Author Topic: Frame mod cb 750  (Read 91539 times)
Re: Frame mod cb 750
« Reply #100 on: November 06, 2013, 09:20:49 AM »
Be mindful that what works on Mikes frame may not be adequate for anyone else........considering that little pussy engine he has.  ;D  ;D
« Reply #101 on: November 06, 2013, 09:25:39 AM »
My thoughts exactly. Tee Hee.   ;)
Offline Phoenix
« Reply #102 on: November 06, 2013, 09:40:02 AM »
I'm looking for a no-weld method because of cost and not wanting to pull the motor to weld it.  I had my top-end done and now have an indication of a head leak.  As I understand it, any re-build requires a re-torque of the head after 500 miles.  Pulling the engine, again, is almost too much to ask.  IF, in the day, guys cut them out and left it that way, you would think a reasonable "fix" could solve it unless you race or are big on wheelies.  Terry suggested sliders that were of a larger id and split to close the joints.  What if the sliders are also a thicker, stronger material.  Wouldn't that do the job.  KrautKoffin pointed out that there wasn't much interest to build anything because money would not cover parts and labor.  I, for one, would be willing to pay a reasonable price for someone like Frank, or ....., to design and manufacture sliders and plates to do the job.  They know what they're doing.  I don't.
I'd be willing to pay 50 to $75, or whatever, plus freight, for 4 sliders and 2 plates. No reason anyone making something shouldn't make an adequate profit.
Ed Spengeman
Indy
1971 CB750K1 (Stock)
1973 CB350 Twin  (Gone)
Offline KrautKoffin
« Reply #103 on: November 06, 2013, 10:01:46 AM »
You can call me Jordan, and I totally agree. The less times I have to pull a motor the happier and the more I'll spend on this kit.
74 cb550
I now have Beastie Boys "Sabotage" stuck in my head after seeing your avatar.
« Reply #104 on: November 06, 2013, 10:19:16 AM »
Hi Ed:
The Gordon Kit was selling for $250 IIRC, plus labor. The Carpy Kit is probably closer to what you're looking for.
http://www.cb750cafe.com/products-page/frame-adapter-kit/
Make no mistake, I fully agree, stronger is better in all respect. But...
I probably have the most mileage experience running a kit of any design. Least wise no one else has piped up with more. I assure anyone who is concerned that strength is not an issue. If you ride harder and faster than I did in those days, well maybe, you'd notice.
If you get a chance to swing by, I'll show you how it works. Big Jay at APE sold thousands, maybe tens of thousands of the kit I have. He did not report any failures nor have I ever heard of a frame failure, with or without a kit.  Your situ is a perfect example though. You can easily cut the tubes out, retork the head, and install the kit. To do a really neat job, you may have to remove some electrics, reposition the ignition key to the handlebar, remove the carbs, nuisance things like that to make room for the Sawzall.
I bot my K1 from Honda-Triumph of Indy. Have you been in Indy long enough to remember them? 46th and Keystone. Owned by Bill Romer, who never rode a motorcycle in his life. The mechanics got him on one of the Honda 3 wheel ATCs, new at the time and he promptly plowed into the back of his Cadillac. Good Times.
I worked there at the time as well. He didn't want to warranty my leaky head gasket, a big problem with new bikes back then. The mechanic took pity on me and for a 6 pack, pulled my engine, retorked it, reinstalled it, in drag strip type time. And I was fixed. Back in the day when two of us could lift an engine and toss it around.
Offline Phoenix
« Reply #105 on: November 06, 2013, 03:09:53 PM »
Ron and Jordan, etal
My only problem with the current non-weld methods are that I would just as soon keep my triangle and add sliders and plates.  It was also mentioned that the current sliders have to almost be knocked on with a hammer.  I'd like to be able to get just (2) plates with (4) sliders that slide.  To me that would be the perfect fix.
Ed Spengeman
Indy
Offline KrautKoffin
« Reply #106 on: November 06, 2013, 04:20:49 PM »
Well you and I are in the same boat. I'm in the market for a kit too, I just don't want to give carpy my money :)
74 cb550
Offline Rookster
« Reply #107 on: November 06, 2013, 05:40:30 PM »
You can make your own kit.  The frame rails are 1" OD.  You need steel tube that has an ID of 1.00x".  The plates you can make from flat stock that they sell at Home Depot.  I'm not sure of the wall thickness on the sliders in the Carpy/Ape style kits but you can order 4130 steel tube with an ID of 1.010" or 1.009" from McMaster Carr.  There are a couple of different options but your sliders should be 3-4" in length each.  Cut, drill, bolt and your good to go.
Scott
Offline CB750R
  • 77 CB750F
« Reply #108 on: November 06, 2013, 05:55:24 PM »
If you bust out some kits let me know Frank, I think I can make the drive from Vernon to pick a set up!
« Reply #109 on: November 06, 2013, 09:41:29 PM »
Vernon!! Hey get over to BCclassic motorcycles, join up and get to our coffee meetings.
