Author Topic: oil behind the ignition cover 79 cb750  (Read 3893 times)
X79CB750X
« on: November 18, 2009, 12:17:07 PM »
I went to check the ignition timing on my bike today and when I took the ignition cover off oil spilled out.  Now since there isn't supposed to be any oil in there..any ideas?  A bad seal up the line somewhere?  Also since there is now (or at least was until I opened it) oil in there how much damage is happening when I run it?  I have to ride it for the next two days and won't get a chance to fix anything.
Offline Bob Wessner
  • "Carbs Suck!"
Re: oil behind the ignition cover 79 cb750
« Reply #1 on: November 18, 2009, 12:59:42 PM »
Yes, there is a seal back there. Unfortunately, it is a lipped seal so the proper fix is to split the cases. There are some folks who have successfully replaced it without splitting. You might do a search for threads on that. How much oil are we talking about? Mine leaks a bit, measured in drops actually, I just live with it.. so far.
X79CB750X
« Reply #2 on: November 18, 2009, 01:25:58 PM »
Hi Bob!
Well the oil kind of took me by surprise when I opened the ignition cover, but I would say there was about a 1/4 cup.  Now unfortunately I am the new owner of the bike which is in immaculate condition, so I'm not sure when if ever the ignition cover was ever opened.  The last owner, a good friend, was not how shall we say mechanically inclined.  So it could have been oil built up over the last year.  For now would making sure all the oil is drained out of it and then letting it go for a few weeks to see how bad the leak actually is be a bad idea?
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #3 on: November 18, 2009, 01:34:06 PM »
A quarter cup sounds like a lot! It's hard to believe that much could accumulate back there unless the weep hole at the bottom of the cover is blocked. If, after a ride, I put the bike on the side stand, there might be a very small amount pooled towards the back. If I park it on the center stand, a few drops might leak out, but I just wipe it with a paper towel right away. I definitely don't lose enough to detect an oil loss on the dip stick between changes. Sounds like your problem might be more severe.
Offline Kevin D
  • SE Michigan
« Reply #4 on: November 18, 2009, 04:00:05 PM »
79 cb750
Is this a dohc750 with ignition on left side? ? ?
I don't know the dohc at all but I'm studying the parts fiche and see gaskets (to hold oil in?)on the left side covers.
1979 CB750K'79 Limited Edition
1979 CB750K
•It was available in one color scheme: Candy Muse Red with Red
•The gas tank and side covers were 2-tone
•The wheels were black comstar
•There was a separate taillight assembly with the 1978 style lens
•The "10th ANNIVERSARY CB750K" side cover emblem was gold and green
•The engine was a 749cc DOHC 4-valve inline four cylinder linked to a 5-speed transmission
•The serial number began RC01-3000006
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #5 on: November 18, 2009, 04:19:14 PM »
Oops, missed the '79 part. I guess this needs to be moved to Other Bikes, eh?
Offline 6adan
« Reply #6 on: November 19, 2009, 05:13:24 AM »
I have a 81 that I found oil there like you did,I just wiped it out and ran it,no problem so far.
1970 CB750 JDM,1975 GL1000, 1979 GL1000, 1979 CBX, 1995 GL1500, 2000 GL1500CT Valkyrie, 2008 GL1800 Trike.
