Author Topic: What did you do to your bike today ?  (Read 3013281 times)
Offline Magpie
« Reply #27850 on: May 18, 2019, 07:41:41 am »
The beat goes on and apart it comes. I hope to have the engine on my workbench this weekend.
Offline gorskatron
« Reply #27851 on: May 18, 2019, 05:50:28 pm »
Rode mine to a buddy's house to help him rebuild the carbs on his new project, a '80 KZ750 Twin!
« Reply #27852 on: May 19, 2019, 10:45:00 am »
Today a crusing day with my CB750K2!
This time not carb testing, nor ignition  testing in legal speeds 3500-4000 rpm on 5:th gear. Charging adjustment and test. The last days cruising had almost drained battery totally after around 300 km.
Adjusted regulator, turned the adj screw in 1/4 turn which most likely fixed it. The charging supervision LED is now green from 4000rpm, allow reducing throttle to 3500rpm and still happy. It must be the relay that switch over and keep staying "high" down to 3500rpm with headlight on. LED H4 consuming 30W.
No overvoltage either with and without headlight on, LED should then flash green-red.
« Last Edit: May 19, 2019, 12:04:02 pm by PeWe »
CB750 K6-76 1005cc JMR Billet block.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #27853 on: May 19, 2019, 01:14:21 pm »
So far I got me front brake lines installed and painted up the brackets for the splitter and also the tail light I installed a couple months ago. I'm on my way back from the hardware store with stainless hardware to extend the center stand stop.
I have also been working on smoothing out the tank dents to get ready for paint next weekend and making sure the tail piece is also smooth and ready for paint.
Offline irish44395
« Reply #27854 on: May 19, 2019, 03:45:13 pm »
I got a new to speedo and tac from ebay . the speedo bounced to much for me so I took it out the housing and put my original speedo in. the original work good but the housing was broken .
Pete
Offline BobR
« Reply #27855 on: May 19, 2019, 04:54:50 pm »
 Wiped it down, checked it over and took it for its first decent ride this season. Bob
Reality is merely an illusion, albeit a very persistent one. Albert Einstein
 CB750K4(F2 engine)
Offline Tews19
  • I am no
« Reply #27856 on: May 19, 2019, 05:10:06 pm »
I picked up this '72 the other day for $30 bucks, $25 of the $30 went to replacing the lost title slip.  The The PO spray bombed the bike. Luckily for me Flitz is removing the spray bomb paint and she is coming around. I should mention I slapped a battery in and everything functions.
Sent from my SM-G955U using Tapatalk
1970 Honda CB750 survivor.
Offline MD
  • Living in the North Woods overlooking The Lake.
    • MN North Woods
« Reply #27857 on: May 19, 2019, 06:02:05 pm »
 :)  What a great find.   8)
-MD
1975 CB550F Super Sport;  Lake Superior Circle 1000, 45-90 Saddle 1000, All in Yooper 1000 and SS 2000 in 48 hrs:  1985 GL1200A, MN in State SS1K
Offline Bankerdanny
« Reply #27858 on: May 19, 2019, 08:19:13 pm »
75% of tank prep done
« Reply #27859 on: May 19, 2019, 09:50:00 pm »
Speedo, tacho faces look rather good. These are usually flaking inside by sun and age, especially these old K2.
« Reply #27860 on: May 20, 2019, 12:49:55 am »
Wow! Bargain! That's the difference between the US and every other 1st world country, stuff in the US is cheap! This is what you get in Oz for more than 10 times what you paid for your K2! ;D
Terry's Swamp Rat CB750 28 Apr 2019 by Terry Prendergast, on Flickr
« Reply #27861 on: May 20, 2019, 05:29:30 am »
 Nick paid way too much  ;D ;D  Is the tach face a different color,maybe a later model ?   Fun find for sure.
Offline Tews19
  • I am no
« Reply #27862 on: May 20, 2019, 07:11:49 am »
The tach does look as if it's from a different model, I really do not know. The speedo did have over spray. Luckily it cleaned up with acetone.  Flitz for everything else. I may give this one to the 19 and 15 year old to work on and learn how to wrench. As of now she is sitting in the shed
« Reply #27863 on: May 20, 2019, 07:40:56 am »
Time to open the wallet and order parts from Yamiya for around $8000 US !!! :)
Make the bike great again!
Offline WhyNot2
  • I'm finally an
« Reply #27864 on: May 21, 2019, 06:54:52 am »
Got the engine ready to go back into the frame.
« Reply #27865 on: May 21, 2019, 07:11:22 am »
What is it?
Offline WhyNot2
  • I'm finally an
« Reply #27866 on: May 21, 2019, 07:14:33 am »
What is it?
It's my other SOHC, just single, not 4.  CB100
« Reply #27867 on: May 21, 2019, 07:55:31 am »
What is it?
thanks!
Offline Scott
  • 72 CB750
« Reply #27868 on: May 25, 2019, 04:03:53 am »
I took the cam out.
Is this how you do it?
Offline MoMo
  • Ride like you're invisible
« Reply #27869 on: May 25, 2019, 06:22:56 am »
I took the cam out.
that is one way,  sure it isn't the by the book method ::)
Offline Scott
  • 72 CB750
« Reply #27870 on: May 25, 2019, 01:00:43 pm »
I bought an engine from the wreckers years ago and forgot about it.
I decided to pull it apart to rob some bits for a 1000cc build and discovered the “parts engine “ seized. It has a hole in the crankcase from chain failure and cam gear bolt was unreachable.
Offline Scott
  • 72 CB750
« Reply #27871 on: May 25, 2019, 06:08:53 pm »
Oh dear
Online jgger
« Reply #27872 on: May 25, 2019, 07:16:47 pm »
A little marvel mystery oil and it should be good to go!
A friend of mine once said "that's easy to fix...........all you have to do is start rubbing it with 100 dollar bills!"
Offline MoMo
« Reply #27873 on: May 25, 2019, 08:21:39 pm »
Oh dear
never seen anything worse  :( ….Larry
Offline Scott
  • 72 CB750
« Reply #27874 on: May 26, 2019, 01:37:37 am »
The barrels where persuaded off, but I don’t think they are reusable.
Here’s the tools I used.
