Author Topic: CB750A Street ET bracket drag bike. A year to build it.  (Read 632007 times)
Offline jweeks
Re: CB750A Street ET bracket drag bike. A year to build it.
« Reply #1025 on: April 05, 2011, 04:05:12 PM »
Am I that bad?  8)  Sam, on your next motor I want to supply the oil pan only! Leave the controversial stuff to Mike? ;)
     Nobody makes modified torque converters for the Hondamatic cb750A. The torque converter that Honda used came from the early Civics parts bin. I contacted over 20 car transmission companies trying to find someone to modify the Honda converter. Yes, that included most of the "name" performance companies who advertise in National Dragster. (NHRA) Only one midwestern company was mildly interested in trying. They did modify my cb750 converter. The stall speed improved from the stock 2,800 (achieved) to 4,200 rpm (achieved.) An exact copy of what they did is in Sam's motor. The internal fins of the torque converter are cast metal.  Most car torque converters use sheet metal fins.(aka bendable) Changing the angle of certain rows of the fins will increase the slippage without hurting the power transfer at the higher rpms.  You can't do that with the factory torque converter! The fins break, not bend. You can make the converter slip more, but it won't still effectively transfer the power. Kinda like a CVT setup - The motor revs high, but it takes a while for the wheels to turn fast.
     Ok, what about a different torque converter? The shaft splining will have to be adapted, either by using a different shaft spline to mate with the car's converter splines or machine a new hub for the converter that will fit the stock Honda spline. If the thought of that expense doesn't discourage you, I'll add this one. What oil goes through most torque converters? (You know, red, thin stuff) The car transmission converter shops have no clue how a converter will work with 20W-50 mineral oils! So we want to buy a high stall converter, modify it, and run a heavy oil through it and achieve a higher stall speed? Converter, $6-800, machining to fit ?$$$, and then try it to see if the stall speed is anywhere near where you want. If it isn't, rework the converter stall speed $$$ and  try again. Sounds like a $1,000+ lottery.
     I did have a converter reworked by milling out the stock cast fins and hand welding in 16 fins on one side of my converter.  I was out over $600 for this modification. The tranny shop wouldn't guarantee any stall improvement for what I spent. Fortunately, I gained stall speed up to an observed 6,000 rpm. So, yes, a converter can be reworked at least that far. That's what I'm running on my 10 second drag Hondamatic.
     Now, if I were to give this converter to Sam to run, what would happen?  Virtually no change in slippage rpm on that bike. Just because the converter can be made to slip to a higher rpm, doesn't mean that it will. The converter eats up the torque,(converting it to oil heat) limiting how high it will slip in rpms. Without the torque necessary, the slippage rpm doesn't rise. Make more torque in Sam's bike at around 2,500 rpm and it will slip to a higher rpm on the starting line. The lower the motor's power, the less that the torque converter will slip. We don't need a "looser" converter; we need more torque around the rpms that we want to launch at.
     How do we make more torque in the 2,500 to 3,500 rpm range? More compression, more stroke, and/or a change in cams. A slotted cam gear may shift the torque curve enough to help with the launch rpm. It may not be enough of a change at the low rpms in question. It is the most cost effective method to try if the upcoming changes on the dyno don't help enough (including the oxygenated gas). In my book, the second most cost effective change is a change in cams (vs new pistons, or another crankshaft). The other alternative is to live with what we've got. My worry with that is the repeatability of the bike. If it varies like it has at Rockingham, you might as well park it. Winning rounds will be due to good guesses, not data of many passes. This can be an ATM machine. It won't be until the 60' times get consistent.
     I'm not trying to have anyone's head. Everybody has tried their best to make this bike work well. All suggestions have been positive. Anybody with car torque converter knowledge will verify that the amount of slippage of a converter changes with the power of the motor that it is attached to. It doesn't matter if it goes 120 mph in the quarter mile. It doesn't matter if it goes in the 11's once. It matters if it will repeat on the track. Some Hondamatics do repeat. That's why at least one is called an ATM. I want Sam to have an ATM.
