Author Topic: What did you do to your bike today ?  (Read 3979678 times)
« Reply #32600 on: November 21, 2023, 08:49:32 PM »
Built a wheel with new spokes for the K6.
John, I missed your picking up another bike to build...
Or, that you are rebuilding/refreshing a K6. Nice looking bike!
Who makes your wheel truing stand? Solidly built unit you have.
That K6 should keep you out of trouble for a while. ;)
David
David…… The K6 has been sitting in my shop longer than I thought! Check it out in “Project Shop” section. I bought the stand several years ago, from a local website. I think it was KapcoMoto.com. They were on sale at the time. Great for balancing too.
« Last Edit: November 21, 2023, 08:53:30 PM by BenelliSEI »
Online grcamna2
« Reply #32601 on: November 21, 2023, 09:20:08 PM »
John,I have the same wheel balance/truing stand.
I have tried sitting a wheel on there for truing using the 2) large fine thread bolts which screw into both sides of it,down a bit lower;I found those 2) pointy cone pieces which sit on the end of each large/fine thread bolt didn't hold the wheel(inside the bearings)as well as just sitting the wheel on the top where the bearings roll. The truing works well now.
The stand does excellent for balancing with very smooth bearings.
« Last Edit: November 21, 2023, 09:24:25 PM by grcamna2 »
« Reply #32602 on: November 22, 2023, 06:11:16 AM »
The two shafts that thread into the vertical legs have been sitting in a drawer, since day one. I also find them useless! The top part does everything perfectly. I’m sure there is a use for those bits, we just haven’t figured it out?
« Reply #32603 on: November 22, 2023, 06:53:28 AM »
Mine has a simple pointer which is ok for getting started but I later install a mag base dial indicator for fine tuning.
Online grcamna2
« Reply #32604 on: November 22, 2023, 08:29:49 AM »
I'm also going to remove them and put them in a bag/box in storage.
« Reply #32605 on: November 22, 2023, 08:50:05 AM »
 I bought a similar stand off of ebay, but I just got the balance version. It has the top shaft and cones only, and then made my own pointers. I also have a mag base dial indicator. Cheap and effective.
« Reply #32606 on: November 22, 2023, 04:03:40 PM »
Wil a normal chromed steel rim a dtinis overkill
Offline jonda500
« Reply #32607 on: November 22, 2023, 06:47:57 PM »
With a normal chromed steel rim a dtinis overkill
+1
I have found some blue-tac and two bamboo skewers can do a perfectly acceptable job. After lacing on the rim on I just put the wheel back in the bike and blue-tac skewers to the forks or swingarm, one either side of the rim pointing to the rim corner. Flipping the wheel over several times throughout helps me ensure the skewer ends and rim are centred and not offset to one side.
John
A starter clutch thread:
Online newday777
« Reply #32608 on: November 23, 2023, 05:31:56 AM »
« Reply #32609 on: November 23, 2023, 07:41:55 AM »
Sorry, my dumfone is playing up, i meant a dti is overkill, Honda spec is in mm not thou and the weld "kick" will drive you crazy as it cant be trued out
« Reply #32610 on: November 23, 2023, 08:47:14 AM »
...did the gauge thing to make them like new again.
Look really good!!
I have a Swedish K2 in need of beautiful gauges, kmh speedo! ;D ;D
I have a set to rebuild.
I have new glasses, o-rings, upper black cover and new faces I painted the rear side on to ensure no light thru as stock
The new rings really hard. I need a good tool for crimping them.
« Reply #32611 on: November 23, 2023, 08:50:02 AM »
Nice, wish I could do that to mine........darn needle broke off.
I have an old gauge where needle came loose with the axis ...
Next time it sit hard I'll warm it.
« Last Edit: November 23, 2023, 08:59:31 AM by PeWe »
« Reply #32612 on: November 24, 2023, 07:02:04 AM »
Steve…… I’ve checked a few wheels when I pulled them from the bikes. Some had as much as 3/16” of run out and “bounce” and rode just fine.
