Author Topic: What did you do to your bike today ?  (Read 3980144 times)
« Reply #32550 on: October 21, 2023, 08:03:20 PM »
Tires can drone at freeway speeds...so best to check on a couple different road surfaces...when in doubt.
« Reply #32551 on: October 22, 2023, 12:30:14 AM »
No no. Of course I cleaned it first. I'm an airhead, not retarded. ...okay I might be a little retarded.
The droning sound at 5k came at freeway speed... okay, maybe a little over freeway speed. The chain had gone dry.
When the oil arrived I cleaned the chain, lubed it, wiped that off and lubed again. I haven't been riding since I oiled it so I don't know if I fixed it.
Next time I'm out flouting the law on the freeway though, I will be listening.
The chain may be worn,which will cause a bit more vibration.
« Reply #32552 on: October 22, 2023, 12:45:09 PM »
The best chain lube I used came in a big round tin that you’d heat on the oven, and after cleaning your chain (kerosene was good back then) you’d sit your chain on top, and let it ease into the melted grease. Leave it there for awhile then carefully pull it out, wipe off the excess and hang on the clothesline until dry.
I loved that stuff (can’t remember the brand, it was English) but it worked great and could be used many times until you eventually ran out of grease. No “oil fling” all over your wheel and spokes etc, and really kept the chain and sprockets in “as new” condition. ;D   .
« Reply #32553 on: October 22, 2023, 01:31:28 PM »
Linklyfe i think Terry
« Reply #32554 on: October 22, 2023, 01:58:35 PM »
Thanks Bryan, I just remembered the brand I used was “Duckhams”. Fantastic stuff, wish I could still get it. ;D
Offline Envoy
« Reply #32555 on: October 22, 2023, 02:01:38 PM »
Successful day! Finally finished installing new points and condensers, static and dynamic timing. Plus fixed the stuck odometer.
Offline BallAquatics
  • Wrenching & Riding
    • My Life with Motorbikes
« Reply #32556 on: October 22, 2023, 04:12:33 PM »
.... I have stock airbox and filter, and an RC (Russ Collins) 4into1 exhaust on my 1974 cb750,...
Dennis...  70 SL175  71 SL100 (project)  74 CB550  79 CBX  82 Seca Turbo  2011 CBR  2012 NC700X https://motobike.us
Offline Kelly E
  • Geriatric Hooligan
« Reply #32557 on: October 23, 2023, 08:11:05 AM »
The RC muffler looks like it has a Supertrapp baffle in it.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
« Reply #32558 on: October 23, 2023, 09:08:16 AM »
Terry, Putoline do a version in uk, is that available in oz?
Can buy it and post it if you want, it says 1kg tub
Offline robvangulik
  • Honda Fourever
« Reply #32559 on: October 23, 2023, 11:55:50 AM »
I've still got such a big flat tin of grease, Quaker state in my case. Haven't used it anymore since I migrated to O-ring chains in the early eighties, but it worked great with the earlier chains!
Never got to the lifespan of O-rings though, on my CBR1000F I get over 40.000 km (25k miles) on a DID chain!
Offline Schnell
« Reply #32560 on: October 23, 2023, 05:25:41 PM »
Here's a pic of the baffle.
primary: 1974 Honda CB750
project: 1971 Honda CL350
project: 1974 Honda CB450
previous:
1975 Honda CB750
1973 BMW R90/6
1981 Suzuki GS650
1973 Honda CD175
Offline Kelly E
« Reply #32561 on: October 23, 2023, 05:29:34 PM »
Where's the stack of diffuser rings I saw in the first picture?
1983 Honda CB 1100F
« Reply #32562 on: October 23, 2023, 06:00:28 PM »
 I rolled the CB750 "Nugget" into the enclosed trailer with the Dragster for a long winters nap. I was planning to do an exhaust swap but one of them needed to get stored due to space needs.
« Reply #32563 on: October 24, 2023, 02:16:24 AM »
Hey Thanks Bryan, I found some on Ebay Oz, so I'll order some. ;D
« Reply #32564 on: October 25, 2023, 12:46:31 AM »
A little bit late, but Spotty and I spent a freezing Sunday working on my latest Triumph Rocket III that I bought a couple of weeks ago. The bike was in pretty good condition, but needed expensive new tyres, (about $1000 per set, AUD) brakes, a rubber throttle body insulator, a better seat, and an exhaust system that wouldn't fry my leg on a cold day.
Rocket III Sunday 22 October 2023 3 by Terry Prendergast, on Flickr
We raided my red Rocket for some parts because it's going the turbo path which is a longer term project, and I wanted to get the black one roadworthy ASAP. New Metzler tyres, great discs and pads, much wheel scrubbing, one fork leg was swapped out, as was the shift lever. Once we'd installed the new throttle body insulator we could finally install the "Ozclaw" air scoop that I bought for the red bike before deciding to turbo it. It looks better on the black bike anyway.
Rocket III Sunday 22 October 2023 2 by Terry Prendergast, on Flickr
I couldn't get this old duffer off the bike, so made him ride it 10 miles in the cold and wet to park it in my storage unit, and I'm looking forward to a longer ride this coming weekend. ;D
Rocket III Sunday 22 October 2023 6 by Terry Prendergast, on Flickr
« Reply #32565 on: October 25, 2023, 07:52:54 AM »
I had no idea a set of two tires could cost that much. Do they have gold flakes in them?
