The zimmer frame as you call it.
Will be doing battle with a host of mad Victorians for their state title on the 9th and 10th of April.
Pat, Paul and all the crew are coming along as usual.
More late night's and to many beers, I'm getting to old for this sh!t.
Oh....thanks again for the cleansing ale enjoyed it immensely.
Brian
[/quote]
Cool Brian, give em hell
Have you sorted the problem with the gearbox that has been dogging you?
Sam.
[/quote]
Yep, we think so.
The motor is back in the bike.
Damaged gear change pall and pins.
Damaged detente fork.
Dogs ripped up on third gear (Main shaft).
Fifth gear chewed up(Main shaft)
Bolt mounts ripped out of the clutch base plate.
Other than that it was fine.
The Cycle-Ex clutch locker seems to be the culprit.
We will run it again but we are going to leave all the bob-weights off the fingers.
Mike seems to think it's worth a try and so do we.
Brian
