Well, I've researched ignition timing. I've done it all "by the book". I adjusted cam chain, adjusted point gap to .014" I set my L.E.D timing light on the blue wire, the other to ground. I set 1-4 on the timing mark, and no light. I loosened the three screws and moved the whole point plate left and right, but I never got the timing light to light up...?
I tried 3-4 and same issue. No matter how much I moved the plate, the light never came on. I'm not sure what to make of this. Is it possible that I might have some electrical hooked up wrong by the coils? Is there a fuse that might have blown, that I am not aware of?
Also, I thought I would just push my starter button and watch it crank over, maybe catch a glimpse of the timing light light up, but it never did. The bike wouldn't crank over after three or four tries. It just died. Battery still seemed good with all the lights appearing fully on, but the bike just stopped turning over...Is this normal? Did my starter motor go to #$%*?
Thanks for any help,