Nice bike!!
« Reply #32566 on: October 25, 2023, 02:25:26 PM »
When the Rocket 3 was first released in 2004 with a 240/50-R16 rear tyre (wider than the tyres on my turbo Subaru GT) Triumph had to have them specially made, by Metzler. The front is a 150/80-R17 which I think Harley may have been putting on their big cruisers by then, but unless you wanted to put car tyres on them (it’s common, called “Dark siding” and is kind of stupid, for obvious reasons) You don’t have much choice but to pony up the dough. Now Avon have come to the party (but for around the same money) as have Bridgestone. (a bit cheaper but N/A when I bought these tyres a couple of years ago during Covid)
Due to the weight of these bikes (around 800 pounds) and the huge torque of the 2300cc (or 2500cc in the post 2020 models) the rear tyres can last as little as 3000 miles, so people doing big miles on them (where they really shine as a “Power Cruiser”) are constantly replacing tyres, hence the temptation to put car tyres on the back, which of course are made in much larger numbers so a fraction of the price.
I was able to get 9000 miles out of my first set on my “In the family from new” 2007 Rocket 3, but they were pretty well buggered by then, and I only felt confident riding it on dry days. The second one I bought cheap had a car tyre on the back, and riding it 10 miles to the shop to have these tyres put on took 10 years off my life, it was “Dangerous at any speed”. With good (although expensive) tyres on one though, they actually handle pretty well for what they are. Brakes are another issue, while the Brembo brakes work very well to haul such a huge bike down from the insane speeds that they’re capable of, a set of discs and pads are shot after around 50,000 miles if regularly ridden in anger.
Spotty and I swapped them out from my red bike and we noticed that both the front and rear discs and pads from that bike had been changed, whereas the discs and pads on the black bike (with only 40,000 miles) were pretty bad. Luckily the discs and pads aren’t as ridiculously expensive as the tyres. (Unless you buy genuine Triumph/Brembo items of course)
As the red bike is a longer term project I’ll replace the brakes as the bike is closer to being finished, and eventually the tyres which are still ok for an occasional ride, but I wanted to make sure the black bike is Roadworthy both for my own personal safety, and to ensure it gets through its Roadworthy Inspection for registration. ;D
Offline spotty
« Reply #32567 on: October 27, 2023, 10:06:54 PM »
Terry very kindly finished the adaptor plate and drilled the bolt holes to size on my new disc , looks awesome and should work way better than the stock cast iron door stop it had stock, the caliper is a Braking Supermotard one, new line ( though I think I'll probably get a shorter one ) and a whole load of sexy
i blame Terry
Offline spotty
« Reply #32568 on: October 27, 2023, 10:10:57 PM »
Also tried my wet sand blasting attachment on the jet washer. Moderate success and a whole lot of mess
i blame Terry
« Reply #32569 on: October 28, 2023, 10:04:12 PM »
  I put the Ebay K0 front tire and wheel assembly on the project K0, I got lucky to find it relatively cheap. I was going to put the early forks on it too but what I've read a late K0 should have the K1 type forks. It's got a 71 title anyway. I cut off the old tire and stored the K3 wheel.
  Next up, more tire and wheel swapping.
« Reply #32570 on: October 28, 2023, 11:19:25 PM »
Built the back wheel back up again on my small Honda.
I had completely disassembled it,then sent the rear hub out to a machinist who's affiliated with Michael Morse over at vintagebrake.com(Sonora,Ca.)who has done this procedure before;had the rear inner cast iron drum lining replaced,then installed new Ferodo shoes and new NTN bearings.
I spent some time with these two wheels(gradually and evenly increasing the spoke tension on every one,until I was satisfied)on my 'truing stand' and trued both it and the front wheel to where they're both laterally and radially True.   Happy Wheeling  :D
« Last Edit: October 29, 2023, 09:10:34 AM by grcamna2 »
« Reply #32571 on: October 29, 2023, 12:39:02 AM »
I was really lucky when I found a minty K0 front wheel and disc on Ebay USA advertised as a K3 front wheel for $80 USD back in around 2019, before I found the remains of a 1/70 K0 in Queensland in 2020, that became the basis of my Redneck K0 restoration. The back wheel needs the rim rechromed and new spokes so I’ve got a K1 rear wheel on it, but one day I’ll get the original wheel restored and install it. ;D
Offline Schnell
« Reply #32572 on: November 03, 2023, 06:16:45 PM »
Last week I installed an Atlas throttle lock so I can take a break and rest my wrist on longer trips.
Today I added fuel stabilizer and rode around the neighbourhood to get the stabilized gas into and through the carbs.
Sadly, I think riding season is over here in Ontario.
previous:
1975 Honda CB750
1973 BMW R90/6
1981 Suzuki GS650
1973 Honda CD175
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #32573 on: November 04, 2023, 11:39:31 PM »
Started assembling and making some minor changes on the raked CB, then realized after a half hour search I have lost the cover plate for the electric box I built...
So I made template for it to make and work and.........
The I forgot that at home...
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
« Reply #32574 on: November 05, 2023, 06:55:42 AM »
Went out late yesterday and I think you are right!
