Author Topic: 1975 CB550F Project Penguin. A.K.A. David  (Read 90396 times)
Offline Zaipai
    • My Home page
Re: 1975 CB550F Project Penguin. A.K.A. David
« Reply #525 on: July 02, 2010, 05:35:15 AM »
Oh yea.. She is running strong.. I need to adjust the cam chain tensioner and the tappets and sync the carbs but none of that is so bad so I can take my time with it. In fact I am on vacation all next week so I will have some time for that. As for the exhaust, well it will be a winter thing along with the braided brake lines etc.. I can wait, and it gives me plenty to do over the winter months along with the GS1000 build I am doing.
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline 75cb550 (kyle)
  • so you're calling me a
  • KEEP YOUR BOOGER HOOK OFF THE BANG SWITCH
    • My Album
« Reply #526 on: July 02, 2010, 07:00:42 AM »
badass
Offline Zaipai
    • My Home page
« Reply #527 on: July 10, 2010, 08:00:58 AM »
So been taking time off from doing any thing with the Honda to try and get this beast running. Well I got it running however the carbs need some work. Talk about picky carbs.. holy cow..
.: Scott :.
Its my Avatar..
75 CB550F  |
traveler
« Reply #528 on: July 10, 2010, 08:04:43 AM »
MY #1 cab does the same thing....now you feel my pain.
I like the lines on that tank.....not sure about those gauges. :-\
~Joe
Offline Zaipai
    • My Home page
« Reply #529 on: July 10, 2010, 08:22:44 AM »
~Joe
Yea, same here.. Once I get it running I am going to look at the lines, etc.. I am thinking since its such a big bike and it has power to spare, I may make this a touring bike with fairing and bags.. Not sure tho? She runs pretty sweet given she is a 81 and been in a garage for over 10 years not touched. Anyway still thinking about it. One option still on the table is to sell her and use the money to beef up the motor on my 550.. ;)
.: Scott :.
Its my Avatar..
75 CB550F  |
Online RAFster122s
« Reply #530 on: July 10, 2010, 11:41:45 AM »
Have you gone through the carbs; the float needle valve isn't working clearly. It's got a dirty seat or is damaged...or the float isn't moving freely in the float bowl. Or you could have a leaky float causing it (hole in the float).
Uh just to clarify, is it leaking out of the float bowl gasket area or overflow?
If float bowl gasket, then you need a new gasket or the bowl has a problem. Could be an undersized gasket if it has new gaskets.
Glad you got it running.
The big GSs are nice bikes, great for long distances if you have a good comfortable saddle.
Offline Zaipai
    • My Home page
« Reply #531 on: July 10, 2010, 12:34:22 PM »
Yea, I replaced the float needle and the seat it sits in. So I am guessing its either a hole in the float, tho I don't think so since all 4 are leaking the same way, or the float level, seems the most likely cause. I did replace the float bowl gasket on all of them as it came in the kit I picked up. It did this before I even touched the carbs so I am guessing the PO mucked things up, and I did not adjust the float levels since I did not have the info when I was doing it.
The odd part about this bike, and maybe its the same on all Suzuki's is the petcock is vacuum operated, that is when on reg setting gas does not flow until a vacuum is created. They do give an over ride called PRI (as mentioned in the video) and reserve seems to bypass this also. I don't believe it has anything to do with what is going on, however it was just some thing I found odd.. But then I am a newb with bikes and carbs so...
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline Zaipai
    • My Home page
« Reply #532 on: July 10, 2010, 03:52:07 PM »
Ok anyone want to take a guess as to why the the carbs are leaking like crazy.? I will provide one hint.. Its not the floats, float needle or float needle seats..
Check back in 1hr for the answer...  ;D
.: Scott :.
Its my Avatar..
75 CB550F  |
Online RAFster122s
« Reply #533 on: July 10, 2010, 04:47:41 PM »
uh...not trying to be insulting...
missing gasket
missing screw
warped bowls
PO drilled hole in carb bowls?
plumbing problem?
Offline Zaipai
    • My Home page
« Reply #534 on: July 10, 2010, 05:21:20 PM »
missing gasket
missing screw
warped bowls
plumbing problem?
Lol.. You are close...
I was an idiot.. I was hooking up the gas line to the vacuum port on the petcock...
So the gas was running out of the vacuum ports.. Yea, I am that much of a newb.. Man..
Well I am going out to hook it up the other way around and see..
.: Scott :.
Its my Avatar..
