Author Topic: What did you do to your bike today ?  (Read 3751007 times)
Offline Kelly E
  • Geriatric Hooligan
« Reply #33425 on: July 19, 2025, 07:40:43 PM »
Today we got the new pistons in and the cylinders on without screwing up anything. Even got the cam chain tensioner and guide installed correctly. 8)
Hopefully next week we'll get the rest of the assembly done. I don't know if a 1mm over bore will add any extra performance and I only rode it once before it started having issues so I have nothing to compare to.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Online newday777
« Reply #33426 on: July 19, 2025, 08:45:17 PM »
I went over to a friend's house and used his sand Blaster on a couple seat pans that had a bunch of rust.
A 78F and a 73K3.
Offline Kelly E
« Reply #33427 on: July 24, 2025, 03:26:09 PM »
Today we installed the cylinder head and cam on the 74' CB 550. Tomorrow I'll retorque the head and install the valve cover. Hopefully Saturday we'll get the carbs on.
1983 Honda CB 1100F
« Reply #33428 on: July 24, 2025, 04:03:56 PM »
The fins are looking very clean on this engine.
Offline Kelly E
« Reply #33429 on: July 24, 2025, 05:49:25 PM »
That's because I smoothed every fin by hand with a file. Sometimes I get carried away. 8)
1983 Honda CB 1100F
Offline Oly
« Reply #33430 on: July 24, 2025, 05:57:48 PM »
Fins look better than new!!
1971 CB750 K1
1967 BSA 441 Victor
1966 Yamaha 250cc YDS3c Big Bear Scrambler
Offline Kelly E
« Reply #33431 on: July 24, 2025, 06:04:49 PM »
Thanks
1983 Honda CB 1100F
Offline Oly
« Reply #33432 on: July 25, 2025, 06:32:09 AM »
Yesterday I found something I have no knowledge of and got new pistons and rings into the +0.050 over bored jugs from Hondaman.
Tomorrow...install rebuilt head and Cam Assembly hardware.
If anyone has experience with the  Cam tower bolts and the impressions I see from the semi-circle cut out in the rocker shafts I'd appreciate any and all feedback.
1971 CB750 K1
1967 BSA 441 Victor
Offline toomanybikes
« Reply #33433 on: July 25, 2025, 02:34:04 PM »
bled the front brakes, sync'd the carbs, mounted the tank
and then ...
took her for a maiden voyage for all of a 1/4 mile (two trips to the nearby cul de sac) since the rear brakes are not yet functional. Other than that, everything worked.
current stable, always subject to change ...
'22 MG V85TT
'19 Triumph Scrambler XC
'10 BMW R1200 RT
'81 Honda GL1100
'78 Honda CB750F SS
« Reply #33434 on: July 26, 2025, 05:03:25 AM »
and then ...
Congrats!
Offline fire113
« Reply #33435 on: July 30, 2025, 08:19:29 AM »
Rode my K2 and fixed some issues ( front brake, indicator light, brake light switch ...) at the cb500 that my friend can pass the tecnical inspection.
Offline Kelly E
« Reply #33436 on: August 02, 2025, 03:57:47 PM »
Today I got around to checking the head bolt torque, got the valve cover on and set the valve clearances.
1983 Honda CB 1100F
Offline fire113
« Reply #33437 on: August 02, 2025, 04:53:09 PM »
The hd-primary chains arrived
Offline WhyNot2
  • I'm finally an
« Reply #33438 on: August 03, 2025, 06:07:31 AM »
Went for a ride after shortening the rear fender.
CB550 front forks and swing arm, shorty shocks.
I'm 212, and did not rub a bit. Rode good enough for me.
« Last Edit: August 03, 2025, 06:17:08 AM by WhyNot2 »
« Reply #33439 on: August 03, 2025, 01:45:49 PM »
Your 550 is looking very good Kelly;is that Dyna ignition ?
« Reply #33440 on: August 04, 2025, 03:29:57 AM »
It looks like a Dyna-S.
Make sure that the wires are strapped down away from the rotor with nut.
Insulation will shave off quickly and a short with sudden stop can happen.
I learned the hard way ;D
Offline Kelly E
« Reply #33441 on: August 04, 2025, 08:50:19 AM »
It's a Dyna S, the wires are not close to the nut. The ignition came with the bike when I bought it. One hard chore left to do, install the carbs.
1983 Honda CB 1100F
Offline fire113
« Reply #33442 on: August 06, 2025, 04:01:28 PM »
...parts and tools arrived
Offline Killer Canary
  • Typical Bran Muffin
« Reply #33443 on: August 06, 2025, 04:39:29 PM »
I machined a pair of spring keepers from 3" aluminum rod.
I got sick of looking at the old ones so why not. ;D
Kawi GPz900, H1
« Reply #33444 on: August 07, 2025, 10:51:27 AM »
Nice job!
« Reply #33445 on: August 07, 2025, 10:55:58 AM »
Time for new sprockets and chain for the cb750K3. Sprockets totally worn out and the chain was snagging and noisy. Checked my notes and never replaced them. Had the bike for almost 15 years…… My bad.
« Last Edit: August 07, 2025, 11:35:29 AM by BenelliSEI »
« Reply #33446 on: August 07, 2025, 11:03:00 AM »
.....since it's off, gave the 18" Lester a good scrub.
Online newday777
« Reply #33447 on: August 07, 2025, 02:28:24 PM »
Nice
While it was off did you pull the drive flange out to inspect the rubber dampers and clean out the old grease from the bearing (it's open to the wheel side) and put fresh grease in the bearing? That will make a seemingly bad bearing come back to and extend it's life. I just did that to a wheel for the K6 project.
« Reply #33448 on: August 07, 2025, 03:12:00 PM »
Mmmm, Lesters. 8)
Kawi GPz900, H1
« Reply #33449 on: August 07, 2025, 04:37:31 PM »
Nice
Stu….. I did. Pried it off with a 4’ length of 2” X 4” lumber, before I unbolted the old sprocket. It looked so clean, I just banged it back into place.
