Author Topic: stuck clutch  (Read 5723 times)
Offline donny
stuck clutch
« on: November 16, 2009, 03:37:41 PM »
 '71 750, I got running, finally , (blown up and parked since '81).   Adjusting everything possible on the clutch it won't budge, apparently stuck.  Is this common on barn finds?  Are there any tricks or  anyway to "unstuck"  a clutch without cracking it open? thanks,
2007 Husqvarna self propelled lawn mower    1976F    1971K    1974K      1990 FXRS-SP
Offline number13
  • 1973 CB500, 2002 VT750DC
    • Sound Exchange
Re: stuck clutch
« Reply #1 on: November 16, 2009, 03:50:06 PM »
You can try putting the bike in gear, pulling in the
clutch and rocking the bike forward and back.
This is a common problem, but pulling the plates may
be the only solution if that doesn't work.
Bikes parked out front mean good chicken-fried steak inside.
Offline fmctm1sw
Re: stuck clutch
« Reply #2 on: November 16, 2009, 05:46:12 PM »
Probably gummed up.  Mine were in a 175 I'm working on.  I soaked mine in Berryman B12 for a few minutes and sprayed carb cleaner on them.  Works fine now...
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline donny
Re: stuck clutch
« Reply #3 on: November 17, 2009, 05:56:16 AM »
yeah.....I was hoping for a secret magic trick to unstick a clutch, but I will just have to bust it open. thanks,
Re: stuck clutch
« Reply #4 on: November 17, 2009, 08:07:40 AM »
I have had them free up after just running the motor and getting that fresh oil circulating again. Try putting it in gear,maybe third or so,not running, but nice and warm, and rocking it back and forth with the clutch in.
Offline donny
Re: stuck clutch
« Reply #5 on: November 17, 2009, 08:31:24 AM »
okay...thanks.
but if I have to crack open the clutch, do I really need the mysterious Honda Special Clutch Nut Tool ?
Is there any other way?
Offline motorhead55
Re: stuck clutch
« Reply #6 on: November 17, 2009, 08:32:58 AM »
Warm the engine up in Neutral. Get the bike moving by either pointing it down hill or have someone push you on the bike while engine is idling. CAREFULLY slip it into first gear with the clutch handle pulled (yes the clutch won't disengage). While in first gear, with the clutch handle pulled inn gently rock the throttle on and off keeping the handle pulled. This usually frees them up.
1976 Honda 550F bought new in 1978
2006 Yamaha TW200 TrailWay
1967 Triumph 200cc Tiger Cub
2007 Dodge 5.9 Cummins Diesel, 6spd. Stick, 4X4
1955 European Spec VW Bug, 1700cc engine, Porsche 356 "A" brakes
1939 Willys Pickup
2003 Kubota B7400
Re: stuck clutch
« Reply #7 on: November 17, 2009, 08:52:12 AM »
okay...thanks.
The tool helps, but is often not up to the job. I've used the hammer and punch method, which really tears up the nut, but usually always works.
The aftermarket tools are usually T handles, and the 4 sprongs splay out before the nut will turn. Get a hardened tool. I think this one would do it...http://www.wemoto.com/parts/picture/HL-792299/
It takes a 1/2 inch drive which should be enough horsepower to turn the nut.
Re: stuck clutch
« Reply #8 on: November 17, 2009, 09:00:06 AM »
This one looks good http://pitposse.com/hooilficlhub.html
It is 24mm right?.  :-[
Offline donny
Re: stuck clutch
« Reply #9 on: November 17, 2009, 10:22:23 AM »
yea..at last.....victory. Much pushing and rocking and perhaps a little massage from a medium caliber rubber mallet it broke free.
 thanks for the link for that little tool.   thanks again guys.
Online Don R
Re: stuck clutch
« Reply #10 on: November 17, 2009, 10:23:44 AM »
Mine loosened when I started it in neutral. It sat for 15 years.
Offline Magpie
Re: stuck clutch
« Reply #11 on: November 17, 2009, 11:42:41 AM »
And to save it from doing that again if it's parked for an extended time I use a bungy or cable tie to pull and hold the clutch lever back to the grip. It keeps the pressure off the plates so they don't meld again.
Cliff.
Offline fang
    • Food Renegade
Re: stuck clutch
« Reply #12 on: November 17, 2009, 04:49:34 PM »
Congrats on sorting it out.  I have reanimated quite a number of these old motors, and I will loose the stuck clutch by push starting the engine in neutral.  Once it is rolling pretty fast (while holding in the clutch) drop it into 1st gear and toodle around real slow with the clutch engaged (lever pulled) the whole time.  Then give it some blips of throttle while riding the brakes.
It always comes loose.  You might die.  But the clutch always will break loose.  =)
-fang
Download Nervous Norvus' "The Fang"  HERE.
Tired of eating CRAP!
