Author Topic: here is a new paint to try!!  (Read 937 times)
Offline HB-1fan
« on: November 18, 2009, 06:18:19 PM »
http://www.vhtpaint.com/flameproof.html
Seen this  advertised on the speed channel. They claim 2000 degrees!!
 It comes with a primer and a clear coat and an application process that seems very particular. It is a ceramic coating and looks to be in more than one shade of silver!!  I believe it to be 7 t0 10 bucks a can.
If applied right, it would probably last for a long time and be fairly impervious for our uses.
 If anyone uses it please post your opinion to the board.
HB
"If you always expect the worst, you can never be dissappointed, only surprised"
Offline Hasenkopf
  • Really, I'm not an
  • This space for hire.
Re: here is a new paint to try!!
« Reply #1 on: November 18, 2009, 06:34:39 PM »
I have used high temp rustoleum at about 7 bucks a can, and has held up on my headers pretty well, just follow the instructions.
I like berries.
Offline ColinMc
  • There aint no pickle like a super pickle...
« Reply #2 on: November 18, 2009, 07:49:49 PM »
It has replaced all the Duplicolor high heat(NOT engine enamel) paint at NAPA...those part numbers will go in at any NAPA, have had it in stock for at least 6 months now. No real complaints anyone that has used it says it seems to be similar to the Duplicolor High Heat Ceramic paint it replaced at our stores.
1976 CB750K - Cafe Project...taking forever
1984 Honda MB-5 - MB-8 conversion in process
2001 Ducati 748 - Built 996 motor sleeper
Offline cb750fbomb
  • is by no means a
  • "No hope? See, that's what gives me guts!"
« Reply #3 on: November 18, 2009, 10:43:19 PM »
It has held up pretty well on my muffler. Where brake fluid didn't get to it anyway  >:(
'77 CB750F2
“The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at or repair.”
