Author Topic: What did you do to your bike today ?  (Read 3830496 times)
0 Members and 9 Guests are viewing this topic.
    • http://forums.sohc4.net/index.php?PHPSESSID=mrjoilti27gj9lejt14mpc82m1&/topic,60973.0.html
« Reply #22800 on: October 26, 2016, 03:28:27 AM »
do you think the inside diameter is to small to a cbx 1000cc engine..it seems that all petcocks is the same desein..just the threddet autrunner is made to spec modell..my fuel line is soft and accepts both ends( vith some care.)..my only vorryes is the fuel kapasaty dl/pro minute..but a cbx only have 100 hk/hp..but like fuel..have once,, emtyed the reserve tank..(..it vas hard to push home)
the adapter vas to my 400 four..its just a moped...
edit..i have made a floting test of the china tap..it gives 0,2 liter pro minute
« Last Edit: October 26, 2016, 07:09:27 AM by strynboen »
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #22801 on: October 26, 2016, 08:54:51 PM »
Started on the front end disassembly today.
« Reply #22802 on: October 27, 2016, 03:49:13 PM »
What's the plan, Bomber?
  • Holy Cow! I'm a
« Reply #22803 on: October 27, 2016, 04:04:07 PM »
I'd been slowly amassing the parts to fix up the front end.  All balls head bearings, fork seals/damping piston ring, just picked up the front wheel from the speed shop.  She'll be rollin spitfires for the next 7-10kmi.  Asked my pal there if he would drill the brake rotor, but he talked me out of the idea, 3 hours labor and not much gained.
I got fed up with the leaky fork seal on the left stancion, my tach gauge is useless so I'm gonna ditch that.  Fashion a new mount or the speedo and key switch, move the indicators into a k-model bar clamp cluster (a swap meet freebie!)
And that mofuggin headlight bucket is a smashed up busted p o s from a yamaha.  Still searching/scheming for a new lamp.
He's the glimpse of the fork tubes as they are.  My pal the guzzi-addict thinks I'll be fine to re use them despite the dull streaks in the chrome.
  • Holy Cow! I'm a
« Reply #22804 on: October 27, 2016, 04:27:14 PM »
Discovered a new product to aid with stubborn stripped old screws.
Offline whitjonw
  • Motorcycle Maniac
« Reply #22805 on: October 27, 2016, 05:26:01 PM »
I like your bottle jack idea in combo with the center stand. I'll have to get one !
1973 Honda CB500 K2
1974 Honda CL200 Scrambler
1974 Honda CB750 K4
1976 Honda CB750 K6
This is our life, this is our song.....
« Reply #22806 on: October 27, 2016, 06:12:21 PM »
Hmmm- Shock- Looks and sounds gooden' nuff to drink-- Yummy !!
  • Holy Cow! I'm a
« Reply #22807 on: October 27, 2016, 06:21:17 PM »
Its more a necessity than an Idea, my jack stands are in use elsewhere
« Reply #22808 on: October 28, 2016, 09:01:29 AM »
Bad place to post probably but found kind of a cool old Aladdin lunch box out pickin' early this morning called Rough Rider. The lady said she had an Evil Knievel also but the grandson wanted it last night. Sure enough as I was leaving the little grandson who looked around 6 or less was walking down the drive towards Granny with his mom carrying Evil  :)
  Any of you biker dudes ever had a biker lunchbox when you were a kid ? Here's one for the cafe guys and the Beemer Boyz also  ;)
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
« Reply #22809 on: October 28, 2016, 09:54:37 AM »
Just Dukes of Hazzard. Is the thermos present and intact?
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
« Reply #22810 on: October 28, 2016, 09:59:02 AM »
Nope just the box unfortunately. She said she had some more boxes packed away somewhere, have to check back sometime.  Maybe Frank 754 will tell us what kind of dirt bikes those are, look a little like Maico or AJS  ;)
« Last Edit: October 28, 2016, 10:01:51 AM by ekpent »
Offline joeyvans
  • Definitely not a
« Reply #22811 on: October 28, 2016, 10:14:49 AM »
Cool find, nonetheless!
1976 CB550 K2
Offline joeyvans
  • Definitely not a
« Reply #22812 on: October 28, 2016, 10:29:43 AM »
Haven't touched my SOHC in awhile, but started some work on my "most impressive bike ever made."
Had to remove the 10" wire extensions in the controls and solder the originals back together, due to switching from the REALLY high bars to 400f replicas.
Cleaning the carbs as well. Hoping to have genuine gasket kits today so I can try firing this baby up this weekend.
Before & After
1976 CB550 K2
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #22813 on: October 28, 2016, 10:37:22 AM »
ooooh. shiiiiiiiiiiiiiiiny.
--Evan
1975 CB750K "Rhonda"
  • Holy Cow! I'm a
« Reply #22814 on: October 28, 2016, 11:16:33 AM »
  • Holy Cow! I'm a
« Reply #22815 on: October 28, 2016, 04:50:31 PM »
I thought I was ready to catch those head bearings but Nope!  One got away from me.
« Reply #22816 on: October 28, 2016, 06:29:27 PM »
Are you doing tapered bearings or just a re-pack. Got some extra bearings around if you lose any.
  • Holy Cow! I'm a
« Reply #22817 on: October 28, 2016, 06:57:40 PM »
I have the all balls kit waiting to go in.
The bearing cap was on finger tight...that might explain my wibbly wobbly shakey wakey issue.
Offline USMC5811
« Reply #22818 on: October 28, 2016, 08:22:20 PM »
I had that and the Evel Knevel box - now all I want is a time machine...
  • Holy Cow! I'm a
« Reply #22819 on: October 29, 2016, 01:30:57 AM »
So I don't have to install the tapered bearings because the stock races are shiny.
« Reply #22820 on: October 29, 2016, 11:26:45 AM »
 Sold #6 yesterday an 81 CX500c. ------------- Hmmm what next-----------------------
« Reply #22821 on: October 29, 2016, 12:33:54 PM »
Hell is frozen!   Send those smokers down here....
  • Holy Cow! I'm a
« Reply #22822 on: October 29, 2016, 03:17:58 PM »
Finally got the bastard out!
Offline Lostboy Steve
« Reply #22823 on: October 29, 2016, 04:12:36 PM »
I wonder how many people on here get that reference...
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
  • Holy Cow! I'm a
« Reply #22824 on: October 29, 2016, 04:20:06 PM »
All that matters is we are out there, runnin in the black.
