Author Topic: What else can come out of the carbs?  (Read 6332 times)
Offline csendker
  • Chris; '75 CB550 & a Crusty 'ol boat
« on: December 21, 2005, 05:55:32 PM »
My first carb cleaning project, and I don't want to wreck anything.  I've opened them up and pulled out the obvious stuff, but what else comes out for a full cleaning job?  And what is the thing I circled?  One end is pointy, the other has a spring loaded plunger.  I read up on carb operation, but the guts of mine don't seem to jive with the diagrams I looked at.  And once they're all apart, is there any way to tell what jets I have?
I'm soaking them in purple cleaner first, to get the major crud off and loosen everything up for dissassembly.  It has worked so far as two stuck floats loosened up, and the pins have now come out without a problem.  When the'yre all apart, I'm going to soak them in the Yamaha cleaner I got earlier.  I would like to re-use everything possible, but the gaskets.  And they're 022A's; thanks.
Actually runs --> 1975 CB550-K1
Projects ---> Crusty old boat
Gallery --> http://www.sohc4.us/gallery/v/members/personal/Christopher/?g2_navId=xada3c7ff
Offline Gordon
  • 750K1, 550K2
Re: What else can come out of the carbs?
« Reply #1 on: December 21, 2005, 06:12:09 PM »
The circled item is the float needle.  It sits inside the valve and regulates the fuel flow based on the position of the floats.
Anything that's brass should be taken out and soaked, cleaned, blown out with compressed air, and inspected for persistent blockage.  One of the most important and often neglected parts is the emulsion tube that sits above the main jet inside the long tube in the center of the carb body.  If things are dirty, it will need some persuasion to come out.
Offline Glenn Stauffer
  • Administrator
    • The SOHC/4 Owners Group
« Reply #2 on: December 21, 2005, 06:14:45 PM »
float valve
I'd skip the purple stuff.  Its corrosive to metals like aluminum - not sure what it would do to carb bodies.  The Yamaha cleaner can be used very effectively a number of ways including diluted with water and heated to a boil.
When you clean carbs, separate them from the rack and remove anything that isn't metal.
« Reply #3 on: December 21, 2005, 06:29:19 PM »
The float needle seat (brass) pulls out of the body.  Probably held in now with the old hard oring.
Same for the main jet at the top of the "tower".
The slow jet next to it unscrews, that's why there is a slot. lefty loosey
After the main jet is removed, you can see brass behind it.  That's the emulsion tube.  Probably glued in with crud.  It comes out the same hole the main jet was in.
I know two ways to remove it.  Press from the carb bore side with something that won't mash the brass. That's the needle jet end. The hole is calibrated for the needle that inserts into it from the slide.
The other way is the shoot compressed air into one of the "Air jets" at the carb intake mouth.  Catch the emulsion tube with a soft rag as it shoots out the hole teh main jet was in.  Much depends on how firmly they are glued in with crud.  Squirting carb cleaner into the hole should soften the "glue".  May have to soak it awhile.
You should also remove the pilot screws on the side of the carbs, too, and clean that passageway.
I disagree with Glenn about separating from the rack.  Unless you are determined to replace the orings on the interlinking tubes and fuel feed nipples.  I've not found that necessary...yet.
Offline Philly550K1
« Reply #4 on: December 21, 2005, 08:29:25 PM »
i'll be getting to my O22A's one of these days, so i'm finding this thread helpful -- post as many pics as you want.  i don't mean to hijack, i'm hoping i'll get to contribute eventually...
given that my bike's been running pretty well overall the last few years, and has been used regularly, what am i likely to encounter?  is reusing everything a possibility, or everything but gaskets, like CS is doing?  i have just over 31K miles on it, i think.
it's always run well off idle, and thru the rev range, but it's never been perfect at idle or on cold starts after it's sat for a bit.  plug readings and pipe temperatures have always varied.  i've fiddled with air screws and slide sync settings and gotten some improvement in its idling and "tip-in" behavior over its life, but this winter it's getting cranky again, and i clearly haven't won the trial-and-error lottery.
i wouldn't be surprised if some slow jets, emulsion tubes, air screws, and/or float valves were obstructed.  one way to find out for sure, right?  :)
-jon
Offline cbjunkie
  • ...know what i'm sayin'?
