Author Topic: CB750K4 Ignition Mount Gone!?  (Read 1361 times)
Offline YogiBear
« on: December 07, 2009, 11:54:48 PM »
The PO of my CB750K4 decided to put the ignition up on the handlebars. Im restoring the bike to stock, so, I got an ignition mount (stock) from a 500 parts bike ive got and the ignition cylinder fits great. But...there is no place I can find on the frame that holds the mount. Huh? On the 500, it mounts to a plate welded to the frame on the left side (if youre sitting on the bike) I examined the frame on the 750, and I cant tell if the PO ground off the bracket or what? Where the heck does the stock ignition go? I assume on the left side, just below the front of the tank? (like the 500) anybody got an ideas?  ???
1974 Honda CB750K4        1973 Honda CB500 Four
Offline bucky katt
  • i am a pastafarian!
    • facebook
Re: CB750K4 Ignition Mount Gone!?
« Reply #1 on: December 08, 2009, 12:00:50 AM »
the stock igniton switch for the 1969-1976 750k was on the left side of the frame right up to the downtube on the horizontal frame rail. in the pic, it's where the orange is, right towards the front of the horizontal frame tube
« Last Edit: December 08, 2009, 12:05:11 AM by bucky katt »
Mark Twain - Notebook, 1894
Offline YogiBear
« Reply #2 on: December 08, 2009, 12:07:15 AM »
thanks. Do you think I could use a "P" clamp around the frame the mount the ignition holder? (In its original location)
Offline bucky katt
    • facebook
« Reply #3 on: December 08, 2009, 12:13:26 AM »
that i dont know. also, i think you can get the proper 750 piece at yamiya750 http://www.yamiya750e.com/index.php?main_page=product_info&cPath=37_96&products_id=134 with the exchange rate, theyre $58.41 plus around 15 dollars shipping
Offline YogiBear
« Reply #4 on: December 08, 2009, 12:28:47 AM »
So thats what the stock mount looks like huh? Well...that looks nothing like the CB500 mount I have. I guess that would explain why there is nothing on the frame.  That just clamps on to the frame. Thanks Bucky. that explains a few things. ;)
Offline celebutante
    • my website, yay
« Reply #5 on: December 08, 2009, 01:22:05 AM »
Yes you can. I did and it worked out swell- specifically an electrical conduit clamp holding the little boomerang-shaped plate the PO used to mount the switch on the triple clamp. I rattle canned the brackets all black and it looks great.
rostosky750
« Reply #6 on: December 08, 2009, 01:28:53 AM »
Ah, this might save a new post....
having just finished restoring my frame and this bracket , I thought it would be a shame to just bolt it back on and scratch the frame up, as this was a very rusty area of the frame before I restored it , So I thought I would put a small wrap of something like thin inner tube or some other protective wrap around the frame first...but then I thought does this bracket have to be earthed at the frame ??? I am quite sure it doesn't but wanted to check...
Offline YogiBear
« Reply #7 on: December 08, 2009, 01:48:53 AM »
Thanks! thats what I like to hear. haha. Off to Lowes...
Offline Toxic
« Reply #8 on: December 08, 2009, 04:30:20 AM »
That bracket doen't need to be grounded to the frame.
Offline celebutante
    • my website, yay
« Reply #9 on: December 12, 2009, 04:23:00 PM »
Actually, the bracket I got included little rubber pieces that go over the bracket- perfect. And no, it doesn't need to be grounded to the frame.