I just use the stick and when I see less than 1/8” run out, I pull them all a bit tighter and I’m done. With a skinny new tire and an ancient (not so skinny) rider: all good.
« Last Edit: November 24, 2023, 07:05:28 AM by BenelliSEI »
Offline fire113
« Reply #32613 on: November 24, 2023, 02:16:20 PM »
Those are stunning! How do you get such a perfect “crimp”?
..thanks al lot  :)  After several Years of trying I bulid a machine to be able to close the ring like in the picture.
Offline fire113
« Reply #32614 on: November 24, 2023, 02:18:52 PM »
...thx again :) if the needle broke off, the machanic is toast, there is no way to fix it.
Offline fire113
« Reply #32615 on: November 24, 2023, 02:23:34 PM »
Look really good!!
...thank You and as I wrote before, I build me a machine to cloes the rings but if the axis is snapped off it is impossible to fix it.
« Reply #32616 on: November 24, 2023, 02:29:26 PM »
 I pulled the front wheel, touched up the paint and removed the very nicely stopping disc brake and put on dual discs and a modified speedo drive. I turned the wheel and it made a chain/sprocket type noise. I thought a bearing was bad or the speedo drive was in a bind. Nope, it was the tread of the tire rubbing on the wheel clamp L0L!
 I took a brake break before attempting to install the silver F1 and A calipers. The one that was on it moves to the turbo drag bike's frame.
 I went back out to try the caliper brackets, The right side unused hole has a mud dabber nest in it. A little tapping with a tap, WD40, brake clean, and determination got it most of the way open. There is a little more to go. I'm going to try to mount over the fender brace and see what it looks like. The last time I went under because I thought I had to.
« Last Edit: November 24, 2023, 03:36:09 PM by Don R »
Online newday777
« Reply #32617 on: November 24, 2023, 03:49:13 PM »
How about sharing pictures of the machine and how it works
Offline bigutah
« Reply #32618 on: November 25, 2023, 12:29:43 PM »
Oil change, requires removal of one of the pipes. Light carb adjustment due to cold temps. JMR 1k motor is coming along well.
« Reply #32619 on: November 25, 2023, 09:08:05 PM »
How does a machine close the crimp to look professional factory work?
How much to fab such a machine? I've got a gauge or two needing refreshed and dampner pot filled with silicone oil.
Offline spotty
« Reply #32620 on: November 26, 2023, 11:56:42 PM »
Got the new fuse box today so I worked out where I wanted it, leaving room for the flasher can next to it, drilled some holes, couple of M5 S/S bolts and lock nuts, sorted. The solid state rec/reg goes on the back of the battery box and the battery will be rubber isolated
i blame Terry
Offline spotty
« Reply #32621 on: November 26, 2023, 11:59:54 PM »
The fuse box is a simple but clever design. Power straight in from the battery, 4 fuses and outlets, LED indicators to tell you if the fuse has blown. And of course modern blade fuses, I searched for mini blade fuses but couldn't find a stand alone unit.
i blame Terry
Offline spotty
« Reply #32622 on: November 27, 2023, 12:05:11 AM »
This is what I might use instead of a key, it's bigger than I expected from the eBay pictures. It's ,again, a simple solution and has a cap to cover the 'key' hole .
I'd like to have just used an on/off flick switch but not the most secure option.
So the theory is power from the battery ( it's a small one as there's no electric start ) into and out of this isolator then into the fuse box
i blame Terry
Offline spotty
« Reply #32623 on: November 27, 2023, 12:15:30 AM »
I don't think I put pictures up of the chain guard I made, 25 x 3mm steel , cut, bent and welded. The welds are on the underneath so it looks pretty good I reckon. Painted in grey primer, satin black then aluminium.
It'll get a/s Allen bolts later
i blame Terry
« Reply #32624 on: November 27, 2023, 05:54:04 PM »
What’s the question??
