Author Topic: What's the worst/dumbest thing a PO did to your bike?  (Read 69468 times)
Offline bcbillings
Re: What's the worst/dumbest thing a PO did to your bike?
« Reply #200 on: April 05, 2012, 04:21:25 AM »
My P.O. was tired of the blinkers not working so he went mad with a soldering gun... my harness in the front was pretty much a mass of wires RANDOMLY soldered... when i got it NONE of the wires were connected properly and i had to cut out the solder and re-attach the proper wires...
F.Y.I. the blinker problem was because the wires had fallen off the blinker relay behind the battery but the P.O. had no idea where it was and never checked it. It all works great now (just have to get the gas to stop dumping out of the carbs when trying to start lol)
Offline WhyNot2
  • I'm finally an
« Reply #201 on: April 05, 2012, 04:54:46 AM »
This is an excellent example of how NOT to run your wiring threw your handle bar!
Godffery,
    Is this you're Honda ? I imagine you've had to do lot's of fixing on it.
This is a Nascar bike, left turns only,  ??? with the bars slid to the left to give it greater turning radius.
Offline Xnavylfr
« Reply #202 on: April 05, 2012, 04:58:00 AM »
I purchased a bike a couple of years ago that the PO had mounted the swingarm to the rear footpeg mounts so he could have a extended frame. WHAT A DS MOVE!! There is NO way those peg brackets( 1/2" pipe dropped from the frame WITHOUT gussets) are strong enough !
Xnavylfr(CHUCK)
« Reply #203 on: April 05, 2012, 05:49:40 PM »
Xnavylfr(CHUCK)
OH NO !
Offline trueblue
« Reply #204 on: April 05, 2012, 09:32:16 PM »
I think this picture says enough.
1979 CB650Z
Offline nayto550
« Reply #205 on: April 05, 2012, 09:57:22 PM »
He "fixed" the voltage leak in the wiring harness, so the battery wouldn't die anymore.
1976 CB550F
1976 CB750F - in resurrection process
1988 HD FLHS
Online CycleRanger
  • No comment about being an
« Reply #206 on: April 05, 2012, 10:09:54 PM »
"Booby trapped... touch those tanks and BOOM!" :o
Offline WarwickE36
« Reply #207 on: April 06, 2012, 12:53:01 PM »
I wonder how many P.O.s say "holy #$%*, I cannot believe that guy paid me U.S.D. for that piece of crap"  as you drive/ride away all excited about your new toy.  Im going with 60 percent of the time, they say it every time.
" Why does anyone get offended by what someone does to their own bike? I dont get it. "
You made me think about it after I cheered knowing someone else would like to know what these control freaks are up to.
 Every time any owner strips whatever precious Honda part the horrified purists parts go up in value. That's not the part that bothers them.
 What bothers them is they sat up late at night, their breast full of wonder and estrogen, unable to sleep, dreaming about their lovely darling and all her glory... and next thing you know someone else doesn't share their emotional deluge and their reaction is they must spread their mind museum as far as they possibly can, taking over as much of the real world as possible.
Drink fast, drive slow, but ride it like you stole it
1974 Cb550 with style
2004 SV650s
Offline messeduptriple
Re: Re: What's the worst/dumbest thing a PO did to your bike?
« Reply #208 on: April 06, 2012, 01:09:07 PM »
agreed!
Sent from my PC36100 using Tapatalk
« Reply #209 on: April 06, 2012, 01:09:26 PM »
lol
« Reply #210 on: April 06, 2012, 05:07:31 PM »
I'll see your wiring pic and raise mine. This is on a CB750 that I'm doing some work on, the whole bike has been totally rewired. While I can respect anyone with the skills to rewire a whole bike, I have to ask, (considering that you can still buy new harnesses) um, why? Obviously the wiring was done with little thought for removing the engine, as I had to cut several wires to get it out. Cheers, Terry. ;D
Offline thrutheframe
« Reply #211 on: April 07, 2012, 07:52:36 AM »
Am I seeing this correctly?  They actually spliced the chain together with two outer links in a row?  Did someone forget to loosen the cam chain tensioner before they "re-installed" the cam chain?  Im thinking this might be the winner of the dumb a## fashion show!