« Reply #5 on: December 21, 2005, 09:20:21 PM »
guys,  ;D...this is why i love this place...this is the most naked carb newbie question i have ever witnessed...and yet, we embrace the brother.
i look forward to posting such open and flawless questions to my betters in the near future.
thank you all.
1971 750K1
1972 CB350 (deceased)
sometimes naked, sometimes mad -
now the poet, now the fool -
thus they appear on earth,
the free men.
« Reply #6 on: December 21, 2005, 10:51:37 PM »
Once you have the jets removed, examine then closely with a magnifying glass.  There should be numbers on the sides of them.
The slow jets will be #40 or #38 if stock (year dependant).  The mains should be #100, if stock.
This is the size of the restriction orifice inside the jet body.  #100 is 1.00MM, #38 is 0.38 mm.
Offline csendker
« Reply #7 on: December 22, 2005, 06:19:26 AM »
Ok, thanks so far - it's starting to make sense now that I'm not almost comatose from lack of sleep.  Out of the purple and into the Yammy they go.  These are an extra set I acquired, so I don't mind if I take all winter, I just want to learn & get a good clean set running (bike's been running great, but the mpg sucks).
I asked what else comes out because nothing else is even remotly loose.  I suspect a set of hardened steel vice-grips with sharp serrated ends is probably not the smartest thing to use on these nice, soft brass seats & jets.  Beyond a good, long soak, any other tips to extract them?
And as requested, more pics:
#1589: Bowls off, on the right - spring clip off, on the left - spring clip still on.
#0034: All spring clips & floats off.
#0035: Float needle valve coming out.
#0038: A view of the other end.
Offline jdpas29
  • my bike is 100% sandcast!!
    • My band = white bread
« Reply #8 on: December 22, 2005, 06:20:37 AM »
it probably wouldn't be a bad idea to go ahead and replace the float needles.  a little ring aroung the tapered head on that thing and it can be leak city.
cars are gay.
« Reply #9 on: December 22, 2005, 06:30:01 AM »
I'd dump that whole rack in Yamaha cleaner for several days and than take the parts out and soak some more. I'd replace the float needle and seat being that the needle is not rubber tipped.
Offline csendker
« Reply #10 on: December 22, 2005, 06:43:40 AM »
Straight-up or diluted (water? %?)?
btripp
« Reply #11 on: December 22, 2005, 07:08:49 AM »
  Hey csendker,
  Did you see the pics of the nasty cabrs on my 550F i'm rebuilding?  At least yours don't look like that!
  Take a look.  I bet it makes you feel better.
  -Ben
Offline csendker
« Reply #12 on: December 22, 2005, 07:14:29 AM »
Where are they?
And I'm finding the outside apperance doesn't relate much to the inside condition...
btripp
« Reply #13 on: December 22, 2005, 07:29:54 AM »
  They're in my post a little while back called "Nasty Carb Rebuild Pics".  It was on the 6th.
  Very nasty.  Don't mean to hijack your post!  I just thought it might give you some inspiration!
  Your assertion that the outside doesn't relate to the inside I'm thinking is right on.
  -Ben
Offline csendker
« Reply #14 on: December 22, 2005, 09:00:19 AM »
Holy crap!  Mine are pristine in comparison.  How did they come out?  And what did you use?
Offline Philly550K1
« Reply #15 on: December 22, 2005, 09:38:54 AM »
yeah, those are an inspiration.  to procrastination!  :)  to answer your original question in a different way, what can come out of the carbs?  apparently vomit, pus, phlegm, river mud, vegemite....
http://www.sohc4.us/forums/index.php?topic=5876.0
thanks for the pics, both of yizz.
-jon
  • Administrator
« Reply #16 on: December 22, 2005, 09:44:38 AM »
Some recommendations:
From the VJMC site on how to use the Yamaha carb cleaner:
http://www.vjmc.org/techtips/carbclean.htm
From a comment posted to the SOHC4.net site:
"an alternate way is to soak the jets in some tinners acid (soldering acid) ruby fluid (a brand of zinc chloride flux) or the like, though the clear uncolored stuff works better. Pull the jets, and put them in small jars of the acid, it will make them look as good as new in a couple of hours, and no worries about snapping a wire in them. On seriously crudded up jets let them soak for a few days.  Once dismantled a set of carbs, put the jets to soak, sold the bike, and found the jets a year and a half later, still in good shape, and spotless, put them in my present bike and I'm still running them, so it doesn't seem that there is any bad effects on the jets."
