Author Topic: What did you do to your bike today ?  (Read 3270384 times)
djwillard18
« Reply #21800 on: May 18, 2016, 05:32:12 AM »
Spent an hour picking at the cracked white paint on the tank emblems.  Any suggestions?
Offline CycleRanger
  • No comment about being an
« Reply #21801 on: May 18, 2016, 07:30:47 AM »
If you want to repaint the letters white thin down some white enamel and use a syringe to fill the letters.
Here's how they look if you go all the way.
Offline Powderman
« Reply #21802 on: May 18, 2016, 08:18:20 AM »
aerosol paint stripper and powder coat them.
djwillard18
« Reply #21803 on: May 18, 2016, 08:24:39 AM »
Thanks guys. Appreciate your ideas. I'll update with the finished product!
Sent from my SM-G900V using Tapatalk
Offline CycleRanger
« Reply #21804 on: May 18, 2016, 10:35:17 AM »
I tried a couple of different attempts to repaint mine but I haven't had a result I was happy with.
The hard part is the black. I've tried to figure out how Honda painted the black and kept the raised edge unpainted.
Based on way the whole badge is anodized gold except the edges of the letters my theory is maybe they painted the whole badge black then the paint and anodizing were removed from the high edge of the letters with a perhaps a fine belt sander then the letters were filed in with white.
When I stripped the original paint the black was very thick compared to the white.
When I get around to it my next attempt might be to try using liquid mask on the high edges of the letters before painting the whole badge black then filing in the letters.  Unless someone has a better idea.
« Reply #21805 on: May 18, 2016, 12:04:29 PM »
 After stripping old finish I painted the badge black then with a small brush a couple coats of white in the letters until satisfied. Did not have to be super careful because when everything had dried real well I took a piece of 400 grit sandpaper on a block of wood and lightly sanded the paint off the high spots of the letters. Looks real crisp.
« Last Edit: May 18, 2016, 12:24:14 PM by ekpent »
Offline CycleRanger
« Reply #21806 on: May 18, 2016, 01:22:00 PM »
Yes it is possible that I am over-thinking the whole process. That's why it takes me so damn long to rebuild a bike... :(
« Reply #21807 on: May 18, 2016, 02:16:37 PM »
I just bought new badges..... ;D
Offline TomsK8resto
« Reply #21808 on: May 18, 2016, 04:42:06 PM »
   Picked up a new machine Saturday to add to my "Big Dawg" collection.  Its a 1999 Suzuki Bandit 1200S. Bought it from the older retired original owner with all the paperwork,manuals extra key etc. Had an even 7,000 miles on it when I drove it off. I met him 3 years ago when he was thinking of selling it,had 6800 miles then. This spring he decided it was time to hang it up. Came with some soft bags,and his helmets. His wife looked happy. Has a flat spot around 4.000 rpm right now.Gave it a good shot of Seafoam Sunday and rode it quite awhile and its getting better but it has been sitting. Hopefully fresh fuel and another good dose will keep me out of the carbs but want to check the valves, change oil and other things also so may dive in if needed,possibly jet kit in hand. These are known to be lean. Never been down or tipped over and anxious to wax and detail her out. Now lets see if I can find a good FJ1100/1200 next that still has all its gears in the tranny :D
Nice find!
'69 CB750 long gone
'76 CB750F gone
'78 CB750K in progress.....
'09 H-D Roadglide
djwillard18
« Reply #21809 on: May 18, 2016, 07:15:52 PM »
My first couple coats with Testors model paint went very well. Thinning the paint really made it very smooth. Hopefully I'll have one ready for a picture tomorrow night.
Offline CycleRanger
« Reply #21810 on: May 18, 2016, 07:38:26 PM »
Yeah that was my first attempt....
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #21811 on: May 19, 2016, 05:35:26 AM »
Rigged up a charging port for my cellphone/gps while on longer trips. I'm going to be doing some motocamping in a few weeks and I don't want to lose battery!
Also re-tightened my new steering bearings. They had settled in over the first few hundred KMs, so I snugged them back up. Went for a ride. TOO TIGHT. I was fighting the bars through turns. Didn't feel safe! Came home and backed the adjuster nut off a bit (1/4 turn or so), then went for another ride. Smooth as silk! When the front end is raised and everything tightened, I can get the bars to swing about 1-2" before the weight takes over and it swings to the full lock.
For those adjusting this nut after installing the tapered bearings... make sure you make the adjustments with the wheel DOWN. I found adjusting the special nut with the front end raised didn't let me feel when it was "too loose" because the weight of the fork and wheel was pulling down on it.
Set initial tightness, tighten the chrome lock nut, raise the front end, check for tightness, lower back down, tighten pinch bolts last. Repeat as necessary!
