Author Topic: What's the worst/dumbest thing a PO did to your bike?  (Read 74132 times)
Offline low-side
Re: What's the worst/dumbest thing a PO did to your bike?
« Reply #100 on: May 23, 2010, 06:39:11 AM »
I bought a SL350 where a PO "fixed" a dropped valve.  The failure was so extreme that the cylinder block was broken in the cam chain channel.  The fix was to bore the left cylinder out .25mm, leave the right standard, and epoxy the camchain channel shut.  That is probably the worst I've seen.
nomad
« Reply #101 on: December 31, 2010, 03:36:11 PM »
Yeah, that's right... my 750's PO was McGyver!  Apparently the proper fix to a fuse that keeps blowing is to bypass it with foil... good to know!  ::)  I'll have to remember to keep an extra stick of gum in my tool kit.   :D
« Reply #102 on: December 31, 2010, 03:52:53 PM »
Actually, thats not as silly as it looks, i wouldn't recommend it as a fix but the foil lining of my cigarette packet saved my arse several times in the past when blowing fuses in the middle of nowhere. Always do a quick wiring check first so you don't melt anything and replace as soon as possible..
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #103 on: December 31, 2010, 03:56:23 PM »
LMAO!! Just be glad he didn't fix it with a 22-caliber bullet!
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
nomad
« Reply #104 on: December 31, 2010, 04:08:01 PM »
I'm pretty sure that was his permanent fix. And I forgot to mention that I found good fuses inside the fuse cover... never used.
Anyway, with the foil bybass in the fuse box and this nice jumper I found twisted & tied into the gauge wiring, I'm surprised the PO didn't burn this bike to the ground.
Offline Really?
« Reply #105 on: December 31, 2010, 09:15:09 PM »
Fuse box was not even being used.
For some reason he thought he was an electrician.
I got a hold of it last week and replaced the harness, the fuse block, the voltage regulator, the positive battery cable, the negative battery cable as well as cleaned and painted it all.
« Last Edit: December 31, 2010, 09:18:38 PM by Industrial TipperT »
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline MILO
« Reply #106 on: January 01, 2011, 05:33:38 AM »
Dumbest thing he did was try to make it run, after sitting for years and years.... it ran 'apparantly' and bent all the exhaust valves, kiilled some guides, etc etc...
dumbest thing i did was buy it haha, but as my first bike to build up i didn't know any better, im learning a lot from it anyway
Offline phil71
« Reply #107 on: January 01, 2011, 09:11:27 PM »
Ooh, i've got one... but this may not really qualify as a PO bungle.
I bought a 1971 CB 750 from the original owner in Sept. It was still wearing a windshield/fairing
that was installed by the dealer in midtown manhattan.
    It hadn't been ridden since 1981, or it definitely had not been registered.
Cleaning up, and doing my basic autopsy, it was fairly easy to get running, and so complete that it was difficult to figure out why it was parked... till i took it around the block. It had a vicious wobble and would track with even the smallest groove in the road.. at any speed.
    I pulled off the fairing and discovered that the accessories guy had mounted the fairing to one of the tree-top fork tubes and cranked down on that bolt, cracking off the clamp on the LH side... I bet that bike NEVER rode well. I can picture a trip or two to the dealer followed by some head scratching, as you'd never see the crack with the windshield on.
« Reply #108 on: January 01, 2011, 09:27:33 PM »
Phil: Does your bike have these washers?
http://forums.sohc4.net/index.php?topic=72765.0
Mounting the fairing to those clamp bolts and cranking them down should have been fine, if the aforementioned washer/spacers are in place. If they are not there that top clamp will break whether there is a fairing there or not.
Offline phil71
« Reply #109 on: January 01, 2011, 09:58:56 PM »
They're there, though the outer washers were long gone .
Offline swellguy
  • An electric cattle prod is a
  • Divorce is so expensive because it's worth it.
    • http://ksphotos.com
« Reply #110 on: January 01, 2011, 10:54:48 PM »
A previous owner has dry fit everything to a bike then spray painted it with cans and cans of bbq paint. Wheels on, tires one carb filter on. Screws, fasteners, coils, wires, everything covered with or full of paint.