« Reply #17 on: December 22, 2005, 10:03:10 AM »
I use the Yamaha cleaner straight though diluted is OK. Personally I wouldn't bother heating the solution..I just let it soak for several days and agitate the carbs several times a day.
Offline csendker
« Reply #18 on: December 22, 2005, 10:37:51 AM »
I like the long soak in straight fluid idea the best, as I have absolutely no time to play.  The VJMC method is actually posted in the FAQ's here (Carb FAQ, obviously), but it's too damn cold outside now to be cookin' carbs.
I'll try to pull the seats & jets tonight, but I think they'll need a longer bath to soften everything up more.  Any hints on getting the manifolds off?  The rubbers seem to be hard as rocks - will they soften up over time in the bath?
So far, it looks like new gaskets, float needles & seats.  I'm assuming any o-rings found will be toast.
Offline Philly550K1
« Reply #19 on: December 22, 2005, 10:45:53 AM »
folks were just discussing hair dryer or a heat gun to soften them, as well as boiling them once they're off the bike.
« Reply #20 on: December 22, 2005, 11:15:08 AM »
Main jet removal for your carbs.
Usually, I just put the retainer spring back on the main jet and hook two fingers down near the jet, pull and rock 'til they wobble out.  But, use some judgment as to force applied to that brittle spring clip, or it will snap in two.  Springing is okay, bending to a crease is death.  If I can't get any movement with this method, I try a pair of soft jawed parrallel pliers.  If still no joy, than the serrated jaw pliers with some care not to the let the jaws slip or dig into the jet metal too badly.
Needle seat removal is similar in technique.  But, of course the retainer bit doesn't apply.
I like to reuse good parts.  The float needle and seat included.  But, not until a close examination, magnification prefered. The needle tip is a cone. If there are deep notches in the cone sides it may leak.  If the seat doesn't look perfectly round and smooth about its needle seating circumference, then replace that, too.  If they look to be in good condition, reuse them.  They aren't THAT hard to swap out of the 550 even with the carbs still on the bike.   When reusing parts like this, keep the needle and seat as a mated pair.
Unless you are using a solvent that dissolves or softens the oring material, continued soaking isn't going to help main jet and needle seat removal.  The orings are what's keeping those parts in the body of the carb.  Their job is to block liquids from getting past them.
Good luck,
Offline csendker
« Reply #21 on: December 22, 2005, 01:00:36 PM »
Looking to see what to expect as I pull these things apart.  I'm assuming:
#1: Float needle valve & seat (press-in)
#2: Main jet (press-in)
#3: Needle jet?
#4: Slow jet (screw-in)
#5: ??
Spring: goes with what (#5?) & where?
Clip: I'm guessing this goes with the needle jet?
Float bowl gasket & carb top gasket are obvious.
« Reply #22 on: December 22, 2005, 01:32:41 PM »
Technically speaking, # 3 is the needle.  The needle jet is part of the emulsion tube you haven't gotten to yet.
Spring goes with # 5 on side of carb.
The "E" Clip goes on the needle.
Was your kit designated for your model carbs or generic for all CB550s?
Offline csendker
« Reply #23 on: December 22, 2005, 01:44:20 PM »
It's not my kit - I swiped the pic from CRC's website just to see what this stuff looks like before I tear them apart any further.  It's handy to know if something is long or short before I start wiggling it out.  I won't order anything until I get them torn down completely and know what I need.  And yes, it was the '73-'76 550K-specific picture.
« Reply #24 on: December 22, 2005, 02:14:36 PM »
If that kit depicts all of what you get, then DO NOT separate your carb bank.  You'll need more o rings for that task.
I asked about applicability, because the needle taper, Air bleed screw taper and design, and jet orifice sizes vary between CB550 models.  Some kit mfgrs don't recognize these differences.
