Author Topic: What did you do to your bike today ?  (Read 3769008 times)
0 Members and 13 Guests are viewing this topic.
Offline edwardmorris
  • Youngish
« Reply #21025 on: February 10, 2016, 08:29:23 PM »
I had to wait till I got home to play the vid with sound, very very nice! Congratulations Jerry!
Offline mrbreeze
  • Not your average
« Reply #21026 on: February 10, 2016, 09:33:38 PM »
That sounded great for a first start Jerry. Settled in to an acceptable idle. I've always had to fiddle with things on mine to get a good idle on first go. I didn't realize you had 2 F's. I thought you just had one with 3 different colored gas tanks!!
MEMBER # 257
« Reply #21027 on: February 10, 2016, 10:23:52 PM »
Sounds very good! Which cam?
1000cc sounds tempting. I have rods for it..... sleeves have 74.5mm OD into the case? Case bore is 75mm?
First step is tp prepare the case so a BIG bore cyl can be fitted when found.
« Last Edit: February 11, 2016, 10:36:00 AM by PeWe »
« Reply #21028 on: February 10, 2016, 10:32:54 PM »
Fred, this one came from all the late night EBay ramblings of a unhappily married father and his computer escape  ;D ;)  I began collecting parts after I scored the unobtainable (at the time) big bore 900 Henry Abe kit one late night session. Told myself I always wanted to do it up right just one time after all those years with the original. It snowballed from there. 5+ years. 9 countries. NOS, discontinued, bargains, etc. I picked everything I could from Honda. $$, $$, mas dinero. When it slowed to a trickle I began the journey. As a matter of fact I have 3 MORE nos parts parts to install on the original during the next week. I have shelves with a box for EVERY page of the parts manual in the basement. After the divorce I decided that a change in life is long overdue. The basement has never been finished and that is becoming a good investment in equity now. The new parts slowly turned into used parts into the boxes as I began the restomod and I needed to do something with all of them. Most were very useable just slightly used after 40 years. I picked a titled frame and engine. This is what you now see  :) If you want I can install the blue or candy presto red body if we get boring but that presto stuff is sacrilege to the 75!!
Thanks to all for the nice comments.
« Reply #21029 on: February 10, 2016, 10:39:04 PM »
1000cc sounds attempting. I have rods for it..... sleeves have 74.5mm OD into the case? Case bore is 75mm?
First step is to prepare the case so a BIG bore cyl can be fitted when found.
Same cam I believe you are experimenting with, DP315  ;D  I did not have this crank cut but I did install a RC lightened rotor to help make up the difference. It has the Crower rods I got Jay to have a run made of as well as his 1000 kit. He did the cylinder work and opening the case half. Heavy rods but really sweet. Stage III head. Going for a torque street monster theme here as compared to the other bike with the stage IV head, 900, Carrillos, 125-75, and lightened crank with stock rotor.
Just wish I knew WTF I am doing  ;) ;) ;D
« Reply #21030 on: February 11, 2016, 01:44:02 AM »
I hoped you used the DP315 since I had vague memories about your modifications and RC/DP315 cam.
125-75 will give more hp than DP315?
- Do you know the diameter of the case bore to fit the 1000cc kit?
I look forward to mount mine since the idle sounds good when hearing your video. APE ultra crank might affect the idle. I suppose that carbs and ignition must be perfectly set with lighter crank.
I'm still taking things apart. Drained oil yesterday. Oil pump with new gaskets got new countersunk bolts with allen heads.
Will remove clutch basket after work so the remaining engine will be easier to pull out from frame. Head, cyl and pistons are removed.
About Honda parts and upgrades to a CB750... I have got bitten by that nice bug too!
Before buying parts when needed, now buy parts to have spares home and not waste time waiting for parts. Buy NOS while still available. I should have bought mored Tsubaki HD cam chains a few years ago wheil still sold everywhere for $40US.
I got a NOS Front fender from David Silver a few days ago when the price was right, fender on bike is old and from a K2, nuts instead of rivited.
Now looking for rear fender. My K6 has not the US style of rear lamp, it's the K0-K1 version. Closest Rear fender is K1.
I have an old cylinder with tapered sleeves, 67.5mm bore that are scratched, sleeves must be replaced. Cylinder is an old version not made for the  8 large o-rings for oil transport. Oil leak will happen easier,right? New sleeves and 67mm pistons can be something for future or finding a 1000cc cylinder with freash bores + pistons (that need case bore).  I have a working 836 setup and the $$$ are flowing as it is...
