Author Topic: Frame mod cb 750  (Read 78645 times)
Offline VB-SLE
Re: Frame mod cb 750
« Reply #275 on: September 08, 2014, 04:57:20 PM »
Will get total price for you later today, thanks.
Thanks, post code is 5710.
Offline welard
  • is this the dude from Highlander?? Oh sht, it is..
« Reply #276 on: September 10, 2014, 09:49:18 PM »
Hi Frank
Do you have any more of the frame kits left? If so could you kindly let me know how much and the shipping costs to Sydney, Australia.
Cheers
Pete
« Reply #277 on: September 11, 2014, 08:44:11 AM »
Shipping info sent, am out of kits at present ..
Am starting on another batch, should have some ready by months end if not sooner.
Offline timbo750
« Reply #278 on: September 16, 2014, 04:52:40 AM »
I was trying to work out how to get these on with out sand back heaps of the powder coating.
So what ended up working is putting one clamp bolt in from the back of the thread and a small piece of steel in the gap so it spreads the clamp.
« Reply #279 on: September 16, 2014, 03:16:01 PM »
Can you mic the diameter of the frame with the powder on it.
At first I thought. I would have to bore a few set to a bigger diameter, but so far nobody requested that. . I think most just sanded. A bit off.
 In the early days of powder it was quite thick. Seems these days it tends to be thinner.
Nic
« Reply #280 on: September 16, 2014, 05:48:29 PM »
Mine was powder coated, sanded off easy as pie.
« Reply #281 on: September 20, 2014, 08:42:27 AM »
 Am working on a new batch of frame kits should be ready in about 10 days.
 Also have a new tool in the works, should be ready in a week. Will be handy on most sohc 4 models and many more Hondas.
Offline timbo750
« Reply #282 on: October 01, 2014, 01:47:02 PM »
Frank
Sorry this took so long, I measured 2, one of which had a slight bulge at the end of the tube. Must of been the way is was hung when it was coated, the measurement I have is after I have sanded it down a fair bit.
« Reply #283 on: October 01, 2014, 04:23:11 PM »
That looks like quite  a lot of buildup...probably 4- 6 thou more would have to come off. .
Offline timbo750
« Reply #284 on: October 01, 2014, 05:18:34 PM »
I would of thought that so long as the frame and cut out are the same then would not matter too much. But are saying that it needs to be close to the original size. Would this be to prevent future fatigue of the clamp.
« Reply #285 on: October 01, 2014, 08:28:41 PM »
Not. Sure if this answers you, if you spread it as you described it should not hurt anything at that size shown..as long as you don't have to hammer it to move it in place.
 Ideal though and easier, if. You get it down to size where it will slide back and forth. If you were removing it often that would make a difference.
Nic
« Reply #286 on: October 01, 2014, 08:41:25 PM »
Exactly and you'll be thankful when you go to put the last one on. Just get a 25mm wide length of emery paper about 120 grade, wrap it over the tube and pull it back n forth working your way around the tube, it takes no time at all. You want them to slide freely.
Online PeWe
« Reply #287 on: October 02, 2014, 04:08:18 AM »
I used valve lapping compound between the clamps and frame for fine adjustment. No paint on the frame under the clamps. Need more sanding for rust protective paint layer to stay intact when its  tight. Bike in warm garage should not make rust possible
I have removed the top frame several times this year, head lifted for service, cam timed several times and cam changed. Will soon change cam again. Plan to compare 3 different cams and Dyno test them.
Change cam is not fun without frame kit... :(
soo much work including draining oil, oil filter and exhaust and carbs and oil tank/hoses off. All bolts and wires, electrical and mechanical. Plus scratch paint, fingers, get the engine on my fot, body (spine) damage when lifting the engine up to the bench.... be home sick recovering cost some $$ too..
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #288 on: October 16, 2014, 03:21:45 PM »
Frank's frame kit arrived today. Might get it installed this weekend (might not, too... garage roof to fix).
Handy opening instructions:
Installation instructions:
The whole kit:
--Evan
1975 CB750K "Rhonda"
Offline markreimer
« Reply #289 on: January 09, 2015, 09:46:48 AM »
Hey guys,
I bought one of the weldless frame kits. It's beautifully made, but I don't actually need it anymore. I ended up pulling my motor out anyway, and the bike I bought it for is slated to be sold in spring anyway, so no point in installing it now.
If anyone would like to buy mine from me while Frank makes his next batch, send me a PM. It's brand new, in the box.
Offline evanphi
  • Apparently I'm an
« Reply #290 on: March 09, 2015, 11:48:15 AM »
--Evan
Online PeWe
« Reply #291 on: March 15, 2015, 12:13:58 PM »
My frame cuts for frame mod fits Mikuni TMR32 with KN filters very well too!
I installed the frame mod for Mikuni VM29 smoothbores
http://forums.sohc4.net/index.php/topic,62832.msg1515860.html#msg1515860
With this frame mod I have lifted the head once changing cyl studs and left head for for seat and valve job to the same guy that ported it for over 30 years ago. Changed cams 3 times and re-timed one of the cams one extra time. Plus fix threads on head holding the cam. All work with engine in frame!! Fantastic!!
Change cam with exhaust and carbs still on without draining oil too... soo much work I do not need to suffer!
Honda made a big mistake back in the 60's. They should have constructed a removable frame part so even the CB750 purists can do the service under the valve cover without pulling the engine!!
« Last Edit: March 15, 2015, 12:16:00 PM by PeWe »
Offline markreimer
« Reply #292 on: April 22, 2015, 07:20:52 AM »
Just a note: The frame kit I mentioned having two posts ago has now been sold to another forum member.
« Last Edit: April 22, 2015, 08:27:26 AM by markreimer »
« Reply #293 on: April 22, 2015, 07:40:10 AM »
I will have more soon, spent a full day on them last week, another day I should have 7 or 8 sets ready..
Offline Casper
    • hondacb750
« Reply #294 on: May 22, 2017, 09:02:51 AM »
Hello 754,
I' m Casper de Jong from the Netherlands and have a question, do jou  still make this clamps?
And if jou do can i order a set?
Regards,
Casper.
Verstuurd vanaf mijn ALE-L21 met Tapatalk
« Reply #295 on: May 22, 2017, 12:46:34 PM »
Casper I sent you a messag. By PM.. Thanks
Offline Henkies
« Reply #296 on: December 10, 2017, 10:36:19 AM »
Can anyone tell me what the inner diameter of the tubes is: Outer diameter is 1", and inner?
Online PeWe
« Reply #297 on: December 10, 2017, 11:16:46 AM »
21.5- 21.7mm. Just  measured my K2 frame that is cut.
Offline calj737
  • I refuse...
« Reply #298 on: December 10, 2017, 12:39:45 PM »
1” tubes with 0.063 wall thickness
Offline Henkies
« Reply #299 on: December 10, 2017, 01:02:43 PM »
Where would we be without this forum. Thanks for your quick replies guys
