Author Topic: What did you do to your bike today ?  (Read 3820803 times)
0 Members and 16 Guests are viewing this topic.
Offline Holshot
« Reply #22700 on: October 03, 2016, 04:42:50 PM »
Holshot, That's a nice little bike shed you made. Looks like it would be cozy to work on one bike with enough room to store 2 or 3. A smaller unit like that would be quick & easy to heat in the winter.
Thanks! That's the plan... I still have to wire her up for electric but it will fit 3 bikes wide in the entrance and the back half will be benches, tool boxes, lift, compressor, ect... I do plan on insulating and finishing off the inside as well so when I throw in a mini-split she stay nice and warm/cool. I'm going to leave my '74 stock/original and not chop her up like originally planned and pick up a basket case ('71) hopefully this weekend to turn into my dream Cafe racer...
1974 CB750K
Offline Desert-SOHC
  • It's old
« Reply #22701 on: October 04, 2016, 08:26:18 PM »
Took the throttle apart and removed the cables, lubed them and rerouted them for a smoother pull.  Since I havent got my extended brake line yet the +9 stuff is a little long.  Also lubed the clutch cable and did a little more work on the forwards, the shifter was hanging a bit.
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
« Reply #22702 on: October 05, 2016, 03:15:51 AM »
I ordered some universal hand guards for cutting down the wind on my hands on these early mornings!
Pics to come...
Looking forward to see them. I need some for my K2. (Yes, it does get chilly in Las Vegas in winter
    • http://forums.sohc4.net/index.php?PHPSESSID=dj2h8cg6dmj2m4r76d547f0a44&/topic,60973.0.html
« Reply #22703 on: October 05, 2016, 05:44:40 AM »
... :)..yes a good idea,,but better to take the cbx dovn..and ride it.
 sohc forums is the place to learn..abaut cultur and klimate..and a mad max mowie..and stone have i all infos to take Down under and ride the real nightrider ride...even you have some Cold vinters..still think i can make it vitaut to cut my boots
Offline The Lone Builder
  • "Still running against the wind"
    • Belfast-2-Belfast-By-Bike
« Reply #22704 on: October 05, 2016, 02:04:26 PM »
Finally got the allen bolt out of the bottom of the fork leg. Thanks to all the tips on here, a broom handle and a smack with an impact driver did the trick.
Now just need to know if I can use replacement longer tubes and springs with original legs.
Will be done by Xmas!
CB750 K2 - From Belfast-2-Belfast
CB750 K1 - The less, said the better!
CB450 K1 - Stalled.
CB400F Supersport - Not Rusty any more!
Follow my journey through Africa @ http://Belfast2BelfastByBike.com
Offline aquarices
« Reply #22705 on: October 05, 2016, 05:17:48 PM »
I fit my new muffler tonight
How's it sound?
A lot more "throaty" and aggressive. Kinda like a mix of Harley sportster and crotch rocket.
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #22706 on: October 05, 2016, 07:44:01 PM »
The short answer is yes.  But you'll have to measure for rake angle/steering geometry.  You probably wont be able to use the factory handlebar clamps, and will end up with a cafe racer lookin front end.  Tubes stickin up through the trees clip ons and stuff.
« Reply #22707 on: October 06, 2016, 03:09:32 AM »
Ha ha, well it depends on how cold you want to be mate, Oz is approximately 50 times the size of Europe, give or take, so you can have cold winters down south where I live, or fcuking hot ones up north where Mick lives, although it does rain a lot up there in the wet season, which is good, becaue it's the only time the smelly bastaards have a wash. True story. ;D
Offline whitjonw
  • Motorcycle Maniac
« Reply #22708 on: October 06, 2016, 04:22:43 PM »
Got fork seals changed on my '74 CB750 and forks remounted and tightened up. Fitted a speedo cable and took the bike for a ride, confirming the speedo works and seems pretty accurate...bonus ! Front end feels good too...double bonus ! It's an awesome feeling bringing back a parts bike others deemed dumpster filler   8)
1973 Honda CB500 K2
1974 Honda CL200 Scrambler
1974 Honda CB750 K4
1976 Honda CB750 K6
This is our life, this is our song.....
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #22709 on: October 06, 2016, 06:07:42 PM »
...It's an awesome feeling bringing back a parts bike others deemed dumpster filler   8)
Good on ya!
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline whitjonw
  • Motorcycle Maniac
« Reply #22710 on: October 07, 2016, 05:45:38 PM »
Good on ya!
Thanks !!
This bike was a roller, just frame and engine. No carbs, engine side covers missing. No oil tank, foot pegs, brake parts front and rear, no handlebar controls or switches, no gauges, wiring spliced, some super ugly king & queen touring seat, no cables, rear brake frozen in the hub, cut up rear fender  and whatever else. I sourced all of the parts and put CB750 back together again  ;)
I have been a Brit bike guy for the majority of my motorcycling life, so getting a '74 CB750 from that state to running again seemed a like a bit of a challenge at first but  I adapted pretty quickly and used my parts finding skills and acquired know how to accomplish the mission and a running and riding mostly stock bike is the end result. And, I really like riding it !!