But, I know myself...I will soon think about 1000cc most of the time, when going to sleep and when wake up... I have to get it to get  piece in my mind. :)
« Last Edit: February 11, 2016, 01:46:47 AM by PeWe »
« Reply #21031 on: February 11, 2016, 02:29:42 AM »
Well CB750 parts are getting way harder to find, and awfully expensive. Long gone are the days where you could buy a rideable CB750 for under a dollar a cc. Anyway, when I was scanning Gumtree (Craigslist) I found a guy selling a couple of CB750 engines.
The seller is a very interesting guy, he has around 80 bikes, but most are British, with a few Jap bikes that he's picked up along the way. He's pretty much retired, but invited me over to his shop, which is full of Classic Aussie Brit and American cars, and lots of (mostly British) bikes. It's always a good sign when you see that his "Daily Driver" is a very rare 1961 Jag E Type convertible, that was a race car back in the day:
Then there was just mechanical eye candy for as far as the eye could see:
But of course I didn't come here to admire Peter's collection, I needed more CB750 parts:
There was a complete F2 engine that had been restored mechanically, in anticipation of going into a Seeley, but the owner found a hotrod K engine instead, and a complete, "never been apart" F engine that had powered the Seeley for the previous 40 years. No busted fins or grazed cases, and I think I'll shove it in my K1 and just ride it for awhile. Not sure about what to do with the F2 engine, but parts are always nice to have..........
I know Carpy (Crappy) lived in Melbourne for a few years, I didn't know that he'd spent time in Canberra:
No busted fins, clean as a whistle, with re-seated valves and surface ground for a nice seal:
Sadly bargains are hard to find nowadays, it wasn't cheap, but it was good, so I'm still happy! Cheers, Terry. ;D
« Reply #21032 on: February 11, 2016, 03:23:38 AM »
It might be the vintage racers that vacuum clean the market of cheap 750 stuff?
It has changed here too. A few years ago a complete engine for about $300US (In need of repair). A CB750 K1-K6 in rather good shape around $2000-3000US.
F1 and F2 can still be found in veru good original condition for around $3000US- K1-K6 double as minimum
Offline maduncle
  • Don't confuse me with a
« Reply #21033 on: February 12, 2016, 01:55:19 AM »
Nice work Terry, always good to see parts slowly accruing in the hand of enthusiasts.
CB750K2 (only slightly modified)
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #21034 on: February 12, 2016, 06:01:36 AM »
Drove the lower race off the triple tree, getting prepped to re-paint where the brake fluid ate it away. Doing the same on the upper.
Fork bits should arrive today, then I can assemble the forks tonight!
--Evan
1975 CB750K "Rhonda"
« Reply #21035 on: February 12, 2016, 12:34:15 PM »
Pewe,
I do not know the case bore diameter. I just sent them to Big Jay and let him do his thing. He plugged the oil return passages with aluminum?? inserts like the older blocks are and do not have the dowels or o-rings now. He filled in the spaces in the block between 1 & 2 and 3 & 4 with epoxy too.
Offline Davez134
« Reply #21036 on: February 12, 2016, 01:38:25 PM »
Put on an oil pressure gauge. Seemed like the oil was wet sumping into the motor a bit, and I saw my light flicker on quickly while at a stop. All good according to gauge though. 65ish psi while riding and 16ish at idle fully warmed. Will drop occasionally to about 12
« Last Edit: February 12, 2016, 02:05:10 PM by Davez134 »
Offline mrbreeze
  • Not your average
« Reply #21037 on: February 12, 2016, 06:45:23 PM »
Terry, that looks like a pretty good haul of parts and on your side of the pond too! I take parts for granted more than you because they are plentiful here in the states. I couldn't afford to have stuff shipped from other countries although I did get a small package from Yamiya for like $10.50. I think its the worst between here in the states and Canada though for expensive shipping.
MEMBER # 257
« Reply #21038 on: February 13, 2016, 02:15:19 AM »
Thanks Guys, yeah I know what you're saying Fred, most of the 500,000 CB750's built were sold in the US, and while there were plenty here once upon a time, good used bikes and parts are going for silly prices now.
Anyway, having a bad back I was dreading the idea of pulling the engines out on my own. I can lift a complete CB750 engine on my own, but I'm usually sore for a day or two after, so I decided to work smarter, not harder.
