Check very carefully the rubber skirt of the plunger, I had one with a split in it, they spew gas when that splits.
Oh yeah and one thing I gotta admit I screwed up was putting the plunger spring on the wrong side of the plunger rod, it don't work like that either
![Grin ;D](http://forums.sohc4.net/Smileys/default/grin.gif)
must go UNDER the plunger to give it lift lol.
As I have said, there are only 3 reasons your carbs will overflow:
1) the float valve is not sitting right (and this could be some rust etc coming down the fuel line and stopping them seating properly).
2) Incorrect float height adjustment, but I don't believe the new plastic floats are adjustable.
3) The tiny "O" ring above the accelerator pump has failed allowing cross flow of gas to air filter and forward to engine valves.
If you have them all covered I can't think of what else would be doing this to you.
