony, but it's a brilliant bike to ride, and I was thinking (as you do) that if I had to get rid of my other 7 bikes and only keep this one, I'd still be happy, it just does everything they do so well, but better. Cheers, Terry. ;D
Offline dhall57
« Reply #20670 on: November 17, 2015, 03:37:59 AM »
How does it compare to the ole Wang?
1970 CB750KO
1974 CB750K4
1976 CB750K6
1977 GL1000
Offline nathanong87
« Reply #20672 on: November 17, 2015, 07:42:39 AM »
that is a ferdamt kool bike...like the orginal boxer idea..not that airkon kooling pump..you have on the other bike
Offline Radam
  • taco racer
« Reply #20673 on: November 17, 2015, 09:05:22 AM »
Terry, I just sold my r1100gs. It was a great bike! Goes real well off the sealed road too. I sold it because we were going to buy a house, but the house got sold out from under us. Now I have to get my cb500 together. Hope you enjoy yours! You better hold on to your "wang" for when you're too old to throw your leg over the gs.  ;D
Offline gloken
« Reply #20674 on: November 17, 2015, 10:02:30 AM »
Tore apart and rebuilt the forks, and polished up the fenders.
Big learning experience for me, but they had leaky seals, and it was time to learn.
I also learned that Honda will actually ship me some parts for a 77, including all of the gaskets, and the rubber spacers for the fender! Nice surprise there.
'77 Honda CB550K
'84 Honda V45 Sabre 750
