Author Topic: What did you do to your bike today ?  (Read 3959736 times)
0 Members and 14 Guests are viewing this topic.
Offline mrd 1976
« Reply #27625 on: April 07, 2019, 09:47:03 PM »
being doin a top end rebuild own my cb 750 an at the end of the day cant get the cam chain to trun the cam an valves
Offline WhyNot2
  • I'm finally an
« Reply #27626 on: April 08, 2019, 03:24:18 AM »
Well, took a points file to my points, reset them, sh1t, now no spark from them.
Iiiiiiis hates these darn things...................
Offline Bankerdanny
  • Endeavor to persevere
« Reply #27627 on: April 08, 2019, 08:03:45 AM »
You mean that you have the cam chain over the cam sprocket, but when you rotate the crank by hand the chain doesn't move? Of can you not rotate the crank?
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #27628 on: April 09, 2019, 05:51:34 AM »
Fell on to it this morning before work.
Left my coat in the building and needed something out of the pocket. Tripped over my angle grinder cord into the bike.....
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
Offline Kelly E
  • Geriatric Hooligan
« Reply #27629 on: April 09, 2019, 10:49:38 AM »
Are you Ok? More importantly is the bike OK?  8)
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
« Reply #27630 on: April 09, 2019, 11:53:22 AM »
Assuming the cam chain is on the sprocket correctly and the sprct is on the cam... do you have spark plugs in it? you should not, makes it real hard to turn with the crank nut.
Offline FourUsTry
  • Old enough to know better
« Reply #27631 on: April 15, 2019, 07:18:38 PM »
Got the '78 CB550K to the "try to run it" phase: plugs gapped and installed, set up tank next to bike with some fresh gas, clear tube float level test and fix level for carbs 1 & 4 (lucky that only the outside carbs needed changes: did it on the bike).
Tried to start it: turned over nicely but no luck. Goosed it with a little starter fluid into the air cleaner and bam, runs like a kitten. Going to check the pilot screw setup tomorrow and see if that helps. When we got the bike it took a ton of starter fluid to get her going so definitely much better, but we don't want to have to spray it every time. We were hoping to avoid a carb rebuild this season so any ideas out there short of that? We've got new coils and NGK D7EV plugs, new OEM ignition plate, careful static timing and valve clearances. I'll do the timing light and dwell tomorrow but with static timing spot on that shouldn't affect starting. Of course I'm using full choke on the cold starts. Cranking speed is great (new AGM battery). My only idea short of pulling the carbs is to see if I can find a vacuum leak by spraying a little starter fluid around the boots once it is idling, but the boots look good and I tightened all their collars. We don't have a good MC compression or leak-down tester yet, but if it runs great when warm that doesn't seem a likely cause of cold-blooded startup.
Anyway, on the whole a good day. After a long winter of restoration work we have a smart looking machine that runs and makes a sweet exhaust purr! Having a celebratory beer and calling it a night.
1978 CB550K
Past:
2001 VFR800
1980 CX500
« Reply #27632 on: April 15, 2019, 09:53:35 PM »
FourUsTry, good looking bike ! :)
Offline BRG-BIRD
« Reply #27633 on: April 16, 2019, 05:24:19 AM »
^ +1
“You are either on something or onto something.” The Comman Man
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #27634 on: April 16, 2019, 10:45:54 AM »
I started Rhonda on Sunday for the first time since her winter nap. I love her singing voice. :)
--Evan
1975 CB750K "Rhonda"
« Reply #27635 on: April 16, 2019, 11:17:37 AM »
 Retrieved a parts bike from storage to nab a couple parts off of it. Now I remember where that F1 fork set went.
Offline WhyNot2
  • I'm finally an
« Reply #27636 on: April 16, 2019, 01:32:05 PM »
I burnt the darn starter relay up trying to get this 750 going.
I released the smoke from it, now,  all it does is click.    Sh1t!!!!!
Gonna have to start from scratch and go thru all the systems, to figure out why it won't start and run.
Offline Bankerdanny
« Reply #27637 on: April 16, 2019, 02:11:13 PM »
generally a click means it is working. Have you tried shorting across the terminals with a screwdriver to see if the starter spins?
