Author Topic: What's the worst/dumbest thing a PO did to your bike?  (Read 75625 times)
Re: What's the worst/dumbest thing a PO did to your bike?
« Reply #325 on: March 08, 2014, 02:35:15 PM »
Yep, I'm guessing that would allow you to mount K0-K2 speedo and tach on a later top triple. Maybe he broke his original "Rhino Horn" triple and couldn't find another one? ;D
Offline CycleRanger
  • No comment about being an
« Reply #326 on: March 09, 2014, 09:17:41 AM »
:-X
Custom unicorn!  Now that is special!  :o
This thread continues to deliver!  ;D ;D ;D
Offline fire113
« Reply #327 on: March 09, 2014, 01:57:10 PM »
:-X
...have some more parts that are special now ;)
Don't know why the PO did it but he did!
Offline 750K
« Reply #328 on: March 09, 2014, 02:02:55 PM »
Haha, those pipes are funny as hell. Pretty genius actually, shame to do that now but that's a hell of a way to get a 4 into 2 setup lol
77 Cb750, 78 Kz1000
« Reply #329 on: March 10, 2014, 10:39:53 AM »
I wonder what that modification would accomplish fire113 ?
Hi grcamna,
...to be sure You have to ask the PO ;)
I am thinking he was trying to build one of the early upper trees.
I see it.  ???
Offline ct_racer
« Reply #330 on: March 11, 2014, 05:41:00 PM »
Well my last bike (73 cb500) was stolen, so that makes me the PO....  I bet that guy was pissed to find the PO had put the jugs and head on the crank case without any pistons and without torquing the head on in anyway.  I bet he was even more pissed to find that when he replaced the pistons the jugs had been resleaved from 500cc to 605cc.
Still have those pistons; I keep them on my desk to make the best of that bad situaton.  Got a "new" bike this past fall and it's been good to be wrenching again.  It's not a sohc,  but 2 is better than 1 right?  ;)
Sent from my SM-T520 using Tapatalk
Offline mcswny
« Reply #331 on: March 11, 2014, 05:45:46 PM »
So confused in the best way possible.
1972 CB750 K2
1997 XR600r (street legal)
1975 XL250
198 XR80
Offline atm cycles
« Reply #332 on: March 12, 2014, 01:50:54 PM »
Bought a running cb750 k6 looked like it needed nothing. I did not test ride. Registered , insured right away. first time out get gas trouble getting third gear. Within one mile no third. Long story short ended up splitting cases replacing shafts n gears all to find the neutral switch was not installed all the way by PO and he had washers on hold down to make up the gap. Good learning experience.
Offline CycleRanger
« Reply #333 on: August 07, 2017, 03:49:56 PM »
I think it's time to resurrect this thread.  ;D
Found this RTV on the 550 I'm working on.
There was more on the back side  and o-rings too when I pulled the manifolds off.
« Reply #334 on: August 07, 2017, 03:56:41 PM »
I resurrected another thread, but will post here too...
A-hole PO didnt properly torque the rod cap nut resulting in a 3" hole in the engine case when it let loose at 90mph.  Dimwit!!!
« Reply #335 on: August 07, 2017, 04:50:04 PM »
That was a "Near Death Experience" Steve! Did you wash your undies afterwards, or just send them to the PO? ;D
« Reply #336 on: August 07, 2017, 05:08:57 PM »
 Fixed a couple on my GS1000 project today,put the spacers in correctly on a carb needle like it should be and found out why the oil light would not go off. Makes me wonder if more evil still lurks.
« Reply #337 on: August 07, 2017, 06:52:30 PM »
Send it to me Eric, GS1000's aren't for the nervous....... ;D
« Reply #338 on: August 07, 2017, 08:03:43 PM »
Good idea, I will mail em to the PO!
« Reply #339 on: August 07, 2017, 09:00:16 PM »
You should make him wear them, just so he could experience your discomfort! ;D
« Reply #340 on: August 08, 2017, 06:38:13 AM »
You should make him wear them...
...on his head!