This project started in confusion and will end in disarray.
http://forums.sohc4.net/index.php?topic=76471.msg852227#msg852227
« Reply #111 on: January 02, 2011, 05:51:25 AM »
Then the PO did indeed screw up!  :D
Offline MoMo
  • Ride like you're invisible
« Reply #112 on: January 02, 2011, 06:57:47 AM »
Just finished reading the entire thread-it really should be in the humor forum ;D.  I've run across many of the above problems but one not mentioned is upside down float needles...Larry
Offline beaniam
« Reply #113 on: January 02, 2011, 11:24:08 AM »
The work of the PO caused me to have to pull the engine and split the cases.  Fun on a brand new to me bike.
5th gear gave me this nice sound http://s257.photobucket.com/albums/hh224/beaniamyota/?action=view&current=P1010275.mp4  What fun that was http://forums.sohc4.net/index.php?topic=76692.msg855141
Turns out a single thrust washer was in the wrong spot in the transmission.  Back together correctly and with a replaced 5th gear I've had no problems since.
« Reply #114 on: January 02, 2011, 12:40:01 PM »
Dumbest thing she did was sell the CB750 to me for $300!
Def worth more...
TODD03412
« Reply #115 on: January 02, 2011, 01:20:35 PM »
The PO of my bike let it sit for 20 years. When I went to buy it and asked if he had done a compression check or anything at all, he kicks it over and goes" See, you can hear the compression!" Im keeping my fingers crossed that I dont have to pull the motor apart, its my first major project.
« Reply #116 on: January 02, 2011, 01:25:54 PM »
Welcome Todd!  When did you get it??
Offline sv9cvk
    • www.sv9cvk.gr
« Reply #117 on: January 02, 2011, 03:27:25 PM »
My K2 when it arrives from Germany
 I bought it for spares for my K7 .....
 But I decide to restored it as my K7 was ready ...... >: (
 Now it is disassembled .... and I hope next summer my cafe racer will be ready !!
Offline Damfino
« Reply #118 on: January 02, 2011, 03:49:36 PM »
Wow! Was that in a fire or just sitting outside for a very long time?
Your Message Here!
1976 CB 750
2014 CB 1100DLX
Charles Manson
TODD03412
« Reply #119 on: January 02, 2011, 06:02:40 PM »
Thanks Steve! I got it about 3-4 months ago. I started a build thread for it a few hours ago - Im a lurker, but am going to start getting into it soon, so I will be around a lot! ;D
« Reply #120 on: January 02, 2011, 06:04:56 PM »
WOW - did he store it next to a BBQ?!!?
Offline sv9cvk
    • www.sv9cvk.gr
« Reply #121 on: January 03, 2011, 01:42:42 PM »
No! No next to a BBQ.......  IN a BBQ :D
Roasted CB750  :o :o
« Last Edit: January 03, 2011, 01:48:43 PM by sv9cvk »
Offline Godffery
  • Godffery's Garage
« Reply #122 on: November 03, 2011, 06:02:16 AM »
Funniest thing I'd ever seen was the muffler bracket bolted to the swing arm.  Wish I had taken a pick of that one!
Offline CycleRanger
  • No comment about being an
« Reply #123 on: November 03, 2011, 06:57:12 AM »
Apparently that's not as uncommon as you might think...
http://forums.sohc4.net/index.php?topic=97641.0
Offline tortelvis
« Reply #124 on: November 03, 2011, 06:57:26 AM »
The dumbest thing the PO did was buy the bike (76 550k) brand new and 2 days later put a Zoom 4 into 1 exhaust system on it and throw the brand new, stock exhaust (4 into 4 into a dumpster.)
I am the PO...original owner and 33 years later I kick myself every day for that one.  WHAT WAS I THINKIN??????
I sold a bike to a work mate who immediately binned the Laser end can coz he didn't like it. I asked if he really didn't want it and if he minded me taking it home. No problem he sez. A few weeks later he complains that he just cannot get the bike to run right and wants a new end can. So I sold him one...yes his old one that he binned! Here is a case of the PO (me) being the smart one. I had no pity; he had taken my gorgeous black and chrome bike and painted it bright royal blue with yellow pinstripes and yellow wheels!
