Author Topic: Topping up a Battery when away from the shop.  (Read 8755 times)
« on: November 21, 2009, 12:13:53 PM »
I got stuck the other day, battery needed water, and did not have all my tools here.
 So I am looking around the house for a hose or whatnot.. and I decide to use ...a pen.. Staples brand.. looks like a bic, lucky no hole on the side..
 field strip it into 3 parts, get a cup of  water (not distilled unfortunately) Get off the battery caps. Wet end of finger, insert pen into cup, put wet finger over open end of pen body,  drain into battery cell hole !..  repeat,.. MANY times, check occaisionally....works pretty good, but slow..
 Hey, it works in a pinch..
Re: Topping up a Battery when away from the shop.
« Reply #1 on: November 21, 2009, 05:04:55 PM »
An ordinary drinking straw will work as well.
Offline Ricky_Racer
« Reply #2 on: November 22, 2009, 12:39:07 PM »
Whenever I use a drinking staw it dribbles from the pressure of trying to hold it. The rigid pen works in a pinch, but my all-time fave is a turkey baster.  Now, NO "turkey" comments, okay?
Oops... I just realized you said away from the shop, and I'm probably the only guy who always carries his own turkey baster, right?  ;D  RR
« Last Edit: November 22, 2009, 12:41:18 PM by Ricky_Racer »
« Reply #3 on: November 22, 2009, 01:06:35 PM »
Whenever I use a drinking straw it dribbles from the pressure of trying to hold it.
Then wet your finger to improve the finger seal on the end.
And, ...so what if it dribbles water?  You using a paper frame?
What melts on the bike in the rain?
« Reply #4 on: November 22, 2009, 01:14:32 PM »
Drinking straw is great, used it before but hard to find.. sometimes..
 In the past I have used the baster. in the shop I use, I think it is called a glass pipette (narrow graduated cylinder, with eyedropper end). I try to use something with lower volume, easy to overfill with the baster...
 Is it just me or is it freaking difficult to see level from the side on a lot of batteries..
Offline Ricky_Racer
« Reply #5 on: November 22, 2009, 07:46:49 PM »
It's cool, Dude. You can use a straw if you really want to... No problemo.  ;D  RR
Offline mystic_1
  • 1970 CB750K
« Reply #6 on: November 22, 2009, 08:15:04 PM »
MacGyver would be proud!  :)  I once (temporarily) fixed a leaking gas tank with chewing gum :)  Later I did a more permanent fix with a soda can and two-part epoxy :D
mystic_1
- John Augustus Shedd
Offline mystic_1
  • 1970 CB750K
« Reply #7 on: November 22, 2009, 08:15:42 PM »
This made me LOL.   :D
mystic_1
Immusia09
« Reply #8 on: November 23, 2009, 03:26:51 AM »
Gaya Thanks Alot Weeeeeeeee Now I Will See Around If GC is looking At My Shop Or Not
avopower
« Reply #9 on: November 26, 2009, 11:55:57 PM »
Been there too...
« Reply #10 on: November 27, 2009, 05:41:31 PM »
Stop by your local pharmacy and ask if they have a 10cc syringe. Better yet ask them for an oral dosing syringe for your baby. You might get that free.
Offline Alan F.
« Reply #11 on: November 28, 2009, 08:41:58 PM »
You're not the only one, a strong flashlight held against the side of the battery helps with that.
-A
Offline Steve F
« Reply #12 on: December 22, 2009, 06:43:17 PM »
-A
I tip the battery back and forth to see the fluid level, use the turkey basterd when I'm at home, but the pen idea is cool.
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #13 on: December 27, 2009, 11:26:12 PM »
you've never been around a horse or other large animal breeding operation have ya? :D :D :D :D
Mark Twain - Notebook, 1894
Offline Steve F
« Reply #14 on: December 29, 2009, 01:49:07 AM »
I hear that those used syringes can be had really cheap!  :P
Offline piute
  • Piute
  • TRICK OR TREAT...B....es
« Reply #15 on: October 22, 2012, 07:07:29 PM »
  This is an old one ,so here's an old tip from Easy Rider Tec-Tip book ,
          " Plastic Baggy",heck just used a reg plastic store bag last month when had to.
Ride to live Live for Jesus
1977 750 F2
Offline cb650
« Reply #16 on: October 22, 2012, 07:46:49 PM »
Long time ago me and the ex went riding across kansas on the hottest day ever there.  115 on fresh black top.  Anyway the battery fried.  Had to push start every stop.  Got to manhaten ks and the battery was low.  For being a collage town nobody knew what distilled water was.  Went to half a dozen stores and had to explain what it was.  Nobody had any.  Used tap water and made it home a couple days later after bussness and thought I would freeze to death at 75 degrees. LOL
