Author Topic: What did you do to your bike today ?  (Read 3331340 times)
Offline Gamma
  • Bike Magazine august 1980 page 71. me on my F1
« Reply #32400 on: August 30, 2023, 12:07:36 PM »
I wanted Ramair (MS006) foam socks for the velocity stacks on my CR29’s but couldn’t get any, so I’m using these.
Also fitted RG500 mirrors to the fairing
« Reply #32401 on: August 30, 2023, 01:24:02 PM »
That GS is nice! Looks long and fast
Offline spotty
« Reply #32402 on: September 05, 2023, 03:52:04 AM »
Top triple clamp from a CB900 modified by Terry to take normal bars, lower set has already been sorted to work on my K7 ( again by Terry ) so now need to get one bent fork leg unbent and then see how the whole front end looks on the bike
Thanks again to Terry
i blame Terry
Offline MisterKnife
« Reply #32403 on: September 06, 2023, 09:46:08 AM »
Oil change on my 550, noticed that the previous owner had cross-threaded the oil nut. Soo drilled it out and put in a nice helicoil.
« Reply #32404 on: September 06, 2023, 10:12:04 AM »
What oil nut?
Offline MisterKnife
« Reply #32405 on: September 06, 2023, 10:13:54 AM »
Ahhh I misspoke. Oil drain BOLT. my bad.
Then again if you can see the oil pan as a sort of nut then it's the oil drain nut.  ::)
« Last Edit: September 06, 2023, 10:15:29 AM by MisterKnife »
« Reply #32406 on: September 06, 2023, 10:20:00 AM »
  You're all wrong, it's the oil drain plug. L0L!
Offline Floshenbarnical
  • Money pit enjoyer
« Reply #32407 on: September 06, 2023, 02:14:11 PM »
I have done absolutely nothing to my bike recently other than put gas in it and ride the hell out of it. Loving every second riding the old girl
'77 CB750 SS
Offline Lucien Harpress
« Reply #32408 on: September 06, 2023, 02:37:13 PM »
Finally bit the bullet and sprung for a set of the carb top dust boots on my 70/71 CB750.  Photos and details in my project shop build thread!
-1970 CB750 K0
-1980 KZ1300
-1976 Yellow GL1000
-1965 CA77 "Dream"
-1997 Valkyrie
-1975 Velosolex
« Reply #32409 on: September 06, 2023, 04:44:55 PM »
Replaced th oil press. Switch on the Varadero with a new cb750 unit works fine.
« Reply #32410 on: September 06, 2023, 05:26:10 PM »
Received 3 new ignition coils for my other Triumph Rocket 3 and popped for an Aussie built “Ozclaw” air scoop foe the Ramair filter system. Once SPotty’s over the plague we’ll install both. Am considering some drop in cam’s from the same supplier, which, with the Ramair system, Jardine pipe and ECU reflash will give it around 190 BHP and 160 foot pounds of torque at the wheel. Should be scary fun. ;D
Offline Kelly E
  • Geriatric Hooligan
« Reply #32411 on: September 06, 2023, 06:36:51 PM »
Hey buddy, that sounds fun! I love riding big really fast bikes. At 125lbs I probably won't slow it down much. 8)
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
« Reply #32412 on: September 06, 2023, 06:49:35 PM »
Get well quick Spotty, Terry isn’t that patient…. ;)
(Joking)
But do get well quick.
Must be near elections again as they are talking about people needing to mask again…
Offline spotty
« Reply #32413 on: September 06, 2023, 06:51:35 PM »
why the hell does this keep happening with the photos ? sometimes they'll come through no problem, sometimes this happens, most often trying to download a post or photos off my phone won't work at all. is this the sohc gods telling me they're not happy with the concept of a 750 trail bike ?
i blame Terry
Offline spotty
« Reply #32414 on: September 06, 2023, 06:53:40 PM »
(Joking)
all better now ( except for no real sense of taste ) , back at work but fairly knackered
he'll have to be patient, the R3 is locked safely in my garage and there 90lb of not quite a wolfhound there to keep undesirables out of the back yard
i blame Terry
Offline Kaze
« Reply #32415 on: September 06, 2023, 07:48:39 PM »
"What did you do to your bike today?"
Put on some new NGK plug caps on the CB750, fired her up... right winker idiot light didn't come on. Spent the next hour trying to hunt down the problem with a tester light, nope. Had the whole indicator light box opened up... couldn't find a short or the problem (found a spider nest in there though). In aggrevation, I cursed out the bike, put it back together, turned the key... *&!^@ indicator lights work again.
Plug caps weren't enough it seems. She always wants more.
« Reply #32416 on: September 06, 2023, 07:51:20 PM »
She wanted to be touched, it's her love language...
Offline spotty
« Reply #32417 on: September 07, 2023, 01:05:03 AM »
CB900 triples closer to fitting
i blame Terry
« Reply #32418 on: September 07, 2023, 01:15:33 PM »
The Rocket III seems to be the popular choice for little guys, mine don’t even notice my 230 pounds, so you would love one. ;D
Offline Kelly E
« Reply #32419 on: September 07, 2023, 04:16:23 PM »
Today we installed fresh front brake pads on the 84' VF 1000F Interceptor. The outside pad on the left side wore down the nothing all of a sudden. Then we fixed the turn signal droop with some 1 1/2" dual wall heat shrink with adhesive. It will work until we get around to buying some new rubber mounts.
1983 Honda CB 1100F
« Reply #32420 on: September 07, 2023, 04:51:33 PM »
Good job Kelly, looks like new. Nothing worse than droopy indicators. Well there is, but you can apparently buy medication to fix that…. ;D
Offline spotty
« Reply #32421 on: September 08, 2023, 08:17:53 PM »
Freshly built ( and no longer bent ) forks means it's back on its own feet again
i blame Terry
« Reply #32422 on: September 08, 2023, 08:23:07 PM »
spotty,what did those long fork tubes come off of ?
Offline spotty
« Reply #32423 on: September 08, 2023, 09:18:01 PM »
As far as I know they are aftermarket chopper tubes but the could be XR600, I used a set of XR350 tubes on another bike years ago which I sold to Terry when I got rid of all my sohc stuff.
. I used to own them years ago with 750 lowers on. I bought them back a couple weeks ago. The guy I got them off also has a chopperised stockish 750 and the digger frame I also sold him. A crafty plan is brewing in my head to get the lot off him along with a stupid long springer front end. I could end up with a dirt bike, stockish chopper and a digger, a bike for all seasons ( as well as the VMAX and the royal tour star cruiser )
« Last Edit: September 08, 2023, 09:20:28 PM by spotty »
i blame Terry
« Reply #32424 on: September 08, 2023, 09:59:23 PM »
I'll venture a guess,that those fork tubes seem like XR600..  I hope you've got them a good set of internals/springs  :D
