Author Topic: 1979 cb650 oil light issue  (Read 3002 times)
Offline MMICAFE
« on: November 11, 2009, 12:43:11 PM »
ok this is the first time i have really had this problem and i dont like it. im out on a little ride then i go to pick up some tail light bulbs for my bike and on my way back home my oil light comes on. i get home check the oil, it is a little low so i top it off. then i let it run a little bit but the light stays on. some one please let me know whats up i know i have the right amount of oil but the light is on. could it just be a wire or is the sensor messed up? please let me know asap
1974 Honda CB450 super sport (sold sniff sniff) (my first bike)
1979 Honda CB650 (we have a love hate relationship)
2008 Honda metropolitan (sold kinda miss it for the gas mileage)
Offline mark
Re: 1979 cb650 oil light issue
« Reply #1 on: November 11, 2009, 01:07:22 PM »
It's a 30 year old bike. Lots of stuff can go wrong.
The switch can go bad.
If the wire is grounded anywhere between the switch and the light..... voilá! a little red light that stays on.
If it isn't one of those, you probably wouldn't have got home.
F you mark...... F you.
Offline cb650
« Reply #2 on: November 11, 2009, 04:19:26 PM »
Mine went on on the race bike once.  Paniced and switched bikes. got home and it was just the sensor.
Offline w1sa
« Reply #3 on: November 11, 2009, 05:14:13 PM »
Disconnect the wire at the oil pressure switch. If the warning light stays on, you've got a problem in the circuit back to the bulb.....if it goes out check/replace the oil pressure switch (sender).
If the warning light stays on (engine running) with a new switch, you've most likely got an oil pressure problem, and better get it tested.
Offline MMICAFE
« Reply #4 on: November 11, 2009, 06:09:54 PM »
well i just went out and checked everything finally and the light is off and all is well
« Reply #5 on: November 11, 2009, 10:24:48 PM »
Remember light has nothing to do with level its for pressure
Offline MMICAFE
« Reply #6 on: November 12, 2009, 08:53:04 AM »
thanks for the tip bryanj