'74 cb 750 K4
'75 CB 360T
'90 RC31 Hawk GT
Offline trueblue
« Reply #212 on: April 07, 2012, 08:26:51 PM »
Yep you're seeing it correctly but they actually used two inner links, and yeah they didn't loosen the tensioner.  I kept the old chain for a souvenir.
1979 CB650Z
« Reply #213 on: April 07, 2012, 08:51:15 PM »
Sweet!
'74 cb 750 K4
'75 CB 360T
'90 RC31 Hawk GT
Offline Milkman666
  • It's not junk, Honey - it's a classic!
« Reply #214 on: April 18, 2012, 10:51:44 AM »
What is going on here?
Milkman
"Everything works if you let it." - Travis W. Redfish
1975 CB750F
2006 VTX 1300C
Offline Teatimetim
« Reply #215 on: April 18, 2012, 11:34:59 AM »
On quest to get mine running, I found 3 different types of spark plugs in it, 2 where 5/8ths champion equivalant, two where 18 mil, one of an unknown type, and the other an orginal spark plug  NGK d8ea I think.
and a non metric Hex nut to plug one of the carb float bowls.
Bikes I own:
1974 CB550K
1971 CB450
Offline steam-powered man
  • Not the eggman, Not the walrus, I am the
  • Where are you going? I was going to make Espresso
« Reply #216 on: April 18, 2012, 11:50:19 AM »
milkman - i see some adjustable lowering blocks - is that what you mean?  anyhow,
worst thing a PO did to me was leave the cam chain sprocket bolts loose.  when attempting to start i heard a "plink" and then the noise of the cam chain dropping into the cases.  at americade.
we should start a "whats the worse thing you've done?" thread.  i think i'm the winner............
searching for a dr350se
Offline grachman
« Reply #217 on: April 18, 2012, 01:47:36 PM »
My PO LOVED duct tape.  He put it everywhere...over the cracked headlight lens, holding the headlight rim on (guess he couldn't find a screw?), holding the front fender on, patching the seat tears, in place of the kick starter rubber, in place of the gas tank rear rubber, around the cracked manifold boots, and my personal favorite....THE ENTIRE WIRING HARNESS!!  Guess I shouldn't complain too much for $100, though I think he should've paid me instead.
Glenn
"wake me up when we're all nomads again."
1974 CB550
Offline lucky
« Reply #218 on: April 18, 2012, 02:43:17 PM »
Let the bike sit in the garage for 8 years without ever starting it/draining fuel tank etc.
Thats just NORMAL behavior isn't it?
Offline lucky
« Reply #219 on: April 18, 2012, 02:48:09 PM »
Condition from the previous owner.
Click once on the photo to enlarge.
« Last Edit: April 18, 2012, 02:56:35 PM by lucky »
Offline Jerry E.
« Reply #220 on: April 18, 2012, 04:36:03 PM »
PO took out the reduction gear, shaft, & washer from the left crankcase because the starter stuck on. He then put a small cork(really)into the blind hole the shaft was in, (in case it leaked? )He was afraid it might stick on again, randomly I guess. He left the starter in the bike. He also removed the solenoid, and disconnected the battery cable to solenoid. The last part was all he had to do. I just bought the bike and had to fiqure out why the starter didn't work.
"Why jump from perfectly good airplanes? Because the door opens."
« Reply #221 on: April 18, 2012, 05:33:38 PM »
Never heard of belt and suspenders?   ;)
« Reply #222 on: April 18, 2012, 05:57:10 PM »
I hope he didn't remove the kickstarter also and resort to "push only"  :o;D
« Reply #223 on: April 20, 2012, 05:40:04 PM »
Push only, been there.
'74 cb 750 K4
'75 CB 360T
'90 RC31 Hawk GT
Online CycleRanger
« Reply #224 on: November 16, 2012, 08:06:44 PM »
Found this inside the front hub on my CJ360T.
Looks like the PO used JB weld to glue the pad to the shoe.
Looks like he used some tie wraps to hold it until the glue set.
