Author Topic: CB750A Street ET bracket drag bike. A year to build it.  (Read 719065 times)
  • Moderator
Re: CB750A Street ET bracket drag bike. A year to build it.
« Reply #3050 on: October 25, 2012, 01:31:42 AM »
Good boy Billy 8) 8) 8) 8)
Is there a bike behind those stickers  ???  ;D ;D ;D ;D ;D ;D ;D
I guess that it works was just a static test on the bench, yes  ???
Is the origional back brake still hooked up, would be good as a back up. ;)
Sam. ;)
Offline Bill/BentON Racing
    • BentON Racing
« Reply #3051 on: October 25, 2012, 04:27:09 AM »
Original still hooked up.Know m ;Dore later today! Stay tuned.Bill
BentON Racing Website
BentON Racing Facebook
    • BentON Racing
« Reply #3052 on: October 25, 2012, 04:07:58 PM »
Well,the rear of the rear caliper needed some clearance,as usual Clarence was getting his way!!! ;) ;D Fixed that,then
not fixed in these pics(last night)but while running it it decided to give up 1&4 pick up on Dyna S  :( >:(
Should be working on something else!!
The pick up good one,bad one wrapped with plate,now gotta remake one using good one from Samauto! ::)
Rear brake linelock,grounded blk wire,put 12v in using MPS switch,nothing happens! ??? Switch puts 12v in when button pushed? No Commerce tomorrow night! :(....Ok well maybe,we'll see if Dyna co-operates! Bill
Offline jweeks
« Reply #3053 on: October 26, 2012, 04:48:36 AM »
Hurricane passing by. :( Don't think that you'll be racing in the rain tonight?
                                       Jon Weeks
    • BentON Racing
« Reply #3054 on: October 26, 2012, 05:22:53 AM »
Not going tonight,linelock not working,and still gotta finish ignition.Calendar Girl in midst of peg,shifter,pipe change! So we'll shoot for next Friday! Might be raining anyway. Jon,I'll take you up on another linelock,can you ship today? Times running out,hope your bikes coming along. Thanks,Bill ;D
Offline dragracer
  • CB750F Dragbike
« Reply #3055 on: October 26, 2012, 06:57:58 AM »
A new line lock can found Summit Racing just down the road from you. I'm sure that one should work.
    • BentON Racing
« Reply #3056 on: October 26, 2012, 02:39:08 PM »
Damn,I was within 15 minutes of Summit today! Jon,PM or let me know,if need be I'll get one from Summit.Thanks,Bill
Offline jweeks
« Reply #3057 on: October 26, 2012, 03:06:44 PM »
Bill,
     New one on your doorstep Tuesday. Summit can't help me. I called them. Jegs doesn't know if theirs will work the way we want it to. That's better than won't work in my application. We'll figure it out. You've got a pm on this.
        Jon Weeks
Offline POPS 911
« Reply #3058 on: October 26, 2012, 04:11:39 PM »
MORE IMPORTANT : Does the SAM-A-MATIC ATM have a REV-LIMTER so you will not ruin a head in some freak over revving ???  The 400-450cc matics have a built in rev limiter that at 7200 RPM in L [low ] the bike turns off and coast till the RPM'S drop down to a safe number then bike turns back on and runs fine down the track = found this out at a night race a few years back when I missed the shift light coming on and the motor shut down, I thought that something broke but in a few seconds the bike turn back on and I shifted in to  D [ drive ].  Got a rev-limter and 2-step Dyna unit on a old KZ ZIR frame = like new with dials, will get it to Bill for SAMS or BILLS bike as I got two new ones in the box as a gift from a fellow racer that I worked on his BUSA bike.
POPS BK911
    • BentON Racing
« Reply #3059 on: October 26, 2012, 05:03:52 PM »
Pops way cool.Theres a rev limiter on MC1 box on Samauto,but just installed the rebuilt Dyna S,no spark 1&4,just installed Dyna S off Calendar Girl,still no spark 1&4,rutrow!! Going to bypass MC1 box,we'll see,damn,why now? If box, limiter is built in box!May have to go,somethings up,now to find out,rather be testing @ Commerce as planned! :( Bill
Jon,great news,thanks so much,it will be ready....if it's running points!!!! ??? ::)
OK,Dyna,my apologies,looks like Dyna S on Samauto was OK. :-[
« Last Edit: October 26, 2012, 05:06:54 PM by Bill/BentON Racing »
    • BentON Racing
« Reply #3060 on: October 26, 2012, 05:46:32 PM »
 >:( :o ??? Yep,all those,bypassed MSD box,instant spark all 4,just not that awesome fat blue spark we did have! >:( Ok,next time I'll try the bypass plug first! ::) Sad part no other MSD box,choice of Dyna S and Dyna 3 ohm green or Dyna 2000 with grey 1.5 ohms or another MSD box(Bill's tapped out...they ain't cheap!)I'm going to put it back together,install rebuilt Dyna S on Calendar Girl,finish brakes,get linelock working and see what we got! ;D don't know why I'm grinning,oh yes I do.....cause it always happens....Racer Blues! ;) Bill
NO rev limiter with this set up!!!!!!!!!