I had ridden a few when I was a teenager in the '80's and was always fond of them since. Trolling CL and right in my town was a '74 CB750 parts bike for $250. I took about 1 nanosecond to reply and contact the seller and the rest is history  8)
1973 Honda CB500 K2
1974 Honda CB750 K4
1976 Honda CB750 K6
« Reply #22711 on: October 08, 2016, 02:29:46 AM »
Congrats!
Good on ya!
Thanks !!
Offline enwri
  • So that noise is normal?
« Reply #22712 on: October 10, 2016, 06:23:14 AM »
Found a new brake fluid reservoir diaphram, should have done that a while ago I suppose..
« Last Edit: October 10, 2016, 06:34:53 AM by enwri »
77 CB 750 k.. 29 years and counting.
91 TDM 850 (No.34) so comfy and soft
8? XJ 550 meh...
76 XL 350 Super Sport stump puller..
80 XR 200 idiot proof
75 MX 250 b dangerous
  • Holy Cow! I'm a
« Reply #22713 on: October 10, 2016, 10:07:41 PM »
Rode Bloo to work, and soon I will be riding her home from work.  Gotta love cold clear autumn days
« Reply #22714 on: October 11, 2016, 02:04:06 AM »
got the new intake rubbers..om..and(new used) airfilter housing..so think it runs in a few days..
Offline esantella
    • Chiltepe Motors
« Reply #22715 on: October 11, 2016, 02:14:05 AM »
Fixed my slides, replaced all my cables, bought some new coils, changed out my spark plugs, oil change, and then drove home. Still working on my 1969 CB750 Diecast. Attaching some recent pics from my shops exposition.
Sent from my iPad using Tapatalk
HONDA CB750 1969 K0 DIE-CAST CANDY BLUE GREEN
HONDA CB750 1980 CODE NAMED "CB KING"
HONDA 1979 CM185T "SKILLFUL SAILOR"
KAWASAKI 1978 KZ1000
ROYAL ENFIELD 1958 BULLET 500
ROYAL ENFIELD 2013 CONTINENTAL GT "ROYAL PEARL"
MOTO GUZZI 2012 V7 RACER
YAMAHA 2017 SCR950
INDIAN 2016 SCOUT SIXTY
Offline maduncle
  • Don't confuse me with a
« Reply #22716 on: October 11, 2016, 02:43:50 AM »
Treated it to a service at a local motorcycle mechanics near work, basically because I am moving house and all my garage gear is packed and I wanted it running well for summer.
And yes, okay - I was feeling lazy too. Sometimes you just want someone else to deal with it.
They found two valve clearances out of eight I had wrong, balanced the carbies, found two loose spark plug leads at the coil end, adjusted the throttle play and gave me back smooth running bike.
Good service for a good price and I had a great ride home.
CB750K2 (only slightly modified)
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #22717 on: October 12, 2016, 07:13:24 AM »
Hand guards installed:
--Evan
1975 CB750K "Rhonda"
Offline USMC5811
« Reply #22718 on: October 12, 2016, 03:01:06 PM »
I like those!
Where'd you find them?
« Reply #22719 on: October 12, 2016, 10:58:16 PM »
I don't know how much protection those ones offer, the PO of my BMW R1100GS added additional material to the OEM ones and with the electric hand warmers are nice on a cold day, for sure. Cheers, Terry. ;D
Offline evanphi
  • Apparently I'm an
« Reply #22720 on: October 13, 2016, 04:53:33 AM »
They're more for wind protection. I have nice heavy winter moto gloves, but just keeping some wind blast off my fingers is needed.
I like those!
Mounting kit: https://www.amazon.com/PowerMadd-34269-Trail-Handguard-Mount/dp/B00230MKZ8
Handguards: https://www.amazon.com/PowerMadd-34210-Star-Handguard-Black/dp/B001TW5BAW
--Evan
Offline USMC5811
« Reply #22721 on: October 13, 2016, 07:25:56 PM »
I like those!
Thanks!
« Reply #22722 on: October 14, 2016, 04:00:09 AM »
sold the cb 77...and the 400 is going today..Money goes to komplet the cbx and ford Taunus.
.as a bonus i lost my job..the elektro repair shop is konkurs..so no more free vires and konnektors..
Offline edwardmorris
  • Youngish
« Reply #22723 on: October 14, 2016, 02:39:09 PM »
Sorry to hear about the job  :(
« Reply #22724 on: October 15, 2016, 12:31:18 AM »
+1 Strybie, I hope you gfind another job soon. Cheers, Terry. ;D