Yeah I better start on these pronto.....
Offline CB750R
  • 77 CB750F
« Reply #110 on: November 06, 2013, 10:04:04 PM »
Thanks for the heads up, I'm currently waiting approval!
« Reply #111 on: November 06, 2013, 11:25:52 PM »
Yep, hurry up Frank and make your frame kits, or I will, and I'll patent 'em and sue your arse if you copy mine! ;D
« Reply #112 on: November 07, 2013, 05:10:07 AM »
Hey......I resemble that remark. ;D
« Reply #113 on: November 07, 2013, 06:28:02 AM »
Whew, I got off lucky. I was worried I might have sacrificed my sponsorship deal for the sake of a joke!
Offline KrautKoffin
« Reply #114 on: November 12, 2013, 10:36:31 AM »
So, who is making these kits? I'm pulling my motor in a few days and would like to only have to dick with this one time.
74 cb550
« Reply #115 on: November 13, 2013, 11:30:08 PM »
Yeah Frank, what's going on, have you got some kits done yet?  ;D
« Reply #116 on: November 14, 2013, 06:53:11 AM »
They are about 1/2 done..
 A couple prototypes, then I can make more.
Offline BPellerine
« Reply #117 on: November 14, 2013, 03:05:11 PM »
we are waiting!haha bill
1978 CB 750K ard and webers
another anfob
Offline KrautKoffin
« Reply #118 on: November 14, 2013, 04:14:33 PM »
Frank,
Have I told you lately that I love you?
74 cb550
« Reply #119 on: November 15, 2013, 02:43:12 PM »
Geez that really is the voice of desperation, don't let them down Franky! ;D
« Reply #120 on: November 15, 2013, 03:14:39 PM »
The problem with that idea (and most of us have had it before) is that the OEM tubing's weld seam protruding inside the tube will not allow you to use an internal slider unless you can somehow grind it out, (difficult, at best) and of course, even if you could, how do you move the internal sliders once they're inside the OEM frame tube? Telekinesis? ;D
Offline Rookster
« Reply #121 on: November 16, 2013, 08:35:10 AM »
My reply was targeted at "installing the new tube outside of the original cut ends" which WILL crush those ends
How?
There is no clamping force applied to the sliders or the frame tubes. The sliders are a loose interference fit.  What force will crush the frame tubes?
There are 2 things at work here:
1. There is a belief that those frame tubes serve either no purpose or are an integral part of strengthening the backbone/steering head.  If they serve no real world purpose they can be cut and discarded.  Many CB750s have suffered this fate.  If they are an integral part of the frame then the only proper solution is a welded in rigidly bolted replacement like the Gordon style kit.  If you aren't sure if they are useless or crucial maybe a kit like the old APE kit that involved sliders and bolts may be what you need.  None of us have done any real scientific tests on the rigidity of the fame/steering head with or without those tubes so we rely on our opinions and beliefs.
2. I am interested in the old APE style kit and wanted to make my own because the ones for sale seem overpriced.  I also wanted to understand a little more about the length and fitment of the sliders.  I did some very quick research about loose interference fits and talked to MCRider because he uses an old APE kit.  My instructions were a way to build an APE style kit for about $30.  No more/no less.
Scott
Offline KrautKoffin
« Reply #122 on: November 16, 2013, 10:38:19 AM »
Scott
Scott, put me down for two kits.
- Jordan
74 cb550
« Reply #123 on: November 16, 2013, 03:15:20 PM »
If you're knowledge exceeds my observation, please accept my apology and I stand corrected if this is not possible on the OP's frame.
Apology accepted, if it was a practical solution, it would have been done long ago.
My reply was targeted at "installing the new tube outside of the original cut ends" which WILL crush those ends and potentially fail unless a Gordon's style kit is used.
Nope, the external sliders bolted thru the frame isn't a perfect solution by a long shot, but unless you're using 3/4" diameter bolts and a ten foot bar on your socket handle, you definitely won't crush the frame tube.
Having said that, I disagree with Scott and his assumption that the side rails may or may not serve any worthwhile purpose. They were designed as support rails for the top frame tube, and you don't have to be a mechanical engineer to understand why they are there, and what they do. If you don't, you should not be allowed to own a hacksaw, for obvious reasons........ ;D
Offline timbo750
« Reply #124 on: November 17, 2013, 08:33:38 PM »
In the days before CAD a lot of things were over engineered and I am betting that someone told the engineers back in the 60's make sure the frame has no issues. The crucial component is the triangle brace in the middle - look at any bridge made out of steel or timber. it would seem that the sole purpose of the rails is to support the triangle brace and as such would only have forces along the length of the braces. All together it would make the top frame support much more rigid, most likely under hard braking and when the suspension was working hard over bumps.
This may of been said before and I am no expect on these bikes, it would seem that these parts are important but not crucial as proven by people in the past who have ridden for years with out it.