Offline dragracer
  • CB750F Dragbike
« Reply #3061 on: October 26, 2012, 06:49:31 PM »
Hang tight. MC 1 will be on its way monday.
Online scottly
« Reply #3062 on: October 26, 2012, 06:52:01 PM »
Given those choices, I'd run the 3 ohm coils with POINTS. ;)
    • BentON Racing
« Reply #3063 on: October 26, 2012, 07:22:40 PM »
Frank,you just made my day,and brother I NEEDED it!  ;D 8)Way cool,Scottly I'm going to try Kenny's ignition next(CycleX). Dyna 2000 was probably what I'd used.Thanks to Frank(Dragracer) we don't gotta! 8) 8) Bill
« Reply #3064 on: October 26, 2012, 07:27:05 PM »
Ohh yea Bill. It just always seems we spin in 100mph circles before a race weekend.
Good luck guys, have a blast. It sounds like you'll have some good company.  8)
Offline dragracer
  • CB750F Dragbike
« Reply #3065 on: October 26, 2012, 07:30:46 PM »
Will do my very best to get it in he mail tomorrow but monday is a safer bet.
Online scottly
« Reply #3066 on: October 26, 2012, 07:39:29 PM »
OK, if the ignition is sorted, what is the problem with the line-lock? Is it a bad solenoid valve? Open coil, gummed up? Is it a problem with the wiring of the switch?
    • BentON Racing
« Reply #3067 on: October 26, 2012, 09:04:28 PM »
Going to check linelock soon,pull top and see! Jon's sending another,new one from Jeg's!! Frank's sending out a MC-1! It will be READY!!!!!! 8) Bill
    • BentON Racing
« Reply #3068 on: October 26, 2012, 10:32:42 PM »
OK,ignition box bypassed,Dyna S and green 3 ohm coils.MC-! on the way! Thanks again Frank! ;D
So back to brake,now have clearance but caliper not sitting properly'
Bracket when tightened completely had slight cock,now straight,but bracket needs clearancing!
So,wheres the MAGIC "Big File" ?Doesn't need much!
Almost
Sloooooooooooowly,we getting it!!! ;) ;D Bill
Offline POPS 911
« Reply #3069 on: October 27, 2012, 06:12:42 AM »
BILL the WRENCH-SPINNER :  Over the years I saw those MC1 go bad for no reason, talked to MSD rep at dealer show long ago and he told me to buy the NEW - UP-DATED ONE !!!!!  I told him the one we had was BRAND NEW and his answer was send it back = I walk back to the parking garage to my truck and carried back in the bad part in the box, he gave me a NEW-UP-DATED one........... this was at the Big MOTORCYCLE DEALER SHOW in Cincinnati,OHIO about 15-18 years ago. We had a few go bad over those past years and we sent them all back to MSD for repair or replacement. Never had a DYNA part go bad !!!!!  Green coils and a DYNA S ignition made the 1000 KZ'S Z1R run just fine [ 10.90 's ]  stock motor, pipe, 29's, long arm , lowered, X2 cams,elec. shift, and 110 octane AVIATION-GAS =  over 400 PASSES with no problems.
POPS BK911
  • Moderator
« Reply #3070 on: October 28, 2012, 04:05:55 PM »
Any updates before I go to beddy byes Billy.  ;D ;D ;D ;D ;D ;D ;D
Sam. ;)
    • BentON Racing
« Reply #3071 on: October 28, 2012, 06:16:01 PM »
Yep,just cleaned my helmet and gloves.Oh yeh,cleaned my boots earlier,still got to clean my leathers.My homemade beef stew about ready.What else? Pup's asleep @ my feet,wifes in bed......you mean something else? ;) ;D Ok,making pegs for Calendar Girl,ignition kill came Friday,getting ready to install RC 4-1! 8)Airshifter by Valdosta. ;D Oh you mean Samauto? Runs on all 4,MC-1 on the way(Frank),linelock new one coming from Jegs (Jon),set ignition timing,going to get with Jim tomorrow on relieving bracket for caliper and picking up air tank and line for airshifter. ;D Samauto sounds awesome!!!! We about ready!! ;D ::) Bill
How about you? You ready? ;D ;D ;D ;D ;D
    • BentON Racing
« Reply #3072 on: October 28, 2012, 07:38:31 PM »
Asleep again! Just not when the tree comes down!! ;) ;D
Some coverage for Samauto! 8)
Dave won Pro ET!
Pretty neat event! 8)
Valdosta soon!They going to be writing about Sam and Samauto soon!!! ;D 8) Bill
Offline dragracer
  • CB750F Dragbike
« Reply #3073 on: October 28, 2012, 08:22:39 PM »
Bill,
I'm putting a bracket in the box for the air shifter. If i had an extra shifter i would make up a bracket for that also and mail to you. Don't laugh at my welding because i doesn't look like Jims. Just get him to grind it all off and reweld-lol. You won't hurt my feelings.I may try to fabricate the bracket for the shifter and you can get Jim to weld on your arm. Its got a funny kick out to it so pictures may not help for you in making one.
  • Moderator
« Reply #3074 on: October 28, 2012, 11:36:00 PM »
What colour,  ;D ;D ;D ;D ;D ;D ;D ;D
