Author Topic: struts or shocks? differances?  (Read 3085 times)
Offline cafenut
  • it dont hurt till the bone shows
« on: December 13, 2009, 07:44:17 PM »
any input
88 1100 katana
84 500 ascott
78 750 f cafe
78 750 f original
78 750 k stock
76 750 k custom
76 750 k chop project
Offline socalenduro
Re: struts or shocks? differances?
« Reply #1 on: December 13, 2009, 07:47:48 PM »
 all i can figure out in 31 years is a shock mounts on both ends usually with eyelets, while with a strut the shaft mounts directly to the object (car, truck, bike suspension)
the two eyelets allow dynamic or pivoting/rotating mounting points on both ends vs static on one end of a strut
Offline cafenut
« Reply #2 on: December 13, 2009, 08:09:35 PM »
good point. good food for thought.
88 1100 katana
84 500 ascott
78 750 f cafe
78 750 f original
78 750 k stock
76 750 k custom
Offline Inigo Montoya
« Reply #3 on: December 14, 2009, 06:30:05 AM »
I think in the motorcycle world, a strut is completely solid allowing for a "rigid" rear end.
Offline Gregorymoto
  • SOHC Aficionado
« Reply #4 on: December 14, 2009, 06:35:13 AM »
One reduces forces one does not.
Yep, i have issues with this sort of stuff.
Offline tortelvis
« Reply #5 on: December 14, 2009, 06:59:05 AM »
Run over a pothole with struts and then you will find out the difference. ;D
drag-on
« Reply #6 on: December 14, 2009, 07:10:24 AM »
LOL........ struts (drags) shocks (street)  ;D
Offline socalenduro
« Reply #7 on: December 14, 2009, 08:13:15 AM »
"The function is essentially the same, but the largest difference is the way they mount to the vehicle. The strut design acts an integral part of the suspension by replacing the upper control arm and acting as a pivot point for the steering."
http://www.kyb.com/technical/faq/faq15.php
but it looks like the motorcycle world has created its own definition... until someone comes up with a completely "new" suspension design
« Last Edit: December 14, 2009, 08:17:32 AM by socalenduro »
Offline mystic_1
  • 1970 CB750K
« Reply #8 on: December 14, 2009, 08:14:06 AM »
Don't confuse the meaning of "strut".  Many people make this mistake because of the popularity of MacPherson struts which are a very specific device in cars where the support member is also part of the steering system.
Generally speaking a strut is any structural component designed to resist longitudinal compression.  How it does so and to what degree it does so is dependent on the designed application.
Shock absorbers, as we know them on motorcycles, are one specific type of strut.
mystic_1
- John Augustus Shedd
Offline socalenduro
« Reply #9 on: December 14, 2009, 08:22:06 AM »
mystic_1
he is smart, and webster seems to agree
–noun
1.   any of various structural members, as in trusses, primarily intended to resist longitudinal compression.
« Reply #10 on: December 14, 2009, 08:42:32 AM »
mystic_1
Agreed. In the context of the OP question, having been made on a motorcycle board, I'm guessing he means motorcycle struts which are simply soild rods with no give.
To further the answer to the question, struts on a motorcycle are done for mainly 2 reasons. In the drag race context mentioned, struts will concentrate weight transfer to the rear wheel, whereas a shock would absorb a lot of it, reducing the launch. The 2nd reason as also alluded to, is to mimic a "hardtail" suspension for aesthetics. In reality most hardtail frames are longer and with the seat in the middle, don't provide as harsh a ride as a standard length frame with struts would.
Though I hope to never experience either.
« Reply #11 on: December 14, 2009, 10:56:02 AM »
The above is what I was referring to. That has been my understanding of struts as pertaining to motorcycles.
Offline mystic_1
  • 1970 CB750K
« Reply #12 on: December 14, 2009, 11:01:06 AM »
Some motorcycle 'struts' actually have springs but solid ones are the most common.
mystic_1
Offline cafenut
« Reply #13 on: December 14, 2009, 06:13:45 PM »
i was refering to an absorbing device with internal components. sorry. never really thought of all the veriations.
88 1100 katana
84 500 ascott
78 750 f cafe
78 750 f original
78 750 k stock
76 750 k custom
« Reply #14 on: December 14, 2009, 06:38:57 PM »
YOu ask a question here, better stand back!   ;D   ;)