--Evan
1975 CB750K "Rhonda"
« Reply #21812 on: May 19, 2016, 05:41:37 AM »
Standard procedure for tappered bearings is to tighten the nut - some manuals prescribe torque in Nm or fp - and back it off 45 - 60 degrees.
Offline evanphi
  • Apparently I'm an
« Reply #21813 on: May 19, 2016, 05:44:15 AM »
I had way overtightened it before, so the 1/4 turn off was just enough to avoid slop in the head tube. Then the big chrome nut also further tightened things.
--Evan
« Reply #21814 on: May 19, 2016, 12:15:25 PM »
Did the final adjustment of the front brakes. Replaced the washers to make right caliper parallel with single spacers for each bolt. 2xM6 + 1xM8.
Edit: Thickness  5.0mm
« Last Edit: May 19, 2016, 10:52:09 PM by PeWe »
« Reply #21815 on: May 19, 2016, 12:20:26 PM »
 8) Nice spacers!
"This is my CB. There are many like it, but this one is mineā€¦"
Offline kap384@telus.net
« Reply #21816 on: May 19, 2016, 01:29:28 PM »
Mounted the rear wheel, complete with new tire, back on my CT70.  Started going through all the new hardware I'd assembled to bolt it back together last year before I fractured my tibia. Cleaned up bolt holes in the engine case and chased threads.  Reminded myself how the automatic clutch assembly went back together.
1965 Honda CB450K0
1972 Honda CT70K1
1975 Honda MR50
1975 Honda CB400F Supersport
1977 Honda CB750F2 Supersport
1978 Honda XL100
1979 Honda CBX Supersport
1982 Honda VF750S Sabre - Adventure Bike modified
1983 Honda CX650T
1995 Honda VFR750
2016 Honda CRF1000L Africa Twin
2015 KTM 200 XC-W
1963 Suzuki T10
My 1977 CB750F restoration - http://forums.sohc4.net/index.php?topic=66779.0
My 1975 CB400F restoration -
http://forums.sohc4.net/index.php?topic=145196.msg1651779#msg1651779
'More Stock Than Not' thread - http://forums.sohc4.net/index.php?topic=90807.500
My CT70 Resurrection - http://forums.sohc4.net/index.php?topic=145221.0
Best Motorcycle Tool Ever - https://www.engduro.com
« Reply #21817 on: May 20, 2016, 03:48:43 AM »
Looks very clean.
I remember using round aluminum ferrules from Home Depot.  They are meant for wire ropes, but the round ones make perfect spacers.
djwillard18
« Reply #21818 on: May 20, 2016, 06:37:44 AM »
Started over last night by stripping with Aircraft Stripper. That took 20 minutes with very minimal effort. The naked emblems are more gold toned than yours, but it doesn't matter.  I am going to try to restore the original paint using the thinning method and dropper for white letters.
I also rebuilt the seat plunger with new grommets from http://4into1.com.   Great experience with this company.  They were out of stock, but Marty told me when they'd be available and I ordered then.  Good customer service and product
« Last Edit: May 20, 2016, 06:41:46 AM by djwillard18 »
Offline Bankerdanny
  • Endeavor to persevere
« Reply #21819 on: May 20, 2016, 09:12:05 AM »
Took care of the title and licensing, ordered a Norman Hyde style M-bar to replace the drag bars. Need to order shorter clutch and throttle cables. The PO installed the drag bars to replace the prior kind of tall bars and all the cables plus the master-brake light switch hose are all way too long.
Now I just need to pick it up from the seller and bring it home. Hopefully Sunday. I can't decide if I want to ride or haul. It appears to be in rideable condition, but I am inclined to haul so that I can change the oil and do some basic maintenance and safety checks before I trust it to the roads.
« Reply #21820 on: May 20, 2016, 09:44:37 AM »
Gotta ride it sometime!
Offline Bankerdanny
« Reply #21821 on: May 20, 2016, 11:37:00 AM »
I know, but I would rather do my initial test rides down at my sister's where my shop is and also my brother-in-law with the trailer to come pick me up.
I'm planning on riding it up to Wisconsin for the 2016 Rockerbox June 11-12, so I want to have a good solid couple weeks and couple hundred miles of riding under my belt to know that there are no major issues that could bite me during a longish trip away from home.
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #21822 on: May 20, 2016, 03:17:11 PM »
Working on installing these new shocks.
Offline firebane
« Reply #21823 on: May 20, 2016, 03:19:22 PM »
Shocks are upside down... May want to turn them over.
« Reply #21824 on: May 20, 2016, 04:22:40 PM »
Speaking of "gotta ride it sometime", have you taken your maiden voyage yet Jerry, or did I miss it? Cheers, Terry. ;D
