Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
Paint side covers 750F1
Some bling-bling Renthal bars.Afterlight by Robb Hohmann, on Flickr
Pulled this K3 out of storage. Started tear down, the plan is to restore as is...
^^^cool as is , just needs a front fender, and......................................tires and brakes and carb work and tlc and tank flushed and electrics done and motor work and ? Lots of potential there Stev-o
New emulsion tubes installed(were backordered), tweaked the pilots(back to 38's). New carb to intake boots installed. Going for a ride shortly...Oh and ordered a new LiFePO4 battery...the one I've been bragging about(Ballistic EVO2-8) no longer holds a resting charge of 13.2 volts and the voltage drops rapidly under load off charge. This is it's forth year and third bike it's been installed on, so I'm pretty happy. Going to give the Scorpion Li a try...Cheers,Kenzo
Can you post a pic or a link Larry? I want one too, but I don't want to piss around with a little cleaner designed for cleaning your mom's dentures, I want one big enough to dump a complete bank of carbs in. Cheers, Terry.
Yer wife's jewels. Doesn't that tickle when you stoop down and drop the boys in? Sorry, I often can't resist