Offline Mr.Mazza
  • The man from down under
« Reply #27638 on: April 16, 2019, 07:26:47 PM »
Installed a Hondaman ignition box into the old girl last night.
After a quick and painless install the bike...the bike feels more alive!
Better idle, quicker throttle response and smoother  8)
Worth every penny!
Also adjusted my front brake so it isnt dragging  :-[
Driving a car is watching a movie, riding a motorcycle is starring in the movie
Offline Can550
« Reply #27639 on: April 16, 2019, 07:31:04 PM »
Struggled with sticky throttle on my cb400f
Cables off bike move freely, lubed them. Put them on bike, checked them before connecting to carbs, smooth and free movement. Carbs snap back fast and strong.
The moment I hook up to carbs, throttle doesn’t go back. Routed cables as lined in manual.
Did it about four times, no luck then I undid push cable and only with pull cable it works perfect. Went for a short ride with just pull cable hooked up, ran beautifully except it was chilly
Can’t figure out what’s wrong ?
« Last Edit: April 16, 2019, 07:40:04 PM by Can550 »
Offline MD
  • Living in the North Woods overlooking The Lake.
    • MN North Woods
« Reply #27640 on: April 16, 2019, 07:37:54 PM »
Went to see if there was still snow in the woods.
Up the Gunflint Trail, Grand Marais, MN.
-MD
1975 CB550F Super Sport;  Lake Superior Circle 1000, 45-90 Saddle 1000, All in Yooper 1000 and SS 2000 in 48 hrs:  1985 GL1200A, MN in State SS1K
Offline MoMo
  • Ride like you're invisible
« Reply #27641 on: April 16, 2019, 07:42:29 PM »
Have you made sure the throttle sleeve is not binding on the handlebar?
Offline Can550
« Reply #27642 on: April 16, 2019, 07:53:09 PM »
Checked that half dozen times
With switch
Without switch
With cables
Without cables
It’s the push cable that sticks but on its own it moves very easy and smooth
Offline jgger
« Reply #27643 on: April 16, 2019, 09:31:50 PM »
If it is a new cable check if the lug on the end isn't rubbing on the throttle housing (too wide). If it sticks out farther than the width of the throttle tube or if the cable is off center to the lug, that could cause the bind.
« Reply #27644 on: April 17, 2019, 02:56:05 AM »
Did you adjust so they have about 1/8 inch of free play as per manual?
Offline WhyNot2
  • I'm finally an
« Reply #27645 on: April 17, 2019, 03:28:06 AM »
It released a lot of smoke and the wires were hot as crap.
Yes, I did jump it, and failed.
Did not spin the starter, just a small spark.
Offline toomanybikes
« Reply #27646 on: April 17, 2019, 03:44:06 AM »
resurrecting a '78 550k, yesterday's progress was clearing brake lines from sludge, new brake fluid, then test ride. Front brake actuates but does not easily return to free state, so either piston is getting stuck or the pads aren't sliding back into position. Time to take it all apart.
Also pulled the float bowl drain screws to replace the orings. One of the bowls is also leaking from the drain plug, so need to see if it's a cracked tube or something else. It's not the valve as verified by clear tube.
current stable, always subject to change ...
'22 MG V85TT
'19 Triumph Scrambler XC
'10 BMW R1200 RT
'81 Honda GL1100
'78 Honda CB750F SS
Offline FourUsTry
« Reply #27647 on: April 17, 2019, 07:28:43 AM »
In mine this was caused by the 2nd, "return", hole in the master cylinder reservoir being completely blocked. Had to get a tiny drill bit to open it up.
1978 CB550K
Past:
2001 VFR800
1980 CX500
Offline WhyNot2
  • I'm finally an
« Reply #27648 on: April 17, 2019, 09:02:45 AM »
Did you do this with the fluid still in, or was it empty?
And second, you mean there's 2 holes in the cylinder?
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #27649 on: April 17, 2019, 09:41:43 AM »
Brought my 74 550 home from the GFs dads.  Gonna get some new brakes for it and get it ready to ride again.
