Author Topic: Need to minimize current draw on my 750...  (Read 2003 times)
Offline grumpy
  • ..... '73 750K3 .....
« on: November 16, 2009, 01:16:24 PM »
... because I need to be able to power some heated gloves!! My hands are FREEZING!!
Looks like I need 27 watts, 2.2A to power some gloves.
So LEDs for tail/brake running/signal will save some power. What else can I do??
Hell, maybe I'll just carry a 2nd battery for the AM commute & throw in on the charger at night....
I need to do something!
« Last Edit: November 16, 2009, 01:23:41 PM by grumpy »
Re: Need to minimize current draw on my 750...
« Reply #1 on: November 16, 2009, 01:43:50 PM »
Actually that second battery may be the easiet solution. I spent two years in your area and please take this the right way, it ain't that cold there.  ;D
Offline grumpy
« Reply #2 on: November 16, 2009, 02:04:11 PM »
... please take this the right way, it ain't that cold there.  ;D
Yeah - I know, I'm from Wisconsin. I've lived thru -17F. But dammit my hands were too cold to work my helmet strap after my 40min ride in this morning in 34deg.
« Reply #3 on: November 16, 2009, 02:18:59 PM »
I know, I am just breaking you shoes. It is a NY thing and one of the reasons we are loved around the country. A small battery may do the trick.
Offline grumpy
« Reply #4 on: November 16, 2009, 02:28:43 PM »
...one of the reasons we are loved around the country.
indeed  :D
27v at 2.2w tho... I might be able to squeeze that out of the bike. I mean, that's like half a low beam headlight. Or roughly the equivalent of turning on the brights, no?
Offline mystic_1
  • 1970 CB750K
« Reply #5 on: November 16, 2009, 03:14:10 PM »
Wait, 27V or 27W?
27V may be problematic to obtain without some electronics :)
27W should be attainable by changing out all the bulbs as you've said.
Your standard 1157 bulb is what, 8 watts low, 23 watts high.  1156 are like 5W-8W.  Don't forget your instrument backlights.
Lots of potential wattage savings there.
mystic_1
- John Augustus Shedd
Offline grumpy
« Reply #6 on: November 16, 2009, 03:17:04 PM »
D'OH!!!
27W at 2.2A
Yeah, 27v would be difficult to come by!
« Reply #7 on: November 16, 2009, 05:00:59 PM »
D'OH!!!
27W at 2.2A
You actually originally said 27 watts. If I were you I would out a voltmeter on the battery an plug in your gloves run the motor up to 3K and see what you get. If you are in stop and go traffic it could be a problem since the alternator is piss poor at idle. I adjusted my regulator up a notch at low idle but it is not great at long lights.
Offline the technological J
  • deliciouso!
« Reply #8 on: November 16, 2009, 05:08:11 PM »
i dunno the draw of heated grips by why not go that route if u havnt already purchased the gloves?
94 ST1100..Gone
72 750 K2 Stay tuned!
Offline Gordon
  • 750K1, 550K2
« Reply #9 on: November 16, 2009, 05:18:30 PM »
+1
My heated grips only use 14 Watts, or at least that's what they say.
Offline grumpy
« Reply #10 on: November 16, 2009, 10:10:34 PM »
Do heated grips help much?
The gloves I'm looking at have a coil woven over the whole surface area (vs. just the underside as in grips)
  • deliciouso!
« Reply #11 on: November 16, 2009, 10:17:51 PM »
its what is most commonly used on snowmobiles... but i have no experience with either
94 ST1100..Gone
Offline Gordon
  • 750K1, 550K2
« Reply #12 on: November 17, 2009, 01:33:47 AM »
They work great for me.  Keep my fingers nice and warm. :)
Offline Toxic
« Reply #13 on: November 17, 2009, 05:37:31 AM »
I used to be the first to say "Man up and grow a pair" ;D  But then I got a BMW with heated grips and now I'm a pu$$y.
It'a amazing how warm hands will extend your comfort.  I miss my heated grips. Not to mention the BMW heated vest.  ummmmmmmm toasty
« Last Edit: November 17, 2009, 05:39:25 AM by Toxic »
Online Don R
« Reply #14 on: November 17, 2009, 03:40:39 PM »
I just bought some really nice gloves an my local bike shop, they are gauntlet style and go up over the sleeve keeping the arms warmer too.
Offline TomC
« Reply #15 on: November 17, 2009, 04:19:23 PM »
Hi Cold Ones
     I run a vest that claims to draw 33 watts with no problem on my avatar. I usually turn it off when I am stopped at a light. Wind chill is noticeable. Slow down if too cold. Speed up if to hot.
          TomC in Ohio
TomC in Ohio
76 CB750 F1 Daily Rider
76 CB550 stalled project
76 CB400F Injured Reserve
Offline 333
  • Time for change
« Reply #16 on: November 17, 2009, 05:06:47 PM »
HID headlight will give you some watts, and give you a brighter light.  And while it doesn't look that good, a full size handlebar windshield keeps the wind chill at a minimum.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
  • deliciouso!
« Reply #17 on: November 17, 2009, 06:17:04 PM »
wow why not just ride in a car! :D did u look like ralphie from the christmas story?
« Last Edit: November 17, 2009, 06:18:37 PM by thegabrielj »
94 ST1100..Gone
Offline Mdub
  • Xspurt
« Reply #18 on: November 17, 2009, 11:36:09 PM »
In my experience, an Oregon motorcycle products solid state reg/rect will do wonders.
X= an unknown quantity
Spurt= a drip under pressure!
