Author Topic: What did you do to your bike today ?  (Read 3241662 times)
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #33325 on: November 27, 2024, 12:03:22 PM »
Wolfe those are looking great.
If you did do a hidden stud in the cap to screw on a dipstick what would be the chance of the dipstick unthreading and falling off?
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
« Reply #33326 on: November 27, 2024, 12:58:25 PM »
yeah like that newday the thin metal cap formed onto the dipstick tightly unlike these caps im working on. I would have to find something to keep it attached to the dipstick so throwing some ideas out there maybe a bolt that the cap would screw on would be nice.
You could then use a small ny-lock nut to hold the dipstick tight;wouldn't back off.
Offline wolf550
« Reply #33327 on: November 29, 2024, 01:39:15 PM »
thats a good idea grcamna2 I have to see what will be the best option once they are made.
74' CB550 (Sold)
71' CB500/550 (Sold)
Offline wolf550
« Reply #33328 on: November 29, 2024, 03:37:22 PM »
Bert here's the other I thought it was 5 fins but it's 7 my bad
74' CB550 (Sold)
Offline spotty
« Reply #33329 on: November 29, 2024, 05:38:41 PM »
Pretty much got the dash how I want it. Not sure if it's going to be legal as I may have to have an odometer for roadworthy.
Bit more cleanup of edges and I'm thinking wrinkle finish black paint
i blame Terry
Online newday777
« Reply #33330 on: November 29, 2024, 05:40:07 PM »
Those stick up a lot. Those might burn a leg on hot summer days.
Today I fired up my K5 to take it out and warm it up to drop the oil for it's winter's nap. 42° this afternoon's high so I had to bundle up for a 15 mile ride at 50 mph, so the wind chill was @11°. I had to stop and pull up my neck wrap at the turn around as my mouth and nose were very cold. Winter is settling in here, only going to be in the 30s next week.......
Offline wolf550
« Reply #33331 on: December 04, 2024, 06:27:13 PM »
sits pretty flush
let me know what you think.
74' CB550 (Sold)
Offline wolf550
« Reply #33332 on: December 04, 2024, 06:39:24 PM »
hey gurp didnt see your post. I think if you did a bolt with threadlock it should be good. I still like the magnets but will have to give it a go.
74' CB550 (Sold)
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #33333 on: December 04, 2024, 11:20:31 PM »
Or better yet threads on a bolt and has a hole in it for a cotter key. I know that heat is how you remove or disable lock type but I'm not sure where that property based on heat begins. It requires a little bit of research.
Offline bert96
  • past ride
« Reply #33334 on: December 05, 2024, 01:09:29 AM »
sits pretty flush
Wow wow wow!!!
Bert
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
Offline wolf550
« Reply #33335 on: December 05, 2024, 01:07:57 PM »
on the inside of the cap that attaches the dipstick theres all the components that screw on snug to the oil can. I bet you could tap that area and do a die bolt that connects to the cap or just keep enough material to lathe it on. that is why I miss frank. I could ask him to make me some of his starter delete plugs but bigger for this problem.
74' CB550 (Sold)
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #33336 on: December 05, 2024, 01:48:32 PM »
That is a heck'n good idea have the whole thing machined out of one piece and then file your design on top or figure out how hard it would be to achieve adhesion between the cast piece and the machined depart.
Offline wolf550
« Reply #33337 on: December 06, 2024, 01:35:32 PM »
that was kind of what that bump on the inside was going to be for but I think it would be good to try something with 3d print as to make it the right specs.
74' CB550 (Sold)
Offline wolf550
« Reply #33338 on: December 08, 2024, 05:35:29 PM »
worked on this one but Im finding out the thickness is too thin on the wall so I am going to beef it up some. also looking at the thickness of the top I can probably file it down another 1/8 " more to make the cap less top heavy.
74' CB550 (Sold)
Offline bert96
  • past ride
« Reply #33339 on: December 09, 2024, 12:39:01 AM »
 Look pretty good.
 Bert
« Reply #33340 on: December 09, 2024, 01:04:31 AM »
 Look pretty good.
 Bert
Your avatar looks better  ;D the woman has a very strong zipper  :D
Offline bert96
  • past ride
« Reply #33341 on: December 09, 2024, 06:36:03 AM »
That's an understatement !
Bert
« Reply #33342 on: December 09, 2024, 01:17:30 PM »
Bert
Lol  ;D
« Reply #33343 on: December 11, 2024, 09:16:19 PM »
 I set up my shop chair next to the lift and spent a few hours sorting out a cake pan full of used Honda hardware. As always, I found a few unknown parts and a few things that I know I'll use. Headlight hardware, turn signal grommets, bowl drain screws, a float pivot pin, fiber washers, etc. It's always a pain but worth it.
 When I bought out a collection of Honda stuff from a friend I ended up with a full tote of things to sort. It took several nights but I found 3 of the ignition switch tabbed washers that were worth the time spent by themselves. Lots of usable stuff but most of it was junk.
« Reply #33344 on: December 12, 2024, 05:29:24 AM »
Those tabbed washers for the ignition switch are almost always MIA! Still missing one for the S/C!.
