Author Topic: Frame mod cb 750  (Read 93444 times)
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
Re: Frame mod cb 750
« Reply #200 on: January 12, 2014, 02:00:00 PM »
Frank, my F2 is powder coated and I come up with four different dimensions ranging from 1.006 to 1.016. How much clearance is already built in? More than .010"? If they measure 1.016 or more I'm good to go.
I'm ok with black fasteners.
Build threads:
1977 CB750 F2
1958 Norton Model 99
« Reply #201 on: January 12, 2014, 02:21:21 PM »
They are mostly between 1.008 and 1.013.
 So you. Could sand it down around .006 and they should fit. It should go pretty quick with emery cloth with a  back and forth motion.
 I can make bigger ones, next run..
Offline martin99
  • UK Based, Non-
« Reply #202 on: January 12, 2014, 02:33:50 PM »
I'm sure they'll be ok as they are. Rather have them tight anyways, so don't mind a bit of sanding :)
Build threads:
1977 CB750 F2
Offline 750K
« Reply #203 on: January 27, 2014, 09:04:33 PM »
Got my kit in the mail today Frank, looks killer. Top notch machining, can't wait to get them installed at some point. They should work perfectly.
77 Cb750, 78 Kz1000
Offline KrautKoffin
« Reply #204 on: January 27, 2014, 09:11:05 PM »
Frank, do you have any instructions for installation?
74 cb550
I now have Beastie Boys "Sabotage" stuck in my head after seeing your avatar.
« Reply #205 on: January 27, 2014, 09:53:23 PM »
I wil, put someting together next few days, i can pm the basic messurements.
Nic
« Reply #206 on: January 28, 2014, 05:45:22 PM »
Received mine today, thanks Frank, excellent work. Will hack up the frame soon as my new adjustable cam sprocket gets here.
Offline Phoenix
« Reply #207 on: January 28, 2014, 05:50:36 PM »
Frank
How much to Indpls
ed_spengeman at yahoo.com
Ed Spengeman
Indy
1971 CB750K1 (Stock)
1973 CB350 Twin  (Gone)
« Reply #208 on: January 28, 2014, 09:14:15 PM »
Ceck your pm..
Nic
« Reply #209 on: January 29, 2014, 02:02:06 PM »
Kraut, it's not critical where you cut, here's how I hacked mine out, I left room for the ignition switch at the front, as long as you can remove the cam cover you're good to go. I managed to cut mine without removing the carbs, clearance at the carbs is good, cuts are nice and crooked, doesn't matter. I had to sand off some of the powder coat, 60 grade paper 1" wide with gaff tape backing, was quite easy, Franks joiners are a perfect fit. Hope this helps. Will add a pic of the finished product later.
« Last Edit: January 29, 2014, 02:06:51 PM by Nic »
Offline Bailgang
  • Scott
  • Indiana
« Reply #210 on: January 29, 2014, 02:10:04 PM »
Ceck your pm..
PM a price to me while you're at it, I'm in Monticello Indiana so you can figure shipping price.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
Offline timbo750
« Reply #211 on: January 29, 2014, 02:33:50 PM »
Got mine yesterday, nice work. I thought there was something missing because the box was so small and light, you could almost call them cute.
can someone give me the measurements for the cut, my engine is out of the frame and in pieces and I would like to cut before I send it of to the powder coaters.
Nic
« Reply #212 on: January 29, 2014, 02:44:25 PM »
Here're my measurements.
Offline 750K
« Reply #213 on: January 29, 2014, 03:11:55 PM »
Did you use a grinder and zip disc or a sawzall?
77 Cb750, 78 Kz1000
Nic
« Reply #214 on: January 29, 2014, 03:16:52 PM »
Good old hack saw mate, I wanted to remove the least amount of metal as pos so the gaps would be as small as possible. Hence, I have "hacked" the frame.
Offline 750K
« Reply #215 on: January 29, 2014, 03:19:01 PM »
Thanks
77 Cb750, 78 Kz1000
Nic
« Reply #216 on: January 29, 2014, 03:22:57 PM »
Thanks
The reason the cuts are angled is because that's the only way the hack saw would fit in the gaps, with the engine out the cuts would have been easy to do straight up.
Offline timbo750
« Reply #217 on: January 29, 2014, 03:24:04 PM »
Thanks Nic
it looks like from the photo that the 225mm dimension could actually be a little shorter, how close are the clamps to the carbs?
Tim
Nic
« Reply #218 on: January 29, 2014, 03:27:12 PM »
Thanks Nic
Tim
Yeah you're right, it's pretty tight but no fouling at all with the throttle. I'll post a pic or two soon, just waiting for the paint to dry on the H section.
« Reply #219 on: January 29, 2014, 03:39:55 PM »
You should be able to cut the front at 3 1/2 back from the lower weld at the front tube..should allow room for old style ignitionswitch bracket. The rear cut can be 5 1/4 to 6 1/4 from back weld. If carb clearance is tight.. Only the VN 29,s that I know of... The cuts could be even further to rear. Behind the carbs.
Nic
« Reply #220 on: January 29, 2014, 04:12:40 PM »
All done up tight, thanks again Frank. Couple o pics.
Offline Bailgang
  • Scott
  • Indiana
« Reply #221 on: January 29, 2014, 04:32:51 PM »
Frank, check your paypal account then check the PM I sent you. Paypal charged a fee that caught me off guard and just wanted to make sure all was cool on your end.
Scott
71 cb350 twin
77 cb750 F2
Offline shpwrk
« Reply #222 on: January 30, 2014, 10:16:29 PM »
Frank   I would like to get a set of frame mod kit..  Do you have any in stock?
Pete   pecarosel@aol.com
Pete Caroselli
« Reply #223 on: January 30, 2014, 10:30:05 PM »
Yes I have 1 or two left. You can pm  me your address thru this forum (if it works) for shipping price.
Or email me at
« Reply #224 on: January 31, 2014, 03:28:51 AM »
This kit will really save a lot of work and scratches on frame, engine and mashed fingers!
Change cam when I want new funny experience.
I'm in too!!
- Any extra wobble to expect?
Something else that can be done with the frame to improve the stiffness here?
