Author Topic: Steering lock key  (Read 1038 times)
Offline grumburg
  • 74550, 76400F, 72 750 67S90, 68CL90, 65 s65 66 x6
Steering lock key
« on: December 23, 2005, 05:06:57 PM »
Bought a cherry complete front end for my 550 project ($50 is cheaper than trying to rebuild frozen forks!). Since the bike has all original matching locks and original keys,  want to transfer the steering lock. No problem removing from old front end, but need t1564 key to remove from new steering head. Will pay postage if I can borrow a key, and you can have the lock.
Fonda Honda
Offline Bill Vaughan
Re: Steering lock key
« Reply #1 on: December 23, 2005, 09:56:55 PM »
Unless you're interested in saving the new lock (T1564) for future use, you really don"t need a key to remove it.  Simply drill the pins out, turn the cylinder with a flat scewdriver while pulling toward you and it's out - destroyed, but out.
Drill directly above the key slot.  The objective is to cut through the small pins, thereby allowing the cylinder to spin freely.
1972 Z50A
1973 ST90
1975 CL360
1971 CB450
1975 CB550
1978 FLH
2003 FLSTS
2006 FLHRSI
Offline Bodi
« Reply #2 on: December 24, 2005, 07:22:42 PM »
Any locksmith can open the lock for you, and many can rekey it for you to fit your ignition key. For that matter, it is a very easy lock to pick yourself. A small screwdriver to torque the cylinder and a .050 ball end allen key for your pin rake will get it turning within a minute or two.
Offline Philly550K1
« Reply #3 on: December 24, 2005, 07:57:58 PM »
maybe silly question, but did you try your key?  pat and i have different lock numbers, but our keys work interchangeably....
