Author Topic: What did you do to your bike today ?  (Read 3209361 times)
0 Members and 22 Guests are viewing this topic.
Offline mrbreeze
  • Not your average
« Reply #4125 on: November 24, 2010, 11:09:04 PM »
Made my very own mono or mano meter for syncing the carbs.  Didn't really work, but did notice fuel pouring out of one of the carb air intakes  :o .  At least this means i get to spend more time getting to know my carbs tomorrow  ;D
Have a Happy Thanksgiving Everyone!
Stick with it bro.......you can never be disapointed when it dials in to the sweety spot and you go for that first blast.....you can't wipe the smile off yer face!!!!!
MEMBER # 257
Offline going4speed
« Reply #4126 on: November 25, 2010, 09:28:26 AM »
Looks awesome.  What paint did you use on the motor?  :o
Reinstalled the brake pedal and linkage, hooked up the clutch cable, observed that the PO routed all the control cables wrong, cleaned up the oil lines, took apart the kick start lever to clean it up and promptly dropped the rusted ball bearing.  Spent 10 minutes looking for the ball bearing on the shop floor.  Mostly found that I really need to sweep..   Then I took apart another lever to get another ball bearing.
And lastly mated the shiny carbs to the shiny motor.
Online CycleRanger
  • No comment about being an
« Reply #4127 on: November 25, 2010, 06:14:10 PM »
Thank you.  I used the Duplicolor hi-temp silver.  Just the case. The jugs are "natural".
I mention that it's really shiny now only because I know this is as good as it will ever look.... :-\
After I changed the brake shoes on the back of the truck this morning I messed with the wiring on the CB for a bit.
I got some shrink tubing but it's too small for my needs.
I think I'm going to order a new connector plug for the alternator pigtail so I can replace the shredded fabric covering.
Offline Tintop
« Reply #4128 on: November 25, 2010, 06:31:15 PM »
You can remove the plug case quite easily.  A small jewller's screw driver will release the tab that locks the socket/blade in place.  Makes it easy to make sure everything is nice and clean on reassembly.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Online CycleRanger
« Reply #4129 on: November 25, 2010, 06:47:07 PM »
You can remove the plug case quite easily.  A small jeweler's screw driver will release the tab that locks the socket/blade in place.  Makes it easy to make sure everything is nice and clean on reassembly.
Yes, I already have the old plug off but it's pretty brittle and cracked.
Offline Tintop
« Reply #4130 on: November 25, 2010, 07:29:33 PM »
Vintage Connections has exact match replacements (also sockets & blades).  I used them on my build, OEM quality and fit.
77 CB550 Cafe build
Online CycleRanger
« Reply #4131 on: November 25, 2010, 08:41:31 PM »
Heh, just came from there.   Yep, they've got the stuff I need.
Offline going4speed
« Reply #4132 on: November 26, 2010, 06:37:38 AM »
Did you find a replacement for the fabric covering?  I am knee deep in harness rework right now myself.
Offline fire113
« Reply #4133 on: November 26, 2010, 10:52:30 AM »
... have all covers polished, the gas tank is fresh sealed and ready to paint :)
Offline Tintop
« Reply #4134 on: November 26, 2010, 12:52:40 PM »
Very nice, nothing like the gleam of freshly polished alloy.
77 CB550 Cafe build
Offline fire113
« Reply #4135 on: November 26, 2010, 02:49:06 PM »
...thx tintop, forgot the gas tank picture and YES!!! fresh polished alloy is looking real good.
Offline tango911
« Reply #4136 on: November 26, 2010, 04:28:54 PM »
stripped it down to frame and front end. almost ready for the sand blast and powder coat.
CURRENT STABLE:
1969 Honda Dream 305 (black)
1974 Mach III kawi 500 smoker
K2 (project)
K2 Original fixer up
K0 original fixer up
2006 CRF250R
« Reply #4137 on: November 26, 2010, 04:34:14 PM »
Bought some new ribbed side covers of Frankenstuff......Thanks Joe....
Offline Tintop
« Reply #4138 on: November 26, 2010, 06:21:19 PM »
OK - envy, envy, mine are just the plain ones. ;) :)
77 CB550 Cafe build
« Reply #4139 on: November 26, 2010, 06:37:18 PM »
I have brand new plain ones as well......you can never have too many options.... ;D
« Reply #4140 on: November 26, 2010, 06:53:17 PM »
The plain ones are faster, too much turbulence from the ribbs.  (Seeing as how I just bot the smooth ones).   ;)
« Reply #4141 on: November 26, 2010, 07:29:00 PM »
Its kinda lika a golf ball mate, the ribs reduce surface tension and increase speed....... ;D   That's my story and i'm sticking to it.... ;D ;)
Offline Tintop
« Reply #4142 on: November 26, 2010, 07:52:08 PM »
So if a get a ribbed one for the right side only, does that mean it will start drifting right?
77 CB550 Cafe build
« Reply #4143 on: November 26, 2010, 07:54:31 PM »
"So if a get a ribbed one for the right side only, does that mean it will start drifting right?"
Yup.
Offline FrankenFrankenstuff
    • FrankenBike Stuff Store
« Reply #4144 on: November 26, 2010, 08:51:56 PM »
Using "just the right" is a race application, for streetriding you will need both....for balance. ;D ;D
« Reply #4145 on: November 27, 2010, 01:32:01 AM »
I just paid Joe for 2 sets of ribbed sidies, and now I hear a rumor about an "Uber Cool" new top secret sidecover that will apparently make us drool like imbeciles and have us sending him more money, damn you Joe, I was trying to save some money! Oh well, so what if I can't afford to eat, I need to drop some weight anyway! ;D
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #4146 on: November 27, 2010, 07:23:56 AM »
Finally replaced the sticky rear brake light switch on the 500 with an emgo.
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #4147 on: November 27, 2010, 11:44:34 AM »
Nothing yet, but I just lit the wood stove, so it won't be long ;D
Offline my78k
« Reply #4148 on: November 27, 2010, 12:33:05 PM »
Wood stove?!?!!?? Is it below 15 or 20 degrees Derek???  ;)
Dennis
Offline Magpie
« Reply #4149 on: November 27, 2010, 04:28:54 PM »
Put the seat on. Cliff.
