Author Topic: Where is the Steering Head Bearing tutorial?  (Read 1653 times)
Offline Johnie
« on: December 10, 2009, 04:18:53 PM »
I recall there was a real nice tutorial on replacing the steering head with roller bearings. It had nice pics and all. I can not locate it. Can somene get me there. Thanks...
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline GammaFlat
Re: Where is the Steering Head Bearing tutorial?
« Reply #1 on: December 10, 2009, 04:52:16 PM »
If you can wait, I hear there's a section in HondaMan's book on that.  There are a couple of nice posts here as well.
Here's one discussion: http://forums.sohc4.net/index.php?topic=7401.msg103752#msg103752
« Last Edit: December 10, 2009, 04:54:08 PM by GammaFlat »
K6
K7
Suzuki GN400 - Ignition fixed!
03 KLR650 - Doesn't do anything very well but.. well.. does everything.
Offline hoodellyhoo
  • CB350F
« Reply #2 on: December 10, 2009, 08:47:40 PM »
There's this thread:
http://forums.sohc4.net/index.php?topic=1516.125
Scroll down and Kirkn goes through the process with great pictures and explanations.
Offline Johnie
« Reply #3 on: December 10, 2009, 08:54:17 PM »
Ah, that is what I am looking for.  Thanks...
Oshkosh, WI  USA
Online Don R
« Reply #4 on: December 11, 2009, 11:57:41 PM »
If you have a tapered type race in there now just use a dremel and make a small tapered cut above the race. then punch it out with a drift from above. I used a piece of angle cut tubing
There are a few ways suggested in the thread but none this easy.
« Last Edit: December 12, 2009, 12:03:21 AM by Don R »
Offline Johnie
« Reply #5 on: December 12, 2009, 07:31:31 AM »
Don...I have the old ball bearing race in there now. I was just going to knock it out with the drift like I do with the races in car hubs. Never had problems with getting races out unless this is different. Thanks for the tip. I take it you are installing new too.
Oshkosh, WI  USA
Offline Freaky1
« Reply #6 on: December 12, 2009, 08:28:58 AM »
That link to Kirkn's post was great hoodellyhoo, I like replies like that to questions us newbies ask that have been asked a million times before, thanks.
I did this about 2 months ago without the cooking and freezing, just a trusty blow torch and everything came out the same. I also had the problem of the top being a hair higher but as I'm using different headlight mounts, I don't think this will be a problem. The only thing not mentioned so far and maybe it's just me, but the lower dust seal was somewhat tricky to get in as you need to make sure the lip on the seal doesn't turn over, nothing a little patience won't cure. I will be removing the top dust seal though just to see what effect this has on my setup.
That which does not kill you leaves cool scabs which turn into awesome scars.
'77 CB750F Come on...were almost there!
Offline Johnie
« Reply #7 on: December 12, 2009, 11:36:21 AM »
Good tip there Freak on the lower dust seal. I will watch for that. The top dust seal is not needed from what I read and I think I will not use mine. I believe if I read the tutorial correct the top seal is not needed as the top bearing nut has a dust cover there. Plus, when you leave it out it helps to get the correct spot so the fork ears fit proper again.
Oshkosh, WI  USA
Offline Freaky1
« Reply #8 on: December 12, 2009, 12:38:07 PM »
The cap that is attached to the nut that goes on top fits right on the top of the bearing and race, there is no "seal" per say (rubber) but with the way it fits together I agree that going without shouldn't pose a problem.
Offline Old Scrambler
« Reply #9 on: December 12, 2009, 01:41:19 PM »
I am in the middle of a replacement like this and hope to remove a small amount of metal from the top neck race support. This will allow the new race to nest lower in the neck to properly align the top tree with the stock headlight ears.  My local shop tech is suggesting we make a cutting tool that could be shared by mail with other bearing replacements........interested?
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline Freaky1
« Reply #10 on: December 12, 2009, 08:54:34 PM »
I don't remember how much meat there is on the bottom of the top race, might not be enough to cut off to make it level. I think the best way (a.k.a. the biggest pain in the ass) would be to cut the recess in the neck so the race can seat in farther.