Offline MetroRedneck
« Reply #341 on: August 08, 2017, 07:19:47 AM »
Copying from another thread - this warrants archiving in this thread for good reason.
Check out my PO RTV skills.  There was also only 1 oiler valve installed, 2 o-rings though.  The cam alignment wasn't in there.  I thought I had a spare - nope - it was the one that should have been inside.  I'm glad they didn't try to run it like this, although it probably would have just blew fire out the carbs the timing was so far off.  Check out the silicone nipples that were made as it squished into the galleries.  I think they were trying to bump the compression.  Remember kids, a little (or preferably none) goes a long way.
Offline CycleRanger
« Reply #342 on: August 08, 2017, 08:23:19 AM »
How many of you have a car horn on your bike?
You can barely see it attached to the left side of the headlight.
Bonus, it was painted red and connected with wire nuts.
« Reply #343 on: August 08, 2017, 08:29:27 AM »
Not quite car horns, but with relays, they are close.
Offline 750K
« Reply #344 on: August 08, 2017, 12:48:26 PM »
I do, it's a spare horn I had from my 83 Volvo 240. It's loud as hell and it is identical looking to the stock 77 750k horn, it mounts to the stock horn bracket and is plug and play. Drivers not paying attention actually hear it, I recommend it to anyone. Cost me a couple bucks ate the pick a part wrecker yard.
77 Cb750, 78 Kz1000
« Reply #345 on: August 08, 2017, 03:00:21 PM »
The worst thing a PO did to a bike I bought from him was 'own it '   ::)  A case of total neglect that I had to fully restore,but we all have to deal with that regularly..
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #346 on: August 08, 2017, 03:33:03 PM »
Does an air horn count?  I have one on my sidecar rig, but can't blame the PO for it ;-)
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline Keith
« Reply #347 on: August 08, 2017, 07:19:48 PM »
Not ground shattering...but could have caused an accident or worse. Checking the bike over before my first ride, I noticed there was a castle nut on the rear brake stabilizer bar, but no cotter pin, and at first, didn't see a hole for the pin in the bolt. Worse, the nut was loose! What had happened was the bolt had a "T" shaped head, and it wasn't seated properly, so the nut couldn't thread on far enough to expose the hole for the cotter pin. If that bar had dropped off when riding....
Offline spotty
« Reply #348 on: August 08, 2017, 07:41:19 PM »
in earlier days of mechanical ignorance (some say it hasn't changed) I built a custom vespa which has stub axles for both wheels, I didn't know that the cotter pin was necessary and replaced the castellated nuts with whopping great pike nuts, looked great...
a couple of days after I finished the build I was riding out in the country on a club run, I took off quite quickish from the last stop and got up to whatever its claimed top speed was, after a little while the back end started to feel a bit twitchy, shortly followed by the pike nut coming adrift from the stub axle followed shortly afterwards by the back wheel...
 the back wheel disappeared up into the body of the scooter, the back of the body hit the ground, tipped over onto its left side and slid towards the side of the road. I was still hanging on at this point but realised that the crash barrier along the freeway was approaching and not wanting to be connected to this large sliding metal thing when it hit, I let go. this however did not stop me from continuing on the same trajectory towards the crash barrier...
I still had time to make one more choice - do I hit the crash barrier upright with my legs apart ...maybe not - do I slide under the crash barrier into the abyss I could see on the other side....maybe not - do I hit the crash barrier upright with on leg ...no time to choose anymore. I hit the upright straight on with the flat of my left foot which forced the ball of my ankle straight up the middle of my tibia
so that didn't end well then
i blame Terry
« Reply #349 on: August 08, 2017, 07:53:15 PM »
My worst is the green putty the PO applied to the cracked cases at the countershaft.  It got into the oil and plugged the feed to the left side of the topend.  The camshaft was completely broken (sheared) next to the drive-sprocket. The motor still ran on #3-4.
The second worst was the K4 with the K8 front forks and rear wheel.  The chain alignment was off and the fork legs were installed backwords (wrong sides).  His confusion ended the project so it now sits in my garage for $100.
Wish I was closer to you: someone here wants a K8 from me...all rebuilt.
