Author Topic: What did you do to your bike today ?  (Read 3979769 times)
Online newday777
« Reply #32725 on: January 15, 2024, 11:07:52 AM »
Ebay item 364627612563, and 184022276167.
These are on ebay uk and no i cant do links
What are they??
Online bryanj
« Reply #32726 on: January 15, 2024, 12:04:52 PM »
One is jis imact driver bits the other is a T handle driver with removeable jis bits, go to ebay.co.uk and put in item number.
If anybody wants them and cant order direct i am happy to be a middle man at cost
Offline Kelly E
  • Geriatric Hooligan
« Reply #32727 on: January 15, 2024, 01:30:28 PM »
Recently I had to install a new set of case cover screws on the 81' Suzuki GS 1100E. So I decided to try out the DeWalt cordless 1/4" impact with a JIS bit. We've been using the Vessel Impacta screwdrivers to remove the screws. Sometimes it takes a while to get the screws loose with the Impacta's and penetrant.
I only had gotten one screw loose so far when I broke out the DeWalt. I finished the entire job in 30 minutes. I had always been hesitant to use it for fear of stripping the screw heads. After that I used it to pull off the case covers with the stuck screws on the 78' KL 250 with the same results.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Online grcamna2
« Reply #32728 on: January 15, 2024, 02:37:55 PM »
The Dewalt make a nice cordless;tough to beat the variable speed with a job like that.
Does it also have Hi & Lo speed final gearing ?
Online grcamna2
« Last Edit: January 17, 2024, 09:00:43 PM by grcamna2 »
Offline bigutah
« Reply #32733 on: January 17, 2024, 08:28:03 PM »
The spigot is at the bottom of the switch wire, bolted to the Tarozzi brake lever
It’s my 750F1 project bike.  I’m probably one of the few people that changed the rear disc brake back to drum brake with cable operation
You’re forgetting every CR750 out there! Lol
Offline smee
« Reply #32735 on: January 21, 2024, 02:57:27 PM »
We had a nice warm day (50F) here in Golden, CO after the frigid temps we endured not long ago. These are some shots from Lookout Mountain (7,377 ft). It's a nice little ride up out of town and comes with a great view. Nice to get the bike out.
« Last Edit: January 21, 2024, 03:00:18 PM by smee »
Offline spotty
« Reply #32736 on: January 25, 2024, 05:06:51 PM »
Made the 4th version of the dash for the trail bike
i blame Terry
Online grcamna2
« Reply #32737 on: January 25, 2024, 05:46:09 PM »
I like that view smee  8) 8)
Offline smee
« Reply #32738 on: January 26, 2024, 06:16:19 AM »
Spotty, this is cool. It's got a Jetsons futuristic feel to it.
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #32739 on: January 26, 2024, 06:24:23 AM »
Not today but yesterday cleaned the shop up a bit and put the carbs and cables on. (Another issue with aftermarket throttle and the cable)
Bike wouldn't kick to life. Picked up a can of "ether" spray the 4 carbs and it fired up.... turned out it was a can of brake parts cleaner where I usually set the starting fluid. Going to put new gas in it today and try to figure out what's up. Only thing that's changed since this motor last ran is the coils.
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
Offline smee
« Reply #32740 on: January 26, 2024, 06:27:20 AM »
It is a nice little ride and view. I feel very fortunate to have it so close. I should put a higher res photo up. In the distance is the Coors plant :D
« Reply #32741 on: January 26, 2024, 06:44:14 AM »
I bet it was still pretty cold at speed, nice photos.
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #32742 on: January 26, 2024, 08:34:57 AM »
Fresh gas and realized the throttle cable was holding the carbs open a little. Fired right up. Turn screws to 2 turns out.
Now for idle jets filters and a retune.
No clutch though. I know I'm getting enough pull at the cable so I'm unsure if the plates are just sticking or what.
Online grcamna2
« Reply #32743 on: January 26, 2024, 12:07:45 PM »
Did the plugs foul ?
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #32744 on: January 26, 2024, 09:00:19 PM »
Turned out the throttle cable has the carbs pulled too far open.  Adjusted too tight.
Offline spotty
« Reply #32745 on: January 27, 2024, 05:15:59 PM »
'bear claw' foot pegs done
i blame Terry
Offline spotty
« Reply #32746 on: January 27, 2024, 05:17:54 PM »
How it's looking at the moment
i blame Terry
Offline spotty
« Reply #32747 on: January 27, 2024, 07:44:36 PM »
Side covers pretty much done
i blame Terry
Offline WhyNot2
  • I'm finally an
« Reply #32748 on: January 28, 2024, 05:36:49 AM »
I like all the mods done here. Especially the exhaust header clamps.
Do they do the job? No leaks? Where did you source them?
Offline Kelly E
« Reply #32749 on: January 28, 2024, 09:27:16 AM »
I finally got the 78' KL 250 gas tank to the EvapoRust stage after spending 2 days scraping and scratching to remove the fibreglass resin that the PO tried to line the tank with. He didn't clean it first and it was peeling, flaking and coming off the bottom in chunks.
It's the last big task before we try to start it.
1983 Honda CB 1100F