I scored a "patient lifter" a couple of years ago that was being thrown out because it was missing some lifting stuff and the batteries were clagged, so I put some new batteries in it and re-purposed it as a mobile bike/engine lifter. I ran some rope through the engine mounting bolts and tied it off in a makeshift harness, and just lifted each engine out, rolled them down to the garage. Simples......... ;D
Offline hotdog
« Reply #21039 on: February 13, 2016, 02:17:26 AM »
Nice haul Terry
Sent from my HTC_M9u using Tapatalk
Instagram - LUMPY CAM MOTORCYCLES
FB - LUMPY CAM Motorcycles
Offline Desert-SOHC
  • It's old
« Reply #21040 on: February 13, 2016, 11:52:57 AM »
Installed the new +7 clutch cable, its a bit long right now but is within an inch of where it needs to be when she is done. Was going to take a test drive but popped my right knee......no riding for me for a few days!  >:(
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
Offline whitjonw
  • Motorcycle Maniac
« Reply #21041 on: February 13, 2016, 06:09:15 PM »
I mounted the seat latch plate and lock to my 1974 CB750.....!!!
1973 Honda CB500 K2
1974 Honda CL200 Scrambler
1974 Honda CB750 K4
1976 Honda CB750 K6
This is our life, this is our song.....
Offline firebane
« Reply #21042 on: February 13, 2016, 07:18:47 PM »
Sourced a inner fender, rear fender and a pre 76 gas tank and petcock. Had to drive 6 hours and visit family but now I can move forward on my bike. Just need a seat or seat pan.
« Reply #21043 on: February 14, 2016, 02:40:50 AM »
Well I don't know what's going on, but my stocks of CB750 parts, which have been depleted over the last couple of years are coming back thick and fast! I saw this pile of K1 bits on eBay tonight, the owner has had the K1 engine rebuilt with a big bore kit and a mild cam, so at last I'll be able to build a complete K1 from front to back. (my K1 has been fitted with a K6 engine since I built it all those years ago) Cheers, Terry. ;D
Offline mrbreeze
  • Not your average
« Reply #21044 on: February 14, 2016, 02:48:52 AM »
Hella cool Terry!! Looks like it's raining 750's over there lately. Do the pipes look as good on the other side? I'm gonna have to keep track of what you do with this one. All the good parts for your K1 and enough left to build another to flip (or whatever).
MEMBER # 257
« Reply #21045 on: February 14, 2016, 03:05:56 AM »
Terry, be careful when mounting the ign wires to the Ultimate coils. Not tighten too much, the threaded things for wires are common screws with small heads that will pop-out from the plastic coil housing if tighten hard with thumb and index finger...
That's why I have Dynatek coils.... ???
« Reply #21046 on: February 14, 2016, 03:11:43 AM »
Thanks Fred, those pipes are a mix of HM300 and 341's, so I might need to do a bit of "buy swap and sell to get the remaining HM300's. I was seriously thinking about buying another Harley when I saw this 17 minutes out from end of auction, and as much as I like Harleys, I've wanted a complete "restificated" (an original K1 with a bit of age to it) K1 for a long time, so the Honda won out! That red K0 tank you sent me is gonna look good in pride of place mate! Cheers, Terry. ;D
« Reply #21047 on: February 14, 2016, 03:14:22 AM »
Hey thanks for the tip Pewe, I'll be careful! (I'll be especially careful to sneak that stuff into my garage without the wife seeing me..........);D
« Reply #21048 on: February 14, 2016, 11:01:11 AM »
Ha-ha-ha!!! I know exactly about sneeking in parts..... I have a lot of parts going in thru the garage doormy woman has no seen. Good that she sometimes work when UPS arrive with big box from David Silver.
Other packages I fetch from the post office when I have to pay VAT and customs. She has seen that I payed $400-600US in VAT and customs only. She thought it was total.... I let her think that. Its my money I use but... the number of $$$ floating to the bike is like having a hot prostitute beside the wife...
« Reply #21049 on: February 14, 2016, 11:05:38 AM »
Pulled engine.... Carbs, Head, cyl, pistons, studs and clutch removed before taking out the engine. Still very heavy.
Typical this part of the year when daylight slowly return to this dark latitude. Things apart in february, work to middle of mars. Everything  to work in the middle of april.
« Last Edit: February 14, 2016, 11:09:10 AM by PeWe »