        JW :)
Offline Bill/BentON Racing
    • BentON Racing
« Reply #1026 on: April 05, 2011, 04:32:26 PM »
He will..........have an ATM machine one day,we just aren't there yet.We'll get the most out of what we got,make it CONSISTENT,and go have FUN!I believe we can make bike go 12.2-12.5 all day once sorted.Yes,I'd love to see 120 mph and 11.something,but that's not the goal. Jon,we'll make it happen,next dyno runs should help.Valdosta someones going past 1st round!Sam????? Consistent runs will happen! Bill
BentON Racing Website
BentON Racing Facebook
Offline azuredesign
  • Knupping pin
« Reply #1027 on: April 05, 2011, 04:49:47 PM »
Hey Jon,
Thanks for taking the time to write that detailed explanation. I understand a bit more about the mechanics of the automatic and some of the background work you've done. If the converter was to use a thinner oil like ATF, would the stall speed increase? If so would it make any sense to have a separate lube system for the converter?
All best,
Ben( I met you briefly at Mike's a year+ ago)
« Reply #1028 on: April 05, 2011, 04:52:29 PM »
Excuse my ignorance with the auto, is there no neutral position with that box.? Can it be strengthened so it can be dumped in gear with the revs up.?  :o
Offline dragracer
  • CB750F Dragbike
« Reply #1029 on: April 05, 2011, 05:07:12 PM »
See, he schooled all of us once again ;D Thats why he's the Hondamatic expert and i have to stick with a simple hand clutch- my brain is too small to absorb this one lever deal-lol.  Seriously, i do comprehend what Jon is saying and i was just making a joke about the head chopping converter question. Jon, you will find that i'm an easy person to get along with but when there is a question, someone has to ask the tough ones no matter the answer. My background is not only from  bike racing but i dabbled in dragcars first. Yes, the stall of a  converter is in direct proportion to the torque of the motor. I have used the same stall converter in both a small block and a big block(Chevies) and neither stalled at the small rpm. Even 2 different small block motors netted different results. Thats why tranny converter suppliers always ask the specs of the car/motor before selling you a converter- the same with camshafts. Big blocks typically make way more bottom end torque than a small block.
Again, this is a bracket bike and consistency is the ultimate goal with ET and MPH secondary. Find repeatability in both the bike and rider and the wins will come.
Offline jweeks
« Reply #1030 on: April 05, 2011, 05:18:59 PM »
Neutral to low gear will tear up the low gear clutch pack, if it holds together. I'd expect shrapnel.
Yes, lighter oils should slip more. How you would make a separate oiling system for the converter would be an engineering challenge! Separate oil pump, reservoir, not to mention how you can put the thin stuff into and out of the converter without mixing with the shaft bearing lubrication. The tranny company asked me the same questions....
       If I wanted a challenge, that wouldn't be the one. Now a 4+ speed transmission for a Hondamatic is one that I'd like to try....
        JW
      I have a dry sense of humor, dragracer. Given more time you may understand me better... Anyone who thinks that drag racing with a clutch is easier is crazy. Clutch materials, clutch pack composition, clutch pack clearances, spring pressures, etc. just for a "stock" clutch. Now if we get into sliders.... ::)
Offline jweeks
« Reply #1031 on: April 05, 2011, 06:25:18 PM »
Mike,
     I agree with you. That's what I wrote. This Saturday should be spent smoothing out the fuel air ratio on the carbs. With everything perfect on the idle/midrange circuit, what do you expect to improve in torque in the 2,500 to 3,500 range?  That's the real question here. I've stated that we should run the bike after this weekend's tune. If it's still not enough of an improvement, where do we go then?
        JW
Offline dragracer
  • CB750F Dragbike
« Reply #1032 on: April 05, 2011, 06:27:04 PM »
Funny, i think we actually understand one another quite well Jon. I get the sense of humor and never take much to heart. We are drag racers so you know we're all a bit eccentric in our way of doing things. As you said in an earlier post, there is no recipe for building a dragbike especially one of this nature. Kinda like raising children i suppose- no one method works for all but you hope in the end they all turn out to be the best they can be. I've learned a lot from this Hondamatic build and appreciate all the knowledge you and everyone else has shared from the first post until now.
This bike will get better. There are to many minds at work n the homeland and iinternationally not to overcome the new bike growing pains.