75 CB550F  |
traveler
« Reply #535 on: July 10, 2010, 05:32:23 PM »
When I pulled my 4-2 pipes off and upon closer inspection....lets just say you wouldn't want them.  they went to the dumpster....there was nothing really left......not worth the postage.
~Joe
Offline Zaipai
    • My Home page
« Reply #536 on: July 10, 2010, 09:07:02 PM »
~Joe
Ok Joe thanks for the thought anyway.. I am still trying to figure out what I want to do with it once I get the cash to do some thing.
Well some progress on the 1000, I hooked up the gas line to the correct hose and tada, there is no gas leaking any longer. The only issue now is if I give it gas slowly, it revs to about 4 to 5k and starts to bog, if I get on it quickly (i.e. blip the throttle) it bogs.. so clearly some thing is going wrong there.. However its late and I am tired so off to bed with me..
It rained most of today, so Sunday if it does not rain I am taking Penguin out for a run because I need to ride a bike that does not give me such issues to re-energize myself.
Later..
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline Captainkirk
  • Certified bike nut
« Reply #537 on: July 20, 2010, 07:20:44 PM »
Nice work getting the zook running. Now I WILL have to come by and see them in person! ;D
I keep looking for your house as I cruise up and down K... ???
It's easier to ask forgiveness than to gain permission.
Offline Zaipai
    • My Home page
« Reply #538 on: July 20, 2010, 08:56:30 PM »
Well if your looking on K you wont find it. Its on 235th Ave. off of K before EW.. ;)
We are working on a Sunday brunch around 10am at the Sly Fox just a few minutes west of Paddock Lake, should you feel like coming (Weather permitting) I will post here once I have every thing hammered out, so far.. Me, Spikeybike and Godffery.. perhaps others.
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline Captainkirk
« Reply #539 on: July 21, 2010, 09:38:42 PM »
Ahh.....235th. I saw it as I rode by tonight around 7-ish.....you may have heard Rex thundering by.......nothing set in stone for the weekend yet, but that could change in a heartbeat.
Offline Captainkirk
« Reply #540 on: August 01, 2010, 03:17:34 PM »
Scott; you will not believe what I just snagged.... ???
3 guesses.....
Offline Zaipai
    • My Home page
« Reply #541 on: August 01, 2010, 05:54:59 PM »
3 guesses.....
Another CB? ;) Don't keep me in suspense!
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline Zaipai
    • My Home page
« Reply #542 on: August 01, 2010, 06:10:44 PM »
Well its getting worse.. I am going to have to try tightening down the heads and see what happens.. This is what it looked like after a 15min ride at 65+ and getting on it as hard as I could from stop signs..
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline Captainkirk
« Reply #543 on: August 01, 2010, 08:24:04 PM »
3 guesses.....
.: Scott :.
That was only one guess. I should make you wait......
Can you say....GS1000? :o
Offline Captainkirk
« Reply #544 on: August 01, 2010, 08:26:20 PM »
.: Scott :.
Hmmm. Hard to tell from the pix exactly where it originates, but rocker box gasket would be my first guess.
Offline Zaipai
    • My Home page
« Reply #545 on: August 01, 2010, 08:29:35 PM »
There is no oil above where the fins get bigger, so head gasket? Spikeybike and Godffrey saw a sample of it last Sunday, I pointed it out then. So I probably just need to tighten the nuts some but not till next weekend. The other side however had no real leaks so I am hoping that will work.
.: Scott :.
Its my Avatar..
75 CB550F  |
« Reply #546 on: August 01, 2010, 08:31:43 PM »
either the gasket or the oil passage o-rings , either way , tightening the head bolts might remedy it
Offline Zaipai
    • My Home page
« Reply #547 on: August 01, 2010, 08:36:42 PM »
Sure hope you are correct. Think I should pick up a torque wrench and see what they are at currently. Stay tuned, next Sunday night I will post the verdict. Tho I have to work next weekend also so hopefully I can get it done.
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline Zaipai
    • My Home page
« Reply #548 on: August 01, 2010, 08:37:22 PM »
3 guesses.....
.: Scott :.
Sweet what year? Pictures? Does it run? etc..
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline Captainkirk
« Reply #549 on: August 01, 2010, 09:17:05 PM »
3 guesses.....
.: Scott :.
.: Scott :.
Sweet what year? Don't know. I haven't seen it yet......
Pictures? I haven't seen it yet......
Does it run? No. Supposedly missing the carb bank and tank? But the price is right ($0.00) and it supposedly has a title. A friend of one of my bike buddies asked him if he wanted it....being strictly a Brit bike guy, he calls me and says, "Hey....want a free bike?"
What was I supposed to do? Tell him no? ???