Offline Tintop
« Reply #1033 on: April 05, 2011, 06:44:14 PM »
So my turn to ask a sideline sitter question. ;)  I know the bike's running CV's, and somewhere in 45 pages it will tell me, but which make / model?  Now returning to munching on my peanuts. ;D
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline jweeks
« Reply #1034 on: April 05, 2011, 06:59:43 PM »
Page 34 "The carbs are early 80's GS750 Suzuki carbs."  34mm with stage 3 Dynajet jet kits and modified linkages to fit the CB750 head spacing.
        JW
    • BentON Racing
« Reply #1035 on: April 05, 2011, 07:12:06 PM »
Thanks to all involved that got us this far.I've made many new friends and had many a happy experience since meeting Sam and this build starting.We have gotten close,engine is awesome,ignition system working fine,we just have a A/F delivery problem.Time to pull those carbs again!It's ok,they jump off now! #1 carb has a passageway issue,Jim and I to explore,I showed him before dyno runs,it showed up in #1 pipe turning blue,theres a restriction in the passageway for the air jet,the ones we changed orifice size on.# 50 drill bit will go in the passageway on 2,3 and 4 and bottom out with only 1/2 inch of bit showing,#1 bit stops about 1 inch in???? ???.This is one of the A/F problems ,but not the main one.We're on the right track,Jon's advice has taken us far and Mike's motor ? No words needed,just listen to dyno or video runs,thanks Mike!Those carbs are the way to go for now,let's see how good we can make them.I'm going go take 'em off and get started,will post a pic of what I wrote and find.Big Jim as usual....stand by,Sam.....pray?
OK,maybe not 87 ,but I believe we'll get 85 RWHP!,just 8 more,fuel @ 4....we can do it,check Doctor D.'s dyno runs for comparison of Megacycle 125/75 vs 125/65,as Mike stated more of both what we're looking for! I'm real interested in spring effect,also polishing slides and bores,those slides weigh 53.6 grams if I remember right...a lot to pick up! We're already up almost 3hp since 1st run,it will happen! Dyno though in 2 weeks,Brian will be @Carolina Dragway(The House of Hook) on Sat... tempting...OK,I'll wait. :(...it would go @ least 2-2.5 seconds quicker than last time there! ;D Carb Time,
off to pull those little devils and heal their sorry azz's! ;) ;D ;D Bill
« Last Edit: April 05, 2011, 07:15:20 PM by bellcow54 »
« Reply #1036 on: April 05, 2011, 07:17:01 PM »
First sort the timing, using the stall speed as your dyno. Also, since the bike seemed to get faster each run, due to the motor breaking in, consider running the bike on the stand at 4-7K RPM for a while. I don't have much experience with CV carbs, but it does sound like weaker springs may help. If they aren't available, it might be possible to wind your own springs from piano wire.
Offline Tintop
« Reply #1037 on: April 05, 2011, 07:35:58 PM »
        JW
thanks JW.
77 CB550 Cafe build
    • BentON Racing
« Reply #1038 on: April 05, 2011, 07:45:20 PM »
Carbs off,pics in a minute,gotta wash up.Bill
    • BentON Racing
« Reply #1039 on: April 05, 2011, 07:46:47 PM »
See what ya'll think. We'll make these or others work!!! ;) ;D,Bill
only #1 blue,
2,3,4 same,
2,3,4 drill bit goes to this depth and you feel it bottom,
#1 does this?????
Big Jim,need your help,he can drill and reweld any passageway(the magician of micro welding) ask Mike!
It's worth it!!!!!!! ;D ;D ;D ;D,Bill
« Last Edit: April 05, 2011, 07:59:45 PM by bellcow54 »
« Reply #1040 on: April 05, 2011, 08:13:38 PM »
Spray carb cleaner into the #1 passage, watch how it exits into the card throat, and compare to the other carbs?
    • BentON Racing
« Reply #1041 on: April 05, 2011, 08:23:15 PM »
Scottly,believe me I did that or never would have gone racing,it comes out,but @ same rate?,need to check other carbs and compare. Somethings up for sure,we'll figure it out. ;D,Bill
Offline dragracer
  • CB750F Dragbike
« Reply #1042 on: April 05, 2011, 10:05:01 PM »
Hey Bill,
I finally got the wifes motor back together after fighting a lengthy piston to valve issue. Had to sneak up on the correct amount to fly cut so we wouldn't put a window in the top of the piston. Head, block and pistons off 3 times but its basically a done deal now. We plan to go to Union County Dragway saturday for their first points race. Perhaps you guys will consider joining us. They just added a bike class so we can compete for points and the track championship. It would be nice for Sam Green Racing to have a track championship under its belt the first year racing the new bike.
Well, give it some thought and let us know.
Later
« Reply #1043 on: April 05, 2011, 10:45:48 PM »
I have no doubts the Samatic will be consistent, as well as quite quick. ;)
Offline ivanhoew
« Reply #1044 on: April 05, 2011, 11:42:36 PM »
Hey Jon,
All best,
or maybe is it possible to run the engine on mobil 1 0w50 ?
trying to get a grip on this , jw , from what your saying ,there are 3 different converters ..
stock 2800 rpm
1st stage 3500rpm on sams ,4200rpm on yours .
2nd stage 6000 on yours .
but you saying that if the st2 was put on sams , it would still not go over 3500rpm?, in that case how come it went from 4200 to 6000 on yours ? much much more torque ?
and if the st2 converter was modifed , isnt it possible to modify another one ,but more so ,to bring sams engine up ?
im probably making a huge fool of myself here ;)
regards
robert
just do it .
  • Moderator
« Reply #1045 on: April 06, 2011, 02:06:22 AM »
OK guys. this is a new bike and most new bikes have there teething problems.
We have been open to a certain extent in order to suply you with reading material.
A lot of teams do all their testing behind closed doors and you don't get to see the results untill the team are satisfied that what you are seeing is what they want you to see.
Because this is a forum and you are free to add your own comments, quite a few are comming up with their views without reading what has already been covered and it is causeing a little unrest between members of the team. This also happened a while back and we had to resort to talking behind your backs and communicating with one another by PM.
Because of this I am locking the thread for the time being. If you have anything to say or would like to add anything, please feel free to have your say by PMing me.
Thanks for all your support over the last 15 months.
Sam. ;)
« Last Edit: April 06, 2011, 02:08:28 AM by SamCB750A »
  • Moderator
« Reply #1046 on: April 06, 2011, 09:03:03 AM »
After 60 people veiwing the thread since I locked it and 60 million angry PMs from people I've decided to unlock it.
Several people contacted me appologising for rubbing people up the wrong way but to me they wern't the guilty parties. ;D ;D ;D
OK, we've got one or two problems but please let us get to the bottom of them in our own way, that way you don't offend the people working on the project.
If you must say something that you think will help. please pass it on to me by PM.
I know you mean well but this thread is very long and if you dont have time to read it all, you may well end up telling us something that has already been tried or altered, It's not like we are a bunch of amatures (I know it must look like it at times ;D) but the fact that we are spread over thousands of miles apart, comunication over the net can sometimes be interpreted the wrong way and something that gets said can sound like you are telling us how we should be doing it.
All the people in this team were hand picked for their skills in different areas of the bike, telling them how to do it is as good as an insult. Please think what you post before hitting the keys.
Thank you, and thanks for your interest and support. 8)
Sam. and the team. ;)
Offline voodooracer
« Reply #1047 on: April 06, 2011, 12:48:22 PM »
 Keep on keepin' on Sam, Bill and crew!!!
    • BentON Racing
« Reply #1048 on: April 06, 2011, 12:57:21 PM »
Sam,thanks for unlocking the thread.It's all gonna be OK.I for one am looking forward,z past is gone.We are working on the carbs.They have been proven to perform.In the meantime want to run/race bike,can't do that and feel good about it (color didn't show up til we leaned it out....#1 real lean?,we'll put the probe up #1 if we gotta)Brian said so!
May make Sat.w/Frank @ Union County,Big Jim and I trying to sneak out! It will have my NOS Mikuni 29mm's on it.Not what we want long term,but can race,put some time on motor,see what times we run and try to run series!Samauto's going forward,in the meantime we work on carbs we got and look @ other CV alternatives,CV flatslides etc? The engine is staying sealed,we don't need no mo motor,we got plenty!In the 7's in the 1/8 if we go this weekend! ;) ;D ;D ;D ;D,Ya'll cheer up,we all own CB750's or CR's!!! or SOHC Honda's Bill.
Frank call me or PM,I can't find your #.
« Last Edit: April 07, 2011, 04:55:46 AM by bellcow54 »
  • Moderator
« Reply #1049 on: April 06, 2011, 01:26:09 PM »
#sent.
Sam. ;)
